Old 06-16-2009, 10:56 PM   #1
dongoesby
dongoesby's Avatar
dongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of light
RAS installation broken bolt/stud
So I broken one of these while torquing the bolt/studs.
I know I used a wrong torque wrench that is can not work on a small amount of torque. I'd like to know if KA24DE is using the same stud size so I could get one from the dealer quick. Thanks.
dongoesby is offline   Reply With Quote
Old 06-16-2009, 11:11 PM   #2
Teambadrun
Teambadrun's Avatar
Teambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to all
gernally tighten them to around 10-12ft lbs or so or just "wrist" tight with a 3/8" drive
you can get them bolts from nissan
but good luck getting the broken "stud" out
you can do this with the correct tooling however.... have fun
Teambadrun is offline   Reply With Quote
Old 06-16-2009, 11:19 PM   #3
dongoesby
dongoesby's Avatar
The correct torque sequence is from ~4 to 6 to 8.7 ft/pound
The bolts were alright when I mistakenly torqued them to ~12 ft/pound, but the first one broke when I decided to re-do them. My torque wrench just gave up on me (I was feeling weird howcome the torque wrench won't click after so many turns).
So local Nissans sell studs for SR20 too? Or it is the same size and length as the ones used in KA?
Old 06-17-2009, 07:39 AM   #4
Def
No idea why people bother trying to torque those studs when the average person doesn't have a wrench capable of reading accurately that low.
Just get a small 1/4" drive rachet and use 5-10 lbs of pressure with a finger or two on the rachet at varying distances on the handle to get a pretty good estimation of the torque.
DEFSPORT
Old 06-17-2009, 09:41 AM   #5
teamsprock
teamsprock's Avatar
teamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the rough
These are probably the most common bolt to break on an SR. Did you get it out yet? They usually come out really easy, I just run a small screwdriver in a circle on the top and they will usually spin back out. The best advice I can give you is to change these all out to studs. You can buy kits to do it or just go buy studs and nuts from ACE. I still run the stock bolts because I have a pile of them but if I have one break again I'm changing to studs.
And as Def said at that low of Tq your better off with just hand tightening it unless you have a really nice Tq wrench.
teamsprock is offline   Reply With Quote
Old 06-17-2009, 09:59 AM   #6
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
THE KA24DE USES THE SAME CAM CAP BOLTS AS THE SR
why is everyone being a dick to him? yeah he snapped a bolt, we all fucking snapepd a bolt.
i did the same thing dude. and i got one from the KA. the KA24DE engine uses the SAME EXACT cam cap bolt (it's a bolt, but you called it a stud).
i suggest you replace them ALL. the metal was so fatigued on all of mine i replaced them all.
clark is offline   Reply With Quote
Old 06-17-2009, 10:05 AM   #7
Homer_Simpson
Homer_Simpson's Avatar
Homer_Simpson is on the path to ruinHomer_Simpson is on the path to ruinHomer_Simpson is on the path to ruin
Go to the dealship like the guys above stated. Snapping those bolts is one of my worse fear when working on the engine. If you're balling, get a set of studs from NAPREC!
Homer_Simpson is offline   Reply With Quote
Old 06-17-2009, 06:31 PM   #8
dongoesby
dongoesby's Avatar
thanks guys for the well advices.
So i went to Nissans today and ordered the bolts, luckily, I am confrimed that KA uses the same bolts. If it turns out to be not, I will try if the sentra SR will work.
However, before i get to use the bolt extractor, I've been drilling the hole for 3 hours.
I went to ACE four times already, changing drill bits from general use to hard metal drill bit and changing drill from dremel to 7amp power drill. I'm using 5/64 drill bit as well as 5/64 bolt extractor. BUT the metal of the bolt is just SOOOO hard, the dremel could only get me 1~2mm in for 1 hour straight drilling. I'm now changing to 7amp power drill with hard metal drill bit. I hope I can make this work.
Please post if everything looks right so far I'm doing.
Old 06-17-2009, 06:45 PM   #9
JVD
JVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfection
You shouldn't need to drill very deep at all. Usually just a couple mm and then use one of those hammer in bolt extractors.
Mine basically spun out by hand.
JVD is offline   Reply With Quote
Old 06-17-2009, 09:54 PM   #10
dongoesby
dongoesby's Avatar
It is out!!
tools:
7amp drill DeWalkt DWD112
5/64 hard metal drill bit
5/64 bolt extractor
tips: drill with a cold drill bit otherwise it will snap.
http://zilvia.net/f/tech-talk/184013...-helicoil.html
now, I'm going to hand tighten the bolts or get a really fancy torque wrench!
thanks clark for your help over pm
