Old 05-29-2008, 12:25 PM   #1
s14kouki_
s14kouki_ has much to be proud ofs14kouki_ has much to be proud ofs14kouki_ has much to be proud ofs14kouki_ has much to be proud ofs14kouki_ has much to be proud ofs14kouki_ has much to be proud ofs14kouki_ has much to be proud ofs14kouki_ has much to be proud ofs14kouki_ has much to be proud ofs14kouki_ has much to be proud ofs14kouki_ has much to be proud of
s13 sr in s14 TEMPERATURE SENSOR QUESTION
MODS LOCK/DELETE!
well i read that you are supposed to use the s14 temp sensor even thought its an s13 sr so i went and bought one from autozone, but now the problem is, the plug wont go in to the temp sensor. it has two prongs but the shape of the sensor is SLIGHTLY different shaped. so what do i do now? do i man handle it and force it in? or am i supposed to use the s14 sr one? help thanks
facts:
97 s14
blacktop s13 sr
using sr harness and ka lower harness
READ LAST POST:
well i double checked my wiring and it is RIGHT! temp is yellow to blue/black and tach is red/yellow to red/yellow. and i double checked to make sure cluster was plugged in all the way. and my temp gauge still shoots up and my tach doesnt work =( i checked every single fuse and nothing is blown. please helP!
s14kouki_ is offline   Reply With Quote
Old 05-29-2008, 12:45 PM   #2
monkeyslide17
monkeyslide17's Avatar
monkeyslide17 will become famous soon enoughmonkeyslide17 will become famous soon enoughmonkeyslide17 will become famous soon enough
Send a message via AIM to monkeyslide17
I belive ur supose to get a temp senor for a 91 to 94. If you got a s13,
or u can just by pass and get a guage that will be more accurate.
monkeyslide17 is offline   Reply With Quote
Old 05-29-2008, 01:31 PM   #3
projectRDM
projectRDM's Avatar
Incorrect. Use the single prong gauge sender from an S14, not the two prong ECU sender. Two completely different things. The two prong sender matches the ECU, not the cluster.
The single prong sender is only if you want to keep your OE temp gauge, otherwise you don't even need it.
FORMERLY R240NA
Old 05-29-2008, 01:47 PM   #4
s14kouki_
my man! so the one right next to the temp sensor right?
Old 05-29-2008, 01:56 PM   #5
surreybc
surreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond repute
the temp sensor changed sometime after 1994 . not sure which year.
surreybc is offline   Reply With Quote
Old 05-29-2008, 02:02 PM   #6
besTint
Trader Rating: (81)
besTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the rough
Feedback Score: 81 reviews
Send a message via AIM to besTint
are you talking about these things?
http://squarespokes.com/
besTint is offline   Reply With Quote
Old 05-29-2008, 02:14 PM   #7
aznrib
aznrib is making a name for him/her selfaznrib is making a name for him/her selfaznrib is making a name for him/her self
yes he is......msg length
aznrib is offline   Reply With Quote
Old 05-29-2008, 03:03 PM   #8
projectRDM
projectRDM's Avatar
Single prong - gauge
Dual prong - ECU
ECU sender matches the ECU, gauge sender matches the cluster.
FORMERLY R240NA
Old 05-29-2008, 03:21 PM   #9
s14kouki_
ok i changed it to a 1997 240sx one from autozone and still same thing =( do i need a s14 sr one?
Old 05-29-2008, 03:41 PM   #10
surreybc
http://www.sr20forum.com/search.php?...3&pp=25&page=2
try searching. this has come up before.
Old 05-29-2008, 05:26 PM   #11
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
They either keep giving you the wrong shit or theyre just a bunch of dumbasses. Go to the dealer and get the sensor (less than $30) or if you have the sensor from your old KA, swap that over to the SR.
But like what Russ already stated, the stock gauge sucks, go invest on a real water temp gauge that will tell you your cars getting hot and overheated already...
CLICK HERE!!!
Old 05-29-2008, 08:53 PM   #12
s14kouki_
yeah they probably are giving me the wrong shit. well ima try the dealer. but why doesnt my tach work either? my gas gauge is the only one that works...
Old 05-29-2008, 03:50 PM   #13
besTint
Trader Rating: (81)
i swapped mine from my s14 KA. i think thats what your supposed to do. not from s14 SR.
Old 06-01-2008, 10:28 AM   #14
s14kouki_
i went and got a s14 sr single prong sensor and still nothing. could it be a ground somewhere that i didnt ground? im starting to think i got the right sensor now since i seen the guy pull it off the s14 sr.
Old 06-02-2008, 11:00 PM   #15
s14kouki_
Old 06-03-2008, 01:23 PM   #16
aznrib
take your cluster off and inspect the traces on the back. If you can try another cluster to verify its not your cluster.
Old 06-03-2008, 07:53 PM   #17
s14kouki_
so are the f3 power plug to s13 sr cluster plug the only wires i need to check? are there any other wires that might be messing with the cluster?
Old 06-07-2008, 06:14 PM   #18
s14kouki_
finally got it fixed!! thanks to bukky at R&D Factory!! the pinout on the jdm s13 sr cluster plug was different than the harness plug i had so he just repinned those wires and VOILA!! tach and temp work!! MODS PLEASE LOCK/DELETE!
Old 06-07-2008, 07:39 PM   #19
WoolyS14DET
WoolyS14DET's Avatar
Trader Rating: (18)
WoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond repute
Feedback Score: 18 reviews
Send a message via Yahoo to WoolyS14DET
very nice +1 for R&D
WoolyS14DET is offline   Reply With Quote
