Guest
Posts: n/a
how do u gap a spark plug?
![]() Join Date: Nov 2001
you can get the tool at any car parts store. the blade type also called a feeler gauge is the one I've used most. just use the blade that is the same size as the gap you are trying to achieve and slide it between the two electrodes. if the blade fits loosly, tap the electrode on somthing hard to bend it down a little and if it is too tight, then pry it out a little. the blade should fit pretty snug. also, if the size you need is bigger then any one blade you can combine them, just by adding the sizes
AutoX Junkie
It's just something you set to factory specs.
In engines with a low compression ratio, i.e., in which the combustion mixture is not so greatly compressed, the distance between the electrodes is made larger: this produces a longer spark, which can more readily ignite the mixture than a shorter one can. Since a highly compressed gas presents a higher resistance to the spark, a smaller spark gap is employed with high compression ratios. |
