Old 11-28-2001, 07:05 PM   #1
Arcane
Arcane is an unknown quantity at this point
I was practicing drifting and yanked on the e-brake.  when i released it, the light didn't shut off.  now, whenever the car is on...so is the #### light!  how do i turn it off??? :confused:
i was thinking of just cutting the wiring...but i don't know how to get behind the panel...
Arcane is offline   Reply With Quote
Old 11-28-2001, 07:08 PM   #2
chickenmanq
chickenmanq is an unknown quantity at this point
Your e-brake cable may be rusty. Get underneath and check it. Make sure your wheel isn't braking. Jack up car and spin both wheels with hand.
Other than that, look underneath where the e-brake is, and you should find a little switch or something that's stuck.
(Edited by chickenmanq at 7<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>9 pm on Nov. 28, 2001)
chickenmanq is offline   Reply With Quote
Old 11-28-2001, 07:16 PM   #3
Arcane
the brake isn't on...i'll try to find the switch thingmabobber...
Old 11-28-2001, 09:07 PM   #4
drifterx
drifterx's Avatar
drifterx is an unknown quantity at this point
Send a message via ICQ to drifterx Send a message via AIM to drifterx
i dont know if this is true... maybe u need new brakes?
well try drifting without your ebrake.... it is possible
hmm try the pull the line from under the car.... then try to jack it up and have another friend pull the ebake and see does the line move......either that or check the ebrake sensor thing for the light
i dont know crap so dont quote me
just giving thoughts
drifterx is offline   Reply With Quote
Old 11-28-2001, 11:28 PM   #5
KoukiS14
KoukiS14's Avatar
KoukiS14 is an unknown quantity at this point
Send a message via ICQ to KoukiS14 Send a message via AIM to KoukiS14 Send a message via Yahoo to KoukiS14
eBrake? We don't need it to drift. . hehe we don't drive Civics =) &nbsp;
I've used it like twice. . but. . ####. . just downshift and pop the clutch to slide lol
-Rob
KoukiS14 is offline   Reply With Quote
Old 11-29-2001, 01:15 AM   #6
91CRXsiR
91CRXsiR's Avatar
91CRXsiR is making a name for him/her self91CRXsiR is making a name for him/her self91CRXsiR is making a name for him/her self
Send a message via AIM to 91CRXsiR Send a message via MSN to 91CRXsiR
e-brake drift... i havent tried that yet.. i just use downshift method...
how do u use e-brake? dont u want ur rear to keep spiinng?
91CRXsiR is offline   Reply With Quote
Old 11-29-2001, 02:17 AM   #7
misnomer
misnomer's Avatar
Getting under the center console isn't hard in an s13, s14 can't be much worse. Pull that out and make sure the cables aren't stuck
Old 11-29-2001, 05:13 AM   #8
ZeroGS14
ZeroGS14 is an unknown quantity at this point
you can always just pull out the bulb isntead of cutting the wire to it and ummm I'd say check out your brakes...maybe you heated one of them up a little to much and its sticking
ZeroGS14 is offline   Reply With Quote
Old 11-29-2001, 06:37 AM   #9
oberkill
oberkill is an unknown quantity at this point
Same thing happened to me in my Skyline in Japan and now my SR'd 240 here. Both of them had the brake light come on while I was playing and using the e-brake to slide around. I checked both systems out completly and their was nothing wrong. I have no idea why it does it but I drove the skyline for a year like that and my 240's light has been on for 10 months and counting. As a matter of fact the guy that bought my Skyline says the light is still on and he cant make it go away either.... Just check to be sure your fluid is good and your e-brake is not sticking on then put it in ignore mode..... LOL
Alan
oberkill is offline   Reply With Quote
Old 11-29-2001, 07:40 AM   #10
DSC
New Title
DSC is an unknown quantity at this point
that happened to me in my old car. my sis left the sunroof open one night that it rained and there was about 2&quot; of water on the floor the next morning (don't worry the seats soaked up most of the water befor it got to the floor). Then a light was stuck on, i'm pretty sure it was the e-brake light. #### things, you do just a little somethin bad with them and they get all pissy <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
DSC is offline   Reply With Quote
Old 11-29-2001, 10:55 AM   #11
NoTuchn
NoTuchn is an unknown quantity at this point
try adding brake fluid... mine does that from time to time, from playin with the e-brake. i just keep adding brake fluid, and itll go away for a month or so.
NoTuchn is offline   Reply With Quote
Old 11-29-2001, 03:52 PM   #12
gfisch
gfisch's Avatar
gfisch is an unknown quantity at this point
Send a message via AIM to gfisch
The only thing that would turn on that light is the little switch/button thing for the ebrake. At least from what Ive seen striping my 240, thats the only wire going to anything related to the ebrake unless there is a short in the gaurge cluster itself. Id just pull off the center console and take a look at it. Ill be its stuck, probably got pushed back to far, Maybe it got slightly bent up.
Greg
'95 SE
gfisch is offline   Reply With Quote
Old 11-29-2001, 06:29 PM   #13
Arcane
alright...thanks for the info...about the downshift method...i have an auto...it's not really practical....the e-brake is the way i learned....so it's easier for me....
Old 11-29-2001, 08:53 PM   #14
chickenmanq
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from NoTuchn on 10:55 am on Nov. 29, 2001
</td></tr></table><span id='postcolor'>
K, your brake line is a closed system, so that means something is leaking. &nbsp;I'd find it before it decides to burst one of these days.
Old 11-29-2001, 08:59 PM   #15
Arcane
(Edited by Arcane at 9<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>1 pm on Nov. 29, 2001)
