Old 03-20-2008, 03:19 PM   #1
sofo259
sofo259's Avatar
sofo259 is an unknown quantity at this point
sr sputters around 2500rpms, more throttle it runs fine
since i got my car running last week, i havent really drove it until a few days ago, and i noticed while pulling through a shopping center around 2500rpms my car likes to sputter like it has a misfire..
any where above that, when i am accelerating it is fine, if im trying to go a steady speed, it sputters..
i am still running on the stock DOHC fuel pump (for now) an SR maf, and the engine is all stock..
i swapped out my MAF with a friends sr MAF, and it was still sputtering, swapped ECU, and it still sputtered..
we have narrowed it down to a fuel problem so far, but has anyone else had this problem ??
i am ordering my walbro, and a FPR tomorrow so hopefully that will fix the problem. Because i'm thinking that my stock pump isnt pumping enough fuel at a steady pace to keep it going but at higher RPMs its just fine..
fckin weird !!!
sofo259 is offline   Reply With Quote
Old 03-20-2008, 03:21 PM   #2
180sx_Drifter
180sx_Drifter's Avatar
180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection
sounds like you need to install the walbro. i had that problem and swapped the fuel pump and that solved everything. swap out the fuel pump and see if it still does it.
180sx_Drifter is offline   Reply With Quote
Old 03-20-2008, 03:25 PM   #3
S14monkey
S14monkey is an unknown quantity at this point
Might also want to check your coil packs. I had a coil pack that was going bad. My car would idle normally, but when I accelerated, my car would sputter like how you described. Get a fresh coil pack and swap it out one by one. See if that helps any.
*Actually, I should have read your post more closely. My car would sputter around 2500rpm, but it would continue to sputter all the way up the range. So maybe it is the pump.
S14monkey is offline   Reply With Quote
Old 03-20-2008, 03:42 PM   #4
dnbwithweed
dnbwithweed is not welcome here anymorednbwithweed is not welcome here anymorednbwithweed is not welcome here anymorednbwithweed is not welcome here anymorednbwithweed is not welcome here anymorednbwithweed is not welcome here anymorednbwithweed is not welcome here anymorednbwithweed is not welcome here anymorednbwithweed is not welcome here anymorednbwithweed is not welcome here anymorednbwithweed is not welcome here anymore
Send a message via AIM to dnbwithweed
hmmm that happened to me but my tps was causing the problem. just throwin it out there.
I would drag race too, If i didnt know how to drift.
ok, so i dont!
dnbwithweed is offline   Reply With Quote
Old 03-20-2008, 03:54 PM   #5
sr20det drift
sr20det drift is on the path to ruinsr20det drift is on the path to ruin
yeah i would check into the tps or fuel pump
sr20det drift is offline   Reply With Quote
Old 03-20-2008, 08:52 PM   #6
sofo259
sofo259's Avatar
well i just replaced my TPS, with a new one because my sr is an auto motor, so i had to go to a manual TPS..
