Old 03-05-2008, 11:58 AM   #1
yankee_TOP-END
yankee_TOP-END's Avatar
yankee_TOP-END is on the path to ruinyankee_TOP-END is on the path to ruin
VQ30 swap
im planning to make a full swap to my S14a with a Z32 N/A engine & tranny auto (cause its cheaper this way hehehehe) , but im thinking of the problems that im gonna have ?????
does someone knows what are the problems that im gonna pass thru this swap or can I have some tips ???
tnks !!!
Yankee_Top-End
yankee_TOP-END is offline   Reply With Quote
Old 03-05-2008, 12:02 PM   #2
STEVES14
STEVES14's Avatar
STEVES14 is making his/her stupidity well-knownSTEVES14 is making his/her stupidity well-knownSTEVES14 is making his/her stupidity well-knownSTEVES14 is making his/her stupidity well-known
Send a message via AIM to STEVES14
tnks !!!
that swap needs some custom brackets for the motor and tranny and maybe a custom driveshaft not sure check out the hybridZ forum they do some crazy swaps with nissains from VQ motors to ls1 swaps
STEVES14 is offline   Reply With Quote
Old 03-05-2008, 12:13 PM   #3
johngriff
johngriff's Avatar
Use the S12 VG30 Car front crossmember, and new S12 VG mounts, with the Z32 brackets slotted a little.
Rebuild your KA trans onto a S12 VG30 Bellhousing, use the STOCK KA mount and Stock KA drive shaft.
[email protected]
Old 03-05-2008, 12:08 PM   #4
yankee_TOP-END
I'll check it out !
Yankee_Top-End
Old 03-05-2008, 12:14 PM   #5
SILVIA_KIDs14.5
SILVIA_KIDs14.5's Avatar
Trader Rating: (-1)
SILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choices
Feedback Score: -1 reviews
is it Vq or VG your talking bout if VG mazworx.com is the place to go to. they can machine the housing to fit in the s-chassis not sure if they do just for vg swaps but it might be an option and they have a custom drive shaft to fit the z32tranny to the s-chassis thats what i plan doing is takeing the z32 tranny and hookin it up to the sr stronger gears good luck wit the swap
SILVIA_KIDs14.5 is offline   Reply With Quote
Old 03-05-2008, 12:18 PM   #6
yankee_TOP-END
im talking about the VG30DE.....sorry !
Yankee_Top-End
Old 03-05-2008, 01:23 PM   #7
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
I was about to say...why would you want to put a FWD Maxima engine in your 240?
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 03-05-2008, 01:29 PM   #8
dragon_x330
dragon_x330's Avatar
dragon_x330 has a little shameless behavior in the past
Send a message via MSN to dragon_x330
VQ? FWD Maxima engine? LOL I think you mean VG.
I think the Q's been answered...but why auto?
Its like Turbo'ing a KA24DE with an auto tranny...its just not...the same.
LOL
-OMGWTFBBQ
dragon_x330 is offline   Reply With Quote
Old 03-05-2008, 02:29 PM   #9
yankee_TOP-END
ok I think I mix up miself ! im talking about the Z32 engine swap to my S14a , the VG30DE , and i choose auto because here i can get it cheaper !! hehehehe
Yankee_Top-End
Old 03-05-2008, 03:12 PM   #10
Bushido
Bushido's Avatar
ehhh... read/research more.
if you are going to go through the hassle of swapping an engine not designed for that chassis, why swap an outdated, heavy iron block VG?
you should have meant VQ30 like you orginially said.
yes, you can swap a FWD maxima motor. you need a few pieces from RWD VQ's, but overall it's unquestionably a better motor than the VG.
and how much money do you really think you're going to save keeping it an auto? in the realm of custom wiring, custom mounts, custom driveshaft, etc... the couple hundred saved at the engine supplier is nothing really...
Old 03-05-2008, 03:34 PM   #11
yankee_TOP-END
you got me there!! .....true,true ! sounds pretty hard.........i think I'll do the 5speed swap and put a t25 to my ka24.........maaannn!!!! this swaping thing is pretty hard & expencive!!
Yankee_Top-End
