Old 07-10-2009, 02:11 AM   #1
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
sr20det swap lower harness question
Ive done my research and never found the answer for my question.
as far i read that when u do a swap from s13 to s13 u can use sr lower harness without splicing it will work.
on ka harness has like 4 plugs around the fuse box.
3 on the side and 1 on undearneath.
then i plugged my sr harness it plugs in with those 3 connectors on the side but it is missing the plug from underneath the fuse box.
im already wonderin that plug needs to be connected somwhere but i dont know what should i do with it.
some says u need to splice the transmission clips from sr to ka with their corresponding color match. but im not sure so any help would be appreciated. im currently stuck with this.
thanks
Old 07-10-2009, 01:14 PM   #2
brian3676
brian3676 is an unknown quantity at this point
just use your stock KA one, Take all the sensors out of the KA tranny and take swap then out with the SR tranny sensors then use KA, everything plugs right in
brian3676 is offline   Reply With Quote
Old 07-10-2009, 01:34 PM   #3
wangan_cruiser
kouki man
Trader Rating: (36)
which one to splice?
can u tell me
Old 07-10-2009, 02:03 PM   #4
johngriff
johngriff's Avatar
LENGTH will help you to determine where to splice them in.
Its just the 4th 5th and reverse lights. You can wire them backwards and it will be fine.
At the end of the day all you need is the reverse sensor anyways, so just do that one.
[email protected]
Old 07-10-2009, 03:19 PM   #5
projectRDM
projectRDM's Avatar
All you need is VSS and reverse. And if you don't care about reverse lights you don't even need it.
We've talked about this what, for over a decade?
FORMERLY R240NA
Old 07-10-2009, 06:38 PM   #6
fast-datsun
fast-datsun is an unknown quantity at this point
Just use the KA harness and switch the SR sensors for the KA sensors you your done
fast-datsun is offline   Reply With Quote
