Old 11-26-2001, 09:23 AM   #1
Guest
Posts: n/a
can I get I pipe to replace my cat, but where i can put my cat back on if I move out to cali.  I'm in Oklahoma so I could get away with it.  Also how much hp might I gain with a pipe if I have catback exhuast?  Any ideas?  i know that's sort of a broad dumb question..so where can I order a testpipe?
Chance
Old 11-26-2001, 09:42 AM   #2
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
i think www.pdm-racing.com has them
http://www.pdm-racing.com/products/pdmdump.html
whateverjames is offline   Reply With Quote
Old 11-26-2001, 09:49 AM   #3
Guest
Posts: n/a
It said this.  Is this true?
NOTE ** S14 240SX owners ** (1995-1998) PDM does NOT offer a dump pipe for the S14, as the catalytic converter is located just below your exhaust manifold. S14's are OBDII, and require the use of a catalytic converter to monitor and maintain your engine's mixture. Removal of the cat will cause computer errors.
Old 11-26-2001, 10:54 AM   #4
DSC
New Title
DSC is an unknown quantity at this point
yes. From what i've heard you can get your ecu reprogramed so you can put a pipe on their but I dono who, if anybody sells them for an s14. If your set on doing it you might have to get it custom made.
DSC is offline   Reply With Quote
Old 11-26-2001, 02:49 PM   #5
Guest
Posts: n/a
shucks....stupid tree huggers.
Old 11-26-2001, 03:46 PM   #6
Impact
Impact is an unknown quantity at this point
Send a message via ICQ to Impact
Hey man.......not all of us hug trees..
Impact is offline   Reply With Quote
Old 11-26-2001, 06:27 PM   #7
vancouvers14
vancouvers14 is an unknown quantity at this point
Send a message via ICQ to vancouvers14
just hollow the cat out.  you don't need to replace it
vancouvers14 is offline   Reply With Quote
Old 11-26-2001, 06:54 PM   #8
yenpit
yenpit is an unknown quantity at this point
i think krunko is right. i dont have my car here, but if you have two O2 sensors (one ahead of, one behind cat) u'll prob trip the ECU/check engine light. not sure why this happens but figure the SECOND sensor reads within certain parameters AFTER the cat. when u change the "flow" with a pipe or punchin ur cat out it will often trip the ECU code. this happens on late OBD II hondas (ie 99-00 civic si). have u considered a hi flow cat like Magnaflow...?? u can build a pipe and replace the cat, then if it does trip the ECU put the cat back in.
if u do this im sure we'd all like to know what happens... let us know!!
yenpit is offline   Reply With Quote
Old 11-26-2001, 10:08 PM   #9
Guest
Posts: n/a
well how much HP are youg oing to see with a highflow cat?  I would think it wouldn't be anywhere near just putting in a pipe, but I wouldnt' want to put in a pipe if its going to screw up my car and make me ECU light go on.
Old 11-27-2001, 08:31 AM   #10
yenpit
late model cats are MUCH more technically advanced than 8-10yrs++ ago. they are restrictive but i would guess u'd only loose a few HP (unless urs has high miles on it cuz they do clog up!). other drawback is noise....cats quiet exhaust. if u punch or replace with pipe ur car WILL get louder, unless thats what u want.
these new hi-flow cats are less restrictive than OEM, and u can see a "few" HP gain over OEM. ya gotta weigh all this stuff!
hasnt anyone actually done this on a late 240..?? krunko, i speak from other import experience (this is my first 240, and its not on the road yet!) but most ive exp are 4cyl FI cars....very similar.
guess...remove or punch out=5-7 HP + noise, possible ECU prob. hi-flow cat=3-5 HP + legal, little chance of ECU prob.
Old 11-27-2001, 08:45 AM   #11
nismo270r
nismo270r is an unknown quantity at this point
Send a message via AIM to nismo270r
Yes there is an O2 sensor in the real catalytic convertor on an S14.  The one that is where a catback exhaust system hooks up to is not a real cat, rather just one there for looks I guess.  I've heard it was put in for visual emissions inspections, but that could just be rumor.  Either way, the fake cat has nothing much in it at all anyways.  You're real cat is right off the header, and has an O2 sensor.  So you either have to get a Random Tech cat (I don't know the part #), or just get a Hotshot header (full header, unlike Greddy SS short header) and replace the fake cat with a real universal RT, or Carsound cat or something.  That's if you're worried about emissions.  It'd probably sound better with a cat on there too.  But if you don't want to, just weld a pipe in where your fake cat is with the Hotshot header and that's the freeist flowing exhaust you can get.
nismo270r is offline   Reply With Quote
Old 11-27-2001, 09:05 AM   #12
Guest
Posts: n/a
what kind of problems with the ECU w0uld you experience without the cat...isn't there a possibility it could make your car run worse/slower?
Old 11-27-2001, 11:19 AM   #13
vancouvers14
well, the other issue is legality.  running no cat is illegal in most places.  plus, if you have a catback, it will get obscenely loud.  i set off probably one car alarm a week, with my exhaust.  i couldn't imagine it getting louder
Old 11-27-2001, 12:24 PM   #14
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
I agree that removal of the cat will lead to a CEL/code.  Yes, this will cause you engine to go into a "safe mode" which will make it run like dookie.  I also 100% agree with yenpit's statement that the science of cats has improved so that you are not going to see huge gains by removing it or upgrading to a high-flow unit.  Some - but not huge.  If you are making huge power or using an engine/header that is not designed to have a cat that may be another story - but for basic bolt ons, I've not seen straight pipes give huge gains like people would like to believe.
The cons are sound and pollution. &nbsp;I'm no tree hugger, but having my car smell like a '71 Catalina is not high on my list of mods <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=';)'> &nbsp;For the money, I think there are other mods that would give you more power with fewer drawbacks.
BTW: after having this debate about 16 times, I believe that most '95s are OBD I with a single, pre-cat o2.
HippoSleek is offline   Reply With Quote
