Body Advice
Right now, My passenger side keylock is not there. So I was thinking about how I might be able to close it. What do you think the best way to do this will be?
Im not going to ever use my passenger side keyhole, so no I dont wanna go buy one at a salvage yard. my handles are intact, just the keyhole = Empty. When I bought the car it never had a passenger door key lock. Last edited by HIM; 06-03-2008 at 04:07 AM.. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
just hit a junkyard and get new handles w/ locks??
or if your set on shaving them off, then itd be wise to pull the door panel, get inside the door, put in a filler panel behind the hole where the lock was, ie weld in the panel, adhesive ect. then filler over that. if you just slapped bondo in the hole it will crack and fall out 1 day. |
#3 | |
![]() Join Date: Dec 2006
using a washer can fill up a key hole pretty easily..and then just fill in the hole in the washer, with weld. smooth that out as much as you can (a grinder, or file if a grinder isnt avai.) then after all that....small amount of plastic to smooth out the body.
Admin Asshole
![]() Join Date: Mar 2002
Welded panel > Bondo
New handle, lock, and key > Shaved
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
![]() Join Date: Sep 2003
id just hit up the junkyard and pull the assembly and get some new keys made...
S14 TrackSlut coming to a raceway near you... 510 TimeAttack on its way... |
