Old 04-07-2003, 09:52 PM   #1
formeRiceR
formeRiceR is an unknown quantity at this point
KA noob Q's about KA damage...
1, What are the common reasons for KA's blowing up?
and
2, What causes the rods and pistons to break?
"Street racers don't need girls." -Lonely Driver
Learning about cars one FLAME at a time ... (thanks to TNORD)
formeRiceR is offline   Reply With Quote
Old 04-08-2003, 02:17 AM   #2
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
Re: noob Q's about KA damage...
[QUOTE]Originally posted by formeRiceR
[B]1, What are the common reasons for KA's blowing up?[quote][b]
Oil starvation or boost spikes are the most common reasons I've seen people pulling KA's out.
Pistons break from detonation, heat, or foreign object damage like hitting valves or something. Rods break from running on an oil starved bearing and warping from frictional heat.
Really, there are TONS of reasons for engine failure. Most common I've seen on SR's: over-revving.
AceInHole is offline   Reply With Quote
Old 04-08-2003, 02:26 AM   #3
apexL8
apexL8 is an unknown quantity at this point
they break from:
1) me using a drillpress to make a hole in the piston
2) using the rod as a device to hammer out steering knuckle bolts
3) jamming the gearbox into 1st at 100mph will likely result in something blowing up
can you please ask a more general question? probably not. how about some circumstances.......such as:
what makes X part bust under X lbs of boost, or X RPM's
:::dissapears into the night only to return upon request of certain individuals:::
apexL8 is offline   Reply With Quote
Old 04-08-2003, 05:52 PM   #4
240Stilo
Junkie
240Stilo's Avatar
240Stilo is an unknown quantity at this point
Send a message via AIM to 240Stilo
That really doesn't help too much either due to the whole thing with different psi on different turbos making different CFM's. And he didn't even mention turbos so that's another thing that he could fix about his question. But Ace pretty much has this one answered. But, now I'm wondering how high people were revving in their SR's and to be more exact was it all up in the redline? (Need knowledge on SR revving capabilities)
-Juan
240Stilo is offline   Reply With Quote
Old 04-08-2003, 06:01 PM   #5
AceInHole
Autox Technician
AceInHole's Avatar
The max anyone has revved an SR, i'm told, is 11k without breaking something. This supposedly includes the big name companies. Stock SR's start to fall apart above 8000RPM I think, when the rocker arms snap, hopefully shutting the valves preventing damage to the valve or piston. One person said that it was a built in "safety feature" on SR's, although I do know one person that over-revved his SR with a bad downshift and damaged his valves/ pistons before half the rocker arms broke (possibly from the valve piston contact).
Old 04-09-2003, 01:16 AM   #6
thx247
thx247 is an unknown quantity at this point
seems alot of people lose the engines from oil problems, driver error, and over boosting with crap equpiment/setup
thx247 is offline   Reply With Quote
