Old 12-17-2008, 02:23 PM   #1
MissShiftS13
MissShiftS13's Avatar
MissShiftS13 is an unknown quantity at this point
Send a message via AIM to MissShiftS13
Header is glowing red hot!!!!!
Does any1 know why my friends stock header on his ka single cam glows red hot after driving it? My advice to him is to junk it already, i mean sad but god damn there's something wrong with it every other week. Well anyways if you guys have any suggestions on why this would be happening help me help out a friend.
MissShiftS13 is offline   Reply With Quote
Old 12-17-2008, 02:27 PM   #2
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
That's normal. Headers get really hot when you drive the car HARD. Now if they glow everytime you drive it you may be running lean, which is not good.
Old 12-17-2008, 02:55 PM   #3
MissShiftS13
Well the car does tend to sputter sometimes, could it be that his injectors might be out?
Old 12-17-2008, 04:37 PM   #4
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
If its glowing hot its either a restricted cat (s14) or it almost seems like its running rich.
The sputtering would too many things.
Bigsyke is offline   Reply With Quote
Old 12-17-2008, 04:39 PM   #5
racepar1
racepar1's Avatar
A rich condition will NOT cause excessive exhaust heat.
Old 12-17-2008, 04:52 PM   #6
Bigsyke
Bigsyke's Avatar
Are you sure? I said S14, which means the cat is IN the exhaust manifold, and excess fuel on the catalyst would melt/damage the unit causing the the manifold to over heat.
Old 12-17-2008, 04:53 PM   #7
aznpoopy
aznpoopy's Avatar
not that i've experienced it, but i've heard of rich condition causing still burning mixture to escape into the header on domestics, causing it to glow red
Old 12-17-2008, 05:37 PM   #8
smelly240
smelly240's Avatar
^^mr knowitall again... greeeaaaat.
a rich condition CAN cause excessive heat.
the distributor could have moved - retarded timing makes that shit glow like that.
or the cat clogged/piping kinked off. i actually seen a muffler innerwall material melt down in front of the stream and cause it.
injector issue, etc.
I would start at the timing.
My SR glows red in the dark the mani and turbine sometimes do... I was tuning a gtir swapped sentra last week and that car had the o2 glowing bc the fellas crank pully rotated and the timing marks were off and he didnt know any better. came over and that shit was RED - i was like so yeah... we're gonna need a ruler, a screwdriver and a plug wrench - i set that bitch to TDC according to my screwdriver, measured the 20 marks distance to the stock tdc mark - marked from the pin over, and set that sucker to "Steve's 20 deg"
hooked up my knockometer, lm1, and ostriches, and did er up.
shit runs its balls off now.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
Old 12-17-2008, 02:31 PM   #9
aznpoopy
aznpoopy's Avatar
lean condition, or maybe a clogged cat / crushed piping?
Old 12-17-2008, 04:43 PM   #10
g6civcx
g6civcx's Avatar
Ideally, you would stick an EGT probe in there and measure exhaust temp.
Old 12-17-2008, 04:48 PM   #11
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
richen it up. move the dist and see if you get a better idle.
but headers do turn red after a "hard" run.
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 12-17-2008, 04:57 PM   #12
LongGrain
LongGrain's Avatar
ive never seen a stock header on a 240 glow red from running too hard. something is definitely wrong.
LongGrain is offline   Reply With Quote
Old 12-17-2008, 04:52 PM   #13
MissShiftS13
Well this is a daily driven car not really a car that gets run hard, it can be a short trip and the headers will get red hot.... so he might be leaning out the motor right? And if the injectors are bad wouldn't it cause it to sputter?
Old 12-17-2008, 04:57 PM   #14
MissShiftS13
well its an s13 fastback.... this care has had issues since the moment he bought it. He had the cat and exhaust checked out and theres no type of blockage or anything like that.
