Old 10-21-2008, 05:11 PM   #1
Mikevar82
Mikevar82 is an unknown quantity at this point
92 Twin Turbo 300zx Excellent condition<< wont find a better deal>>>
I have 1992 Black clean titled twinturbo that i purchased about a year ago from a member on tt.net that was moving away. The car had a rebuilt motor with lots new parts i.e. new O2 sensors, new fuel damper and regulator, new wiring harness, new det sensor etc... The motor was not built very well so I purchased a good jspec 5 speed motor and a set of low millage turbos and began putting it back together. The motor was completely stripped to the long block and everything was replaced and completly cleaned.
Motor
replaced oil pan and pickup tube
Removed EGR parts
New timing belt sprocket
New OEM timing belt
All new oil seals front and rear
Valve covers sandblasted,cleaned, painted and cleared
Low millage water pump, timing tensioner and pullies( less then 10K)
Cleaned and sand blasted water pipes
Injectors cleaned & flow tested w/new orings & insulators
turbos off a 95 with 48K original miles
All turbo oil lines cleaned before install
Timing belt covers painted+cleared (black)
New upper plenum gasket
Balance tube painted and cleared
Upper plenum cleaned and sandblasted
Front water pipes cleaned and sandblasted
ALL water lines replaced with new lines and re- routed
ALL fuel line replaced with New fuel injection Good Year fuel lines
New OEM fuel filter
ALL Vacum line replaced with good and new silcon lines
flywheel resurfaced to spec
Brand New RPS street clutch
New OEM oil filter
New OEM spark plugs
New OEM water bypass hoses
New OEM theromstat
New Battery
Body 164K
The car sits on a low millage set of KYB eibach adjustable suspension (less than 10K).
Brembo sloted and cross drilled rotors with SS brake lines.
Stillen short throw shifter
Split down pipes with test pipes and HKS hiper exhuast.
The body is rust free and has great original paint with the exception of the rear wing being rotted and the front bumper was showing some cracking. i have since replaced the wing with a good used one and had the front bumper repainted.
set of stock TT wheels that have been cleaned
A top speed hicas eliminator w/ Z1 hicas fitting.
suede is in good condition.
the leather on the seats is good but the seems have popped on the bottom pieces.
Asking price is now $7000 OR BEST OFFER, no trades. Car drives great. compression numbers are good and within spec. Jspec motor has less than 60K! and CLEAN CARFAX!
Notes:
Replace power steering hose w/ z1 rebuilt unit
Installed manual boost controller (9 psi)
Replaced trans fluid w/ Redline MT-90
Installed Auto meter boost gage pod
For more pictures
Link deleted
Last edited by racerx2k1; 10-30-2008 at 03:12 PM.. Reason: No links allowed. Post pics here.
Mikevar82 is offline   Reply With Quote
Old 10-21-2008, 06:07 PM   #2
BRAIN_Z33
BRAIN_Z33's Avatar
BRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfection
clean Z man
A buddy of mine is lookin for one, i will let him know....
BRAIN_Z33 is offline   Reply With Quote
Old 10-30-2008, 11:24 AM   #3
Mikevar82
$6500 or best offer!
Old 10-30-2008, 12:59 PM   #4
Nimso
Nimso's Avatar
Nimso has much to be proud ofNimso has much to be proud ofNimso has much to be proud ofNimso has much to be proud ofNimso has much to be proud ofNimso has much to be proud ofNimso has much to be proud ofNimso has much to be proud ofNimso has much to be proud ofNimso has much to be proud ofNimso has much to be proud of
thats a great deal.. very clean z man... glws
Nimso is offline   Reply With Quote
Old 11-06-2008, 09:11 AM   #5
Mikevar82
Still Available
