Old 05-06-2008, 03:03 PM   #1
miami-z
miami-z is making his/her stupidity well-knownmiami-z is making his/her stupidity well-knownmiami-z is making his/her stupidity well-knownmiami-z is making his/her stupidity well-knownmiami-z is making his/her stupidity well-known
Noob? What size spacers and tires for 18' 6 spoke z33 wheels for my s13
Hey guys, tried searching but did not find anything. I want to know what size spacer and what size tire i should run on my s13. The wheels im going to run are the 18' z33 6 spoke. My car is on Tein coils, i want the wheels to sit real low and flush. i know i might have to roll the fenders. Thanks in advance
miami-z is offline   Reply With Quote
Old 05-06-2008, 04:32 PM   #2
d r i f t swift
d r i f t swift's Avatar
d r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the rough
spacers and tire size all depends on preference and what youre trying to do with the car. i dont think you really searched..
http://marksink.com/tire_wheel_offset/offset.html = wheel offset calculator
http://www.zilvia.net/f/showthread.php?t=129865 = wheel fitment whore thread
http://www.zilvia.net/f/showthread.php?t=166563 = max rubber fitment thread
rip bobby.. you will be missed..
d r i f t swift is offline   Reply With Quote
Old 05-06-2008, 04:36 PM   #3
miami-z
if you say so bro, thanks
Old 05-06-2008, 04:37 PM   #4
A Spec Products
A Spec Products's Avatar
I think the ones you are referring to are something like an 18x8+30?
It's still a pretty broad question though, since each person's definition of "flush" is relative
But I'd say at least a 15-20mm bolt on spacer should do it
driftswift is correct though, there are a lot of resources to answer this question
Since in this case, 8 inch wheel inside clearance isn't really technically a big issue
So really its just matching up equal outer position to a wheel that you see
For example if someone posts up their S13 with 18x9+15 all around and you like how that looks in regards to outer position near the fender
Then type in 8 inch 30 offset into the wheel offset calculator (current)
Then type in 9 inch 15 offset into the wheel offset calculator (new)
Then you get the result "The outside edge of the wheel will EXTEND an extra 28mm"
Which tells you that if you want to match up the same outer position, you need a 28mm spacer to achieve that same distance
Got it?
A SPEC PRODUCTS CORP
Old 05-06-2008, 04:39 PM   #5
miami-z
yea that's the size, thanks alot bro