Old 12-17-2008, 05:01 PM   #15
MissShiftS13
my suggestion was dump the ka and get an sr or a ca but he wants to keep fixing it. Ive never even seen my sr glow red.
Old 12-17-2008, 11:35 PM   #16
SlideWell
SlideWell's Avatar
SlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfection
sawwweeeeeet. take pics.
SlideWell is offline   Reply With Quote
Old 12-17-2008, 11:40 PM   #17
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Yes.
And buy a clear hood.
Old 12-18-2008, 09:13 AM   #18
MissShiftS13
You know what he's out of town right now but he should be back by tomorrow or no later than saturday, i should take pics and post im yet to even see it he just told me about it.
Yes.
Old 12-18-2008, 09:34 AM   #19
S14DB
AFC #1
S14DB's Avatar
Header/Manifold glowing is usually fuel burning in the manifold.
Check the Timing first. Usually the case is the ignition timing has retarded to the point were combustion is not completed and hot burning fuel is sprayed into the manifold. Then it finishes burning in the manifold cooking it.
Rich/Lean condition will cook other components before the manifold starts to get hot enough to glow after shut down. But he has said there is other problems.
1) Check the Base Timing.
2) Inspect the spark plugs. Read them for color and deposits.
Old 12-19-2008, 04:50 AM   #20
smelly240
smelly240's Avatar
thx i already said all that -- lol
Old 12-19-2008, 06:32 AM   #21
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
put some heatshielding on yoru brake fluid reservior before you lose control of your brakes and go spiraling into an elf.
clark is offline   Reply With Quote
Old 12-19-2008, 03:49 AM   #22
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
Yeah, I used to have a bad tune and it ran rich and my manifold was glowing red.
Do what he said^^^
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 12-19-2008, 04:22 AM   #23
240KA
240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice
how does he know its actually glowing red? was the car on a dyno? was the car jacked up, set on stands and revved out? lol
a header doesnt glow red "after" a hard run. it glows red during a hard run.
240KA is offline   Reply With Quote
Old 12-19-2008, 07:27 AM   #24
smelly240
smelly240's Avatar
if you get out and look after a run - its still red.
Old 12-19-2008, 07:48 AM   #25
S14DB
AFC #1
S14DB's Avatar
Under normal conditions yes. But, when you have gas burning in the manifold it is like having a blow torch on it for the run time and it glows for a long time.
It's also one of the 2 big reasons why some people can run the cheapest manifold on ebay and never crack it and another can run the most expensive one or a stock manifold and crack it in a month.
Old 12-19-2008, 09:59 AM   #26
MissShiftS13
It was still glowing when he popped the hood after he got home, not sure but i would think he left the car running and popped the hood cus he noticed something was up.
Old 12-19-2008, 08:07 AM   #27
Jonnie Fraz
Jonnie Fraz's Avatar
Trader Rating: (29)
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Feedback Score: 29 reviews
Send a message via AIM to Jonnie Fraz
Ok do the simple shit first. Like others have said: spark plugs and timing.
Then if that does not work you might try getting your injectors rebuild. I had mine done for about $100.00 for all four. Make sure if you do that they use OEM seals! All the after market seal kits that I have found for the Nissan SOHC injectors are a hair too small and they leak.
I found that when I did mine the car rans so much better. Better mileage, ran way smoother, and almost passed smog. All four were leaking is what the tech said.
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 12-20-2008, 08:04 PM   #28
Rapier46
Rapier46's Avatar
Rapier46 is an unknown quantity at this point
Send a message via AIM to Rapier46
it's so cold it freezes, that's the red. grab it with your hand to warm it up.
Rapier46 is offline   Reply With Quote
Old 12-20-2008, 08:08 PM   #29
neverrain
neverrain's Avatar
neverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud ofneverrain has much to be proud of
Being a moron won't get you respect here.
neverrain is offline   Reply With Quote
Old 12-20-2008, 08:33 PM   #30
Bigsyke
Bigsyke's Avatar
a KS code can make your header glow red.
