Old 05-02-2008, 07:41 PM   #1
reactor
reactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nice
Power FC Help
Alright, so I just bought a brand new Power FC from Unnatural and it was delivered to my house today. Went outside, unplugged the Negative battery cable, disconnected my stock ECU, installed the Power FC, and reconnected the battery cable. I then turned the ignition switch to on and the Power FC didn't come on, so I attempt to start it and still nothing car won't start! I had this exact same problem with another Power FC I bought used and was working when I bought it. Plug back in the stock ECU and the car starts and runs just fine.
Has anyone ran into a problem like this? Has anyone fixed this problem?
Apex Power FC Part Number - 414AN014
Stock ECU Currently in Car - 62
reactor is offline   Reply With Quote
Old 05-02-2008, 08:46 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Something is up with your wiring harness...check all your pin outs...you'll never know if something is modded on the harness thats causing the PFC to spritz...
CLICK HERE!!!
Old 05-02-2008, 11:23 PM   #3
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
i agree /w flip
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 05-02-2008, 11:36 PM   #4
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
make sure the power fc is plugged in all the way. the harness can be a tight fit.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 05-03-2008, 02:03 AM   #5
MaD1337M3DRiV3r
MaD1337M3DRiV3r's Avatar
MaD1337M3DRiV3r has a reputation beyond reputeMaD1337M3DRiV3r has a reputation beyond reputeMaD1337M3DRiV3r has a reputation beyond reputeMaD1337M3DRiV3r has a reputation beyond reputeMaD1337M3DRiV3r has a reputation beyond reputeMaD1337M3DRiV3r has a reputation beyond reputeMaD1337M3DRiV3r has a reputation beyond reputeMaD1337M3DRiV3r has a reputation beyond reputeMaD1337M3DRiV3r has a reputation beyond reputeMaD1337M3DRiV3r has a reputation beyond reputeMaD1337M3DRiV3r has a reputation beyond repute
Its a tighter fit than stock, I had the same issue.
MaD1337M3DRiV3r is offline   Reply With Quote
Old 05-03-2008, 02:00 AM   #6
S14DB
AFC #1
S14DB's Avatar
What happens a lot is that people that do SR harnesses don't wire all the power leads correctly. Needs the BATT power and the IGN power wired corectly to work.
Take the ECU out and Check the Grounds, BATT power and IGN power. Make sure the BATT is constant and the IGN comes on when the switch is in ON.
Old 05-03-2008, 02:08 AM   #7
SoguRacing
SoguRacing's Avatar
^Thanks for the feedback. I thought I had a problem with it being too tight.
Old 05-04-2008, 10:11 AM   #8
reactor
Alright, I've figured out the problem, but not the cause. With my stock ECU all pins that are supposed to get power, get power. The harness was wired correctly to begin with. When I plug in my Power FC the 2 ECCS Power pins do not get power. When I force power directly to those pins the Power FC comes on. I've tried bypassing the relay, tried giving power directly to the wire in the engine bay that goes directly to the ECU, and it won't turn on unless I give power directly to those pins. So either there's some resistance in the wires, or the Power FC requires more amperage than the stock wires are handling. I'm going to check the resistance on the wire right now, but if the resistance is good, I'm just going to directly wire the 2 pins from an ignition on source.
Old 05-04-2008, 11:32 AM   #9
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
Odd.. mine worked just fine. Shrug. Keep us up to date. Does anyone have a description for what all the shit in sensor/switch check stuff is??
-Bart
DJ_Sunrise is offline   Reply With Quote
Old 05-04-2008, 11:57 AM   #10
ROIDMONKEY
ROIDMONKEY's Avatar
ROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfection
my stock ECU was 62 also from a 91BT, my power FC is for a 94-96 black top and works perfectly on my 91. forgot the PFC part number tho
TRUE thing: True ////OFFSET\\\\ is acheived without spacers
Running on E85 570whp Precision 5862....laggy as fuck. hate it
ROIDMONKEY is offline   Reply With Quote
Old 05-07-2008, 02:50 PM   #11
Xantcha
Xantcha is making a name for him/her selfXantcha is making a name for him/her self
Same thing happened to me on my '96 sr. Turned out to be a missing relay. There are two behind the ecu that must be plugged in for the pfc to work. If one or the other (i forget which) is plugged in, the stock ecu will work fine, but the pfc won't. Might be totally different but it's something to just check, take you 5 seconds. Hope it helps!
Xantcha is offline   Reply With Quote
