Old 03-09-2008, 02:57 PM   #1
harleys
harleys is an unknown quantity at this point
Eng Cont fuse draining battery?
First i'll start with some info on the car:
89 Nissan 240sx Coupe
Sr20det swap
and other goodies that don't really relate to this problem.
Problem:
For a while now, the battery is dead if the car sits for more than a couple of hours. So today I finally broke out the multimeter to see what was drawing all the power. I figure out that it is the FL25A Eng Cont fuse under the hood. It's drawing about 10a with nothing at all on inside the car. I believe this fuse is for the ecu, so i tried disconnecting the ecu and it still has a draw.
Can anyone tell me what else this fuse powers? What could be drawing the power? I'm so tired of having to keep a jump box with me to start my stupid car. I tried giving all info that is related to the problem, if you need to know something else, just tell me.
Thanks in advance for the help.
-harley
harleys is offline   Reply With Quote
Old 03-09-2008, 07:48 PM   #2
slider2828
slider2828's Avatar
I think pretty much the ecu.... check your grounds on the ecu... Pull it and see if it is still drawing.
Turn and Burn!
Old 03-09-2008, 09:35 PM   #3
harleys
i did pull the ecu. even unplugged it still has the draw.
-harley
Old 03-09-2008, 11:31 PM   #4
slider2828
slider2828's Avatar
Check the wiring diagram.... sorry, try also the mafs.... which is connected o the Ecu as well.
Turn and Burn!
Old 03-11-2008, 11:38 PM   #5
harleys
update: ok. figured out that it is the 02 sensor drawing power. if i unplug it, i have no draw at all. the red wire and white wire in the plug going to the sensor have continuity. not sure if it is supposed to, but doesn't sound right.
-harley
Old 03-11-2008, 11:48 PM   #6
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
I have the same problem! I'm gunna check my fuse tommorow, also the O2 sensor. Thanks! (My car is an '89 S13 with a blacktop SR)
DataXUnknown is offline   Reply With Quote
Old 03-12-2008, 11:59 AM   #7
harleys
There are hundreds of things that could be draining your battery. It took me couple hours to narrow it down to this.
-harley
Old 03-12-2008, 02:46 AM   #8
PIwakawa
PIwakawa is an unknown quantity at this point
my car had the same problem, just ran w/o O2, since there is no emission in florida.
PIwakawa is offline   Reply With Quote
Old 03-12-2008, 07:44 AM   #9
Mangudai
Mangudai's Avatar
Mangudai is an unknown quantity at this point
^ Doesn't thats affect gas mileage? Im assuming you mean the front o2 sensor..
Mangudai is offline   Reply With Quote
Old 05-02-2016, 07:08 PM   #10
Drift_86
Drift_86's Avatar
Trader Rating: (60)
Feedback Score: 60 reviews
I'm having same exact problem could some one pitch in and help me out?
