Old 03-24-2003, 03:59 PM   #1
Fibercus
Fibercus is on a distinguished road
Send a message via AIM to Fibercus
Just got a free CT26 Turbo (and 3sgte engine lol) Trying to build budget turbo
My best friend has had this 3sgte MR2 motor in his garage for about 3 years now. I was qurious what kind of turbo it had, I did some research on the CT26 and turns out I found a couple people with it in there KA's. His brother no longer cares about / wants it (drives an s2000 now) so I can have it.
Pics of the CT26 removed (havent removed the 3sgte mani. yet)
I wanted to know if my understanding of what is needed to have this turbo up and running at stock or below stock boost (4-8psi) is correct (for a budget turbo kit):
Using the stock SR side mount + Piping + BOV. 1 / 2 bills?
Obtaining and inlet adapter (converts CT26 to standard t3) $60 SO AWESOME they make it... no need to custom weld a mani.
Turbo Manifold (cheapest I can find) hopfully around 250-300
Custom Up-pipe (I think, might be downpipe... still learning) ??
Then cooling sys. (oil / water already have stock MR2 looking to fabricate onto KA)
What else would I need? Again Im not looking for big boost, just whatever I can get by with, without having to change my fuel pump / injectors / ECU upgrade... unless these ARE needed. I have done some research on boards and google and am planning on hitting Barnes and Nobles for a couple good text mentioned in the forums.
Any help is much appreciated
Fibercus is offline   Reply With Quote
Old 03-24-2003, 04:03 PM   #2
fogleroller
fogleroller's Avatar
fogleroller is an unknown quantity at this point
LOL, is that guys brother named Min?
Here is a pic I found here on Zilvia. "240racer" owns the car.
I wanted to do it also, but I changed my mind.
fogleroller is offline   Reply With Quote
Old 03-24-2003, 04:11 PM   #3
Fibercus
No on the name part, and yep I am familiar with that pic... it was the first setup I found during my search thru the forums. That setup belongs to '240RACER' hes got a site
http://www.geocities.com/nord0306/240sxturbo.html
When I first saw all that welding I got intimidated.. then while I was trolling I cam across this:
http://www.jgstools.com/turbo/ct26adp.html
Basically converts the CT26 flange ( i think its called) to a standard T3 one, allowing me to use any turbo manifold (revhard, etc...) and its 59.99.
Old 03-24-2003, 04:47 PM   #4
fogleroller
looking good so far, I can't wait to see the outcome.
Old 03-24-2003, 06:03 PM   #5
240racer
240racer's Avatar
240racer is an unknown quantity at this point
Hey nice turbo, looks a lot like mine. There are two problems with using a CT-26 turbo, one, it's not clocked correctly, since the toyota engines have the exhaust on the other side and two, the flange is not typical which requires some type of custom work on the manifold.
You can see what I did about both of those problems in that picture that was posted.
I like the turbo, I think it's a very good size for a moderate boosting car. I wouldn't want to go much higher then 15psi with it. I ran it at 7psi which is stock for the wastegate, and it worked great.
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
'88 Celica All-Trac turbo
stock, but no more ecu codes!!
240racer is offline   Reply With Quote
Old 03-25-2003, 01:52 AM   #6
Fibercus
Originally posted by 240racer
... and two, the flange is not typical which requires some type of custom work on the manifold.
Is there anything that I am missing for the entire setup? (minus gauges)? I am planning on using an adapter to convert it to standard t3 and fit it onto any aftermarket turbo manifold... would that not work because of the timing and such? Wondering if I have to mount it the same exact way as yours in order for it to function. BTW 7Psi would be a dream for me... id be happy with 4 lol.
Thanks for the posts =]
Old 03-26-2003, 04:10 PM   #7
240racer
240racer's Avatar
you will just have to see if you can clock the turbo or not. My friend who drives supras and celicas with this turbo did not think it was a good idea to try and clock the turbo. The OEM turbos aren't as good at adjustability as a aftermarket one. if you look at the turbo on your car, you will notice that if you point the exhaust flange at the engine, the exhaust exit is pointed towards the front of the car. remember, the oil drain has to be on the bottom for it to work properly. that's the real pain, it isn't the way the inlets and outlets point, it's making the oil drain on the bottom while having the exhaust point in a good direction (towards the back) I don't think you will be able to use a regular manifold at all, even with an adapter. If you can clock it, then you might be able to, but I didn't even try since I was welding my own manifold anyway, it seemed easier to weld a odd looking manifold then possibly wreck the turbo trying to clock it and welding a regular looking manifold.
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
