-10 oil return line- what do i weld to the pan?
I will be running a -10 oil return line from my t25 ka-t. I don't have the lines with me, nor do i know much about them.
What do i need to weld into my oil pan so i can easily connect the -10 line later? I know JGS sells a 1/2 threaded fitting, but is that the best/most used route to connect to -10an? Also, can i use a threaded portion from like home depot or are they threaded differently? thanks |
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 20 reviews
Does your -10 line already have ends to it? Or are you going with AN fittings?
I went KA-T and bought this fitting and had it welded to my oil pan. http://www.anplumbing.com/shop/images/997110.jpg then bought a AN fitting from a local shop for the -10 line to thread onto the newly welded fitting. http://www.anplumbing.com/shop/images/6487_165106.jpg They were all -10 so it was real clean and simple. If the -10 line already has a male or female end on it, I'm sure you can find which weld on bung you need at http://www.anplumbing.com/shop/index...dept=Weld!_Ons. Hope that helped. |
