Old 09-23-2008, 02:54 PM   #1
SidewayZ-s14
SidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enough
Preping car for paint help?
Hey guys, ive been reading and searching a bunch and im getting mixed reviews on what grit sand paper to use and how far down im supposed to sand. some people say 500grit grit and some say 1000. I'm a little confused as to what i need to do what i need.
Heres what im doing...Id like to sand and bondo the dents and fix the rust spots on my s14 before i take it in for paint so i can save me some money. I'm pretty sure on the dent ill want to take the paint all the way down to the bare metal so i can then bondo it and sand it flush with the car. What about on the other parts on the car that dont need bondo or rust to be fixed.....
I'm lost as to what grit sand paper to use, and how far to take down the paint. I have the Emerald green color now, and plan on doing black. Any help would be greatly appreciate it.
SidewayZ-s14 is offline   Reply With Quote
Old 09-23-2008, 03:06 PM   #2
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
1st try and get the dents out as far as you can, hammer/dolly, dry ice etc, filler should only be used for surface imperfections etc. then you can use 90 grit on a DA to "smooth" it and 150 or so on a long board to get it close, and finally 220 to get it finished.
basically you want to get rid off all the clear off the car and "scuff" paint so that the new paint/primer will have something to stick to, i have always used scotch bright pads they will give u a great surface to work with, red scotch brite then green.
are you going to have it painted? or do it yourself?
if ur having it done talk to the painter 1st.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 09-23-2008, 04:38 PM   #3
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
This is a good tip
PLEASE don't use "bondo" as the universal term for "body filler". There are much better body fillers on the market other than Bondo brand.
when it comes to the actual clear coat ruff down. I recommend 400 wet/dry. You want to properly etch the panel as so the new paint as something to adhere to. MAKE SURE you use some sort of pre-painting cleaner BEFORE you sand. I recommend wash the car, use Prep-All on the panels, wet sand, rinse with water, use Prep All again, then paint.
IF you don't do that you run the risk of embedding more oil and trash into the previous paint and not giving the new paint a good surface to adhere to.
Like the guy said above, get a book and read or just let your guy do it.
There is more to it than you think
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 09-23-2008, 04:30 PM   #4
spartanic
spartanic is an unknown quantity at this point
Go to your local Barnes and Nobel and get a good book on car painting.
spartanic is offline   Reply With Quote
Old 09-23-2008, 04:33 PM   #5
SidewayZ-s14
Id rather not spend more than i need to. thought i could come here and get some prefessional advice for free. kthnks.
Old 09-23-2008, 04:32 PM   #6
SidewayZ-s14
I'm going to have it painted. Why have i been reading to use 600grit and wet sand my car? So im basically going to just take off the clear and scuff up the emarld green that is there now, so the primer/paint have something to "bite" to?
Old 09-23-2008, 06:26 PM   #7
SidewayZ-s14
Thanks for all the tips! I'll just talk to the painter and see if we can work something out.
-Thanks
Old 09-23-2008, 06:30 PM   #8
widegts
Banned from the Marketplace
widegts's Avatar
Location: Walnut/WestCovina ............................ Everything in this world is art. A simple alteration of how you see something, is art. So with that in mind, what do you see as art!!!
widegts is close to perfectionwidegts is close to perfectionwidegts is close to perfectionwidegts is close to perfectionwidegts is close to perfectionwidegts is close to perfectionwidegts is close to perfectionwidegts is close to perfectionwidegts is close to perfectionwidegts is close to perfectionwidegts is close to perfection
Send a message via AIM to widegts Send a message via Yahoo to widegts
come by the shop, and ill show u some ways, shortcuts, and tricks.
widegts is offline   Reply With Quote
Old 09-23-2008, 06:38 PM   #9
SidewayZ-s14
Alright sweet! Can i get the directions? I'll stop by tomorrow after school around 1pm or so.
