Old 05-21-2009, 02:14 PM   #1
MissShiftS13
MissShiftS13's Avatar
MissShiftS13 is an unknown quantity at this point
Send a message via AIM to MissShiftS13
Smog question!!!! HELP!!!!
Ok so my car failed smog and it says on the paper that my car is a gross polluter. I wasnt told why it didnt pass other than its running rich and on my paper it says... This vehicle failed the ignition timing check due to engine rpm being out of tolerance.... any1 know what the heck that means and what i can do to fix it.
MissShiftS13 is offline   Reply With Quote
Old 05-21-2009, 02:18 PM   #2
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
you have to set timing properly at the distributor
R@ddy is offline   Reply With Quote
Old 05-21-2009, 02:20 PM   #3
MissShiftS13
Is it costly???
Old 05-21-2009, 02:49 PM   #4
nastjuid
nastjuid has a spectacular aura aboutnastjuid has a spectacular aura aboutnastjuid has a spectacular aura aboutnastjuid has a spectacular aura aboutnastjuid has a spectacular aura aboutnastjuid has a spectacular aura about
Not typically... A friend with the right tools should be able to help, but a diagnosis should be done. What does your car idle at? What engine is it?
nastjuid is offline   Reply With Quote
Old 05-21-2009, 03:05 PM   #5
MissShiftS13
Well i know this is a nissan forum and i just got rid of my s13 and i have an mr2 with a usdm 3sgte? the car idles fine though i think just under 1
Old 05-22-2009, 09:37 PM   #6
gijoe69
gijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant future
Send a message via AIM to gijoe69
to pass smog; Get a major tune up > Cap & Rotor, spark plugs, plug wires, upstream oxygen sensor (replace to fix running rich), adjust timing to stock, get a new catalytic converter and exhaust piping, inspect and replace any cracked leaking fuel hoses; run seafoam to thru brake vac line to reduce HC levels.. after u do all that you should be able to pass smog
gijoe69 is offline   Reply With Quote
Old 05-22-2009, 10:55 PM   #7
Slammed Assassin
Slammed Assassin's Avatar
Trader Rating: (34)
Slammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud of
Feedback Score: 34 reviews
Send a message via AIM to Slammed Assassin
also clean up the egr and make sure to replace any cracked hoses on the back of the motor..
Slammed Assassin is offline   Reply With Quote
Old 05-23-2009, 04:34 AM   #8
sidedrifts13
sidedrifts13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
or if you have $150 i know a place that will pass your car no matter how rich it runs or what swap you have on it???????????
sidedrifts13 is offline   Reply With Quote
Old 05-24-2009, 09:41 AM   #9
MissShiftS13
The car is a factory turbo not illegally swapped. Egr valves can be cleaned out? with what?
