![]() Join Date: Jan 2007
sr20 compression test results
So yeaaaaa out of sheer boredom at work i decided to do a compression test on my motor and this is what i came up with:
Engine is moderatly warm. CLY1=105psi CYL2=105psi CYL3=104psi CYL4=103psi When i searched for compression test results i saw people coming up with 140psi numbers and new SR motors should be around 200psi...this blew me away, i didnt think that compression numbers were supposed to be that high. Should i pull the head and check her out?? This is a stock sr with stock boost, stock cams just the normal bolt ons, FMIC, Tubular mani, exhaust. Thanks guys
d-faction.com |
What is your elevation?
Put a teaspoon of motor oil in a cylinder and test it. If the compression goes up its most likely your rings. If it doesn't go up then it could be a headgasket issue or valves seals etc etc. |
Elevation is about 500ft nothing that would effect that. The power hasn't felt weak or anything i just did this compression test out of randomness. The motor has never been refreshed to my knowledge, it should have stock pistons and such.
d-faction.com |
![]() Join Date: Aug 2005
Trader Rating: (60)
![]() Feedback Score: 60 reviews
warm your engine to normal operating temps and test it again. You should have more normal numbers. Also make sure you test with the throttle body open. You should be getting number around 150-155.
my experience has been that EVEN numbers across the board like you have got - are good news.
i did a test on one of my VW 1.8t last year. with 2 different air devices. first run i was seeing 135-140s acrooss the board, the 2nd run, 2 days later, i was seeing 180s across the board, different measuring device (probably better) and different day. gotta be a warm motor, just be slow taking out the spark plugs, warm threads are tender. |
throttle body open, yes i let it stabalize i let it crank over about 5 times and the gauge maxed out after about 3 cranks. When i did the test when the motor was hot it came out to 98-95psi numbers. Stock cams. I think im gonna do a leakdown sometime this week. thanks guys
d-faction.com |
![]() Join Date: Oct 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
so wat were the leakdown results? I"m in the same process with my honda motor.
AIM SoarinStrong[B]STRONG 6iX[B] RB single turbo ///Work AMKREAD 180sx |
![]() Join Date: Apr 2005
![]() ![]() ![]() ![]() Feedback Score: 6 reviews
4 times should be max. on my first sr, i got 150 in the first 3 and 155 in the last. on my current motor, i'm too scared to do a test. its running fine and i don't wanna start getting all paranoid
