Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Group Buys
Group Buys Dedicated Forum for Group Buys.
Old 07-20-2009, 12:24 PM   #1
Fatboy Garage
Fatboy Garage's Avatar
Fatboy Garage is an unknown quantity at this point
Send a message via MSN to Fatboy Garage
Thumbs up Godspeed Power GB Page!! Turbo,Exhaust,Down Pipe,turbo manifold and MORE!!!
Godspeed Power Parts Group Buy!
Everything in stock and READY to SHIP AND PICK UP!!!
Turbo is the BEST!!
Nissan 240SX 89-90 KA24 (S13) Single Cam (KA24E) T3T4 Complete Turbo Kit
-T3T4 Turbo Charger .63ar
-KA24E Stainless Top Mount Manifold
-Aluminum Pre-Bent intercooler Pipe, With Clampes & Silicone
-3" Staninless Turbo Uppipe
-3"Stainles Turbo Downpipe
-Godspeed 38 Wastegate (7PSI)
-Oil Feel Line, Oil Return Line With All Fittings
-Type RS Blow Off Valve
NISSAN 240SX 91-94 KA24 (KA24DE) DUAL CAM MOTOR T3T4 COMPLETE TURBO CHARGER KIT
-KA24DE Stainless Top Mount Manifold
TD04-H T25 TURBO CHARGER
Turbo spec.
Intake in: 37.8 ex: 59.7
Exhaust in: 45.47 ex: 52.9
Internal Wastegate Set at 8PSI
Start Spooling At 2500RPM
GODSPEED 38MM GT-SERIES 38MM WASTEGATE (universal)
- comes with 7psi waste gate spring ( fully adjustable )
- dual port. accurate boost
- ultra durable diagram (diaphram)
- comes with all the hardware (bolts, gasket etc)
- accurate boost pressure
- high quality appearance
- 1 year warranty ( if installed by professional)
- comes with additional 11 psi, 15 psi springs
this wastegate is only 4.35" tall. very compact especially good for customer working with small / tight engine compartment.
GODSPEED GT-SERIES 44 MM V BAND DUAL SPRING WASTEGATE (universal)
-comes with 15psi waste gate spring ( fully adjustable from 10- 15 psi ) and extra 14psi spring ( if you add both spring that makes it 29 psi total )
-accurate boost pressure , prevent over boosting.
-high quality aluminum die-cast body
-ultra durable high temperature diaphragm
-comes with all the hardware ( v band, clamps and etc)
-stainless steel valve
-high quality appearance.
-1 year warranty ( if installed by professional)
GODSPEED GT-SERIES 50 MM V BAND DUAL SPRING WASTEGATE (universal)
-comes with 20psi waste gate spring ( fully adjustable from 15-20 psi ) and extra 7.5 psi spring ( if you add both spring that makes it around 27 psi total )
-ultra durable diagram (diaphram)
GODSPEED GT-SERIES 60 MM V BAND DUAL SPRING WASTEGATE (universal)
-comes with 24psi waste gate spring ( fully adjustable from 15-24 psi ) and extra 7.5 psi spring ( if you add both spring that makes it around 30 psi total )
Nissan S13 SR20DET Intake Manifold
Three Style available Cast, Polished, Chromed
Cast
Polished
Chromed
S13 S14 240SX Top Mount T3 Turbo Manifold ( sr20det motor )
- T3 Turbo Flange. FIT T3 AND T3T4 HYBRID TURBO
- 35MM or 38MM external wastegate flange
- SUS321 stainless steel
S13 S14 240SX SR20DET T3 Top Mount Cast Turbo Manifold
- extremely strong casting
- fits sr20det motor (s13, s14 ,s15)
- 38mm wastegate flange ( will fit 35mm or 38mm wastegate)
- t3 flange. fit all t3 or t3t4 hybrid turbo
- life time warranty
SR20 TOP MOUNT MANIFOLD + 3" STAINLESS DOWNPIPE + WASTEGATE DUMP TUBE
-FITS : TOP MOUNT T3 OR T3T4 TURBO CHARGER
-extremely strong stainless steel
-equal length for quick throttle response
-3" 5 bolt standard flange turbo downpipe
-T3 turbo flange
-38mm wastegate flange
-able to retain A/C power steering
-fully TIG welded
-Fully ported and polished
-includes all gaskets
-1 year warranty
S13 S14 240SX top mount t3 turbo manifold ( KA24DE motor )
- T3 Turbo Flange
- Fully TIG welded
- Fully Ported and Polished
- Includes bolts and gaskets
KA24DE(dual cam) T3 or T3T4 or T4 Top or Bottom Mount Cast Turbo Manifold
- 91-94, 95-98 Nissan 240sx KA24DE (Dual Cam)
- 93-01 Nissan Altima
- Extremely Strong Casting
- 35MM or 38MM External Wastegate Flange
- T3 or T4 Flange
Nissan 180SX (CA18DET Only) T25 Bottom Mount Turbo Manifold
Nissan S13 S14 KA24DE(Duel Cam Only) T25 Bottom Mount Turbo Manifold
Nissan S13 S14 SR20DET T25 Bottom Mount Turbo Manifold
Nissan S13 S14 SR20DET Turbo Downpipe
Nissan S13 89-94 & S14 95-98 SR20DET Catback Exhaust
Nissan S13 89-94 SR20DET Carbon Catback Exhaust
Nissan S13 & S14 SR20DET Fuel Rail
Nissan S13 SR20DET Engine Damper
For RB25 Swap!!
RB25 Intake Manifold
Three Style Available Cast, Polished , Chromed
Cast
Polished
Chromed
RB25 Fuel Rail
Fit 10.5 to 11 mm feed injectors
PM US or CALL US For Better Pricing!!!
