Old 02-25-2008, 03:16 PM   #1
ILoveJDM
ILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to behold
Stumbling, random stalling
alright, this only started happening after i gave her beans around a corner.
sohc ka stock
when i downshift ex 3rd->2nd, when i first touch the gas after its in gear the car with hesitate (no power, like a misfire) then it will be fine.
other times the car will randomly stall, then itll fire on first crank.
im guessing its some sort of fuel issue.
ILoveJDM is offline   Reply With Quote
Old 02-25-2008, 03:56 PM   #2
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
search for MAF, this sounds like a common MAF issue
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
Old 02-25-2008, 03:56 PM   #3
pbcstylez
or search stumbling idle, random stalling
Old 02-26-2008, 01:06 AM   #4
slider2828
slider2828's Avatar
Do 100k or 80k tune up such as fuel filters and everything else. No water pump change needed.
Turn and Burn!
Old 02-26-2008, 01:54 AM   #5
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
check timing, ignition is the key to a healthy car
change fuel filter, can cause stumbling and hesitation at high rpm due to lack of fuel/ backed up filter
change spark plugs, and gap them to .030. very critical if your ignition system is weak, car is old so nothing is factory spec.
Change oil, and make sure there are no vacuum leaks
Good luck
SoguRacing is offline   Reply With Quote
