Old 02-10-2008, 09:22 PM   #1
ncrk
ncrk has made poor choicesncrk has made poor choicesncrk has made poor choicesncrk has made poor choicesncrk has made poor choicesncrk has made poor choices
Send a message via AIM to ncrk
SR boost gauge reading 20 lbs vaccum?
i installed a new autometer boost gauge and i drove my car for the first time and it was reading between 10 and 20lbs of vaccum...
if it helps, i have the t25 turbo that comes with a redtop sr20
why is it doing thatt??
ncrk is offline   Reply With Quote
Old 02-10-2008, 10:21 PM   #2
Kouki
Kouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud of
If you're just cruising the gauge is going to read vac, if you put it to the floor you should see it hit full boost between 2900-3200 rpm. At idle it will probably read somwhere around 20-25psi vac, because there is no load on the engine.
Kouki is offline   Reply With Quote
Old 02-11-2008, 12:09 AM   #3
sd8ted
sd8ted is an unknown quantity at this point
What you are seeing is completely normal. My car idles at ~21psi vacuum and unless I'm over 1/4 throttle it will stay on the vacuum side. If you are saying that you are full throttle and the gauge won't come out of vacuum then theres either a problem with the line to the gauge or the gauge itself.
sd8ted is offline   Reply With Quote
Old 02-11-2008, 01:18 AM   #4
louisdaboois
louisdaboois's Avatar
Trader Rating: (28)
louisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfection
Feedback Score: 28 reviews
its actually mmHg of vacuum. which 25mmHg is about 0.5psi if my asian genes serve my calculations correctly.
louisdaboois is offline   Reply With Quote