Let Us Know You are From Zilvia.net for Best Discount!!!!
We are S13/S14 Specialist, if you cant find what you need check out our website GodSpeed Project - Intercooler, Turbo Kits, Turbo Manifold, Body Kit or give us a call if you have any question!!
We also have other GB on the forum, so please check them out!!!
Ken @ Fatboy Garage Motorsport
11135 Rush St Unit B
South El Monte CA 91733
626-442-3988
Fatboy Garage is offline   Reply With Quote
Old 07-24-2009, 03:10 PM   #2
Grenade180sx
Grenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfection
Send a message via AIM to Grenade180sx
i need a catback exhaust for s13. something similar to the megan type 2. u got anything?
Grenade180sx is offline   Reply With Quote
Old 07-28-2009, 10:06 AM   #3
Fatboy Garage
Sorry we dont
Thanks
Ken,S
Old 07-24-2009, 03:27 PM   #4
stunnaben
stunnaben is an unknown quantity at this point
best price on a s14 exhaust shipped to 27603
stunnaben is offline   Reply With Quote
Old 07-30-2009, 12:48 PM   #5
florante rea
florante rea's Avatar
Trader Rating: (43)
florante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of light
Feedback Score: 43 reviews
Send a message via AIM to florante rea Send a message via Yahoo to florante rea
any warranty on sr topmount manifold?
fdrea
florante rea is offline   Reply With Quote
Old 07-30-2009, 04:54 PM   #6
Fatboy Garage
Cast are life time warranty
Thanks
Ken,S
Old 07-30-2009, 04:20 PM   #7
wisdom01
wisdom01 is on a distinguished road
how much for the ka24de turbo kit shipped to 96816?
wisdom01 is offline   Reply With Quote
Old 07-30-2009, 07:31 PM   #8
florante rea
Trader Rating: (43)
sorry i was referring to the tubular top mount mani, not the cast.
fdrea
Old 08-04-2009, 10:47 AM   #9
allntrlundrgrnd
allntrlundrgrnd's Avatar
single slammer turbo kit to 21146
Old 08-04-2009, 12:14 PM   #10
lewisfk
lewisfk's Avatar
lewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond repute
were the hell is your products made? how much research and development goes into your products? godspeed!!!
lewisfk is offline   Reply With Quote
Old 08-04-2009, 01:53 PM   #11
allntrlundrgrnd
who makes the turbo?
Old 08-04-2009, 04:17 PM   #12
Fatboy Garage
they are made by godspeed
Old 08-04-2009, 04:21 PM   #13
burninskulls0911
burninskulls0911 will become famous soon enoughburninskulls0911 will become famous soon enoughburninskulls0911 will become famous soon enoughburninskulls0911 will become famous soon enoughburninskulls0911 will become famous soon enough
polished s13 sr intake mani
burninskulls0911 is offline   Reply With Quote
Old 08-05-2009, 01:10 PM   #14
shmiddy
shmiddy's Avatar
im looking for a top mount manifold... which do you recomend???? log or tubular?? pm me the price. i need a good STRONG ONE PLEASE LMK ASAP
i fully de-volved
Old 08-06-2009, 01:38 PM   #15
Fatboy Garage
Check out our site
Old 08-10-2009, 07:49 PM   #16
kbui
kbui's Avatar
kbui is an unknown quantity at this point
so what's the zilvia special pricing for the sr cast manifold?
kbui is offline   Reply With Quote
Old 08-17-2009, 10:49 AM   #17
FusionR240sx
FusionR240sx's Avatar
FusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond repute
Send a message via AIM to FusionR240sx
price for sr downpipe shipped to 60018
Originally Posted by Wreckless35 View Post
still be flush dropped on KYB AGX struts & s-tech springs
WUT?
FusionR240sx is offline   Reply With Quote
Old 08-23-2009, 07:03 PM   #18
d0pe240
d0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of light
how much for the exhaust shipped to 28209?
d0pe240 is offline   Reply With Quote
Old 08-24-2009, 03:11 PM   #19
Fatboy Garage
ALL Pm Replied
Old 08-24-2009, 06:18 PM   #20
Fatboy Garage
Bump Bump Bump
we have End of the month special
Please PM for pricing
Old 08-25-2009, 06:52 PM   #21
Fatboy Garage
Bump Bump Bump
Old 08-25-2009, 07:26 PM   #22
d0pe240
does the exhaust hang low to the ground?
Old 08-26-2009, 11:43 AM   #23
Fatboy Garage
Nope is look like stock height
Old 08-26-2009, 01:03 PM   #24
pondmotorz
pondmotorz has a spectacular aura aboutpondmotorz has a spectacular aura aboutpondmotorz has a spectacular aura aboutpondmotorz has a spectacular aura aboutpondmotorz has a spectacular aura aboutpondmotorz has a spectacular aura about
cat back shipped to 91402 please
pondmotorz is offline   Reply With Quote
Old 08-30-2009, 10:54 PM   #25
FusionR240sx
ka24de s13 turbo kit shipped to 60018
WUT?
Old 08-31-2009, 10:37 AM   #26
Fatboy Garage
Bump Bump All Pm Replied
Thanks
Ken,S
Old 09-01-2009, 07:44 PM   #27
Fatboy Garage
bump bump bump
Old 09-02-2009, 10:14 AM   #28
Fatboy Garage
bump bump bump
All Pm Replied
Old 09-03-2009, 11:17 AM   #29
Fatboy Garage
ALL PM replied!!
Thanks
Ken,S
Old 09-03-2009, 06:19 PM   #30
Fatboy Garage
night night night
Bump Bump Bump
