Old 11-24-2009, 04:48 PM   #1
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
Car wont start
I have 95 240sx (ka)I was driving normally and when i got to the stop light and my car hesitated and then just cut off. I tried starting it and it wouldnt start. I grabbed a pair of pliers and pulled out one of the spark plug wires and stuck the pliers inside and about 1/16 inch away from a chasis ground and noticed i wasnt getting any spark. My question is how often do the internal coils on a 95 KA go out and would you recommend changing the cap,rotor,plug wires before spending $200+ dollars on a brand new distributor?
redline racer510 is offline   Reply With Quote
Old 11-24-2009, 08:30 PM   #2
redline racer510
nobody knows or has experienced this problem
Old 11-24-2009, 11:15 PM   #3
fcdrifter20
fcdrifter20's Avatar
Trader Rating: (44)
fcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to behold
Feedback Score: 44 reviews
check ur ingnition fuse
fcdrifter20 is offline   Reply With Quote
Old 11-25-2009, 12:14 PM   #4
JDMwannaBE
JDMwannaBE's Avatar
JDMwannaBE is on a distinguished road
when's the last time you did just a general tune up? how do your plugs look?
JDMwannaBE is offline   Reply With Quote
Old 11-25-2009, 05:43 PM   #5
redline racer510
well i replaced the plugs about 1000 miles ago with NGK's and today i replaced the cap and rotor which got me to start my car and drive it 10 miles or so but it still has trouble starting and it hesitates and sputters when i give it gas and also when im about to come to a stop. I am also getting a check engine light and the following codes:
13-coolant temp sensor
25-IACV
34-Knock Sensor
After installing the cap and rotor i reset the ecu and after starting the car back up it gives my a check engine light again. Do you think it can be the distributor itself because my ka has the internal coil not the external coil as in 91-94 240sx's?
Old 11-25-2009, 06:09 PM   #6
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
check the resistance of the ECT. clean out your iacv then go from there. reset the ECU.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 11-25-2009, 06:43 PM   #7
redline racer510
I replaced the plugs like 1000 miles ago (NGK) and just a few hours the cap and rotor and it got the started but gave me a check engine light so i reset the ecu but before doing so noted that i have a code for coolant temp sensor, IACV, knock sensor. After driving the car it has alot of hicups and when giving it gas it has some hesitation and when i come to a stop it sputters and i have to give it gas to keep it from diein(this is an auto btw). I think the next thing im going to change is probably the distributor itself.
Old 11-25-2009, 06:45 PM   #8
redline racer510
sorry but im not familiar with the synonym ect lol( i know its a newb thing )
Old 11-25-2009, 11:15 PM   #9
hockeymikey16
hockeymikey16 is an unknown quantity at this point
have you checked ANY of your vacuum lines?.. how exactly your car is acting up?
is it turning over? starting but the idle is abnormal?... my car had the sorta the same problem..
car died when i stop at the light, then i started it but it wouldnt hold idle. i had to push it home, it was a vicious vacuum leak thats why it couldnt hold the idle right... GL man
hockeymikey16 is offline   Reply With Quote
Old 11-25-2009, 11:19 PM   #10
hockeymikey16
try and open up your dizzy cap and take off your dizzy. and grab a wire brush and give it a good clean, not too much though you dont want to extend the gap.
clean the dizzy itself and the cap rotor from the terminal and the electrodes inside. or w/e u call them.
but yeah GL
Old 11-25-2009, 11:35 PM   #11
roboticnissan
roboticnissan's Avatar
roboticnissan is making a name for him/her selfroboticnissan is making a name for him/her selfroboticnissan is making a name for him/her self
ustJustget a new motor
roboticnissan is offline   Reply With Quote
Old 11-26-2009, 08:14 AM   #12
redline racer510
lol, just get a new motor, i was thinkin bout that but its not an option right now do to financial issues and the budget i have to work with on this car. The thing that i am having right now is that it wont hold idle when i am parked and it hicups while im driving and when i give it gas it hesitates.
Old 11-26-2009, 12:02 PM   #13
redline racer510
im thinking it might be the distributor since the car didnt start until i replaced the cap and rotor and it still something to do with a weak spark. any input on this situation will be very much appreciated.
thank you...
Old 11-26-2009, 06:47 PM   #14
redline racer510
yea i just checked my ecu and the only codes i have are 13,34,98 two of which are ect related and one is knock sensor any input on this guys?
Old 11-28-2009, 01:31 PM   #15
redline racer510
i m changing the dizzy and the plug wires
Old 11-29-2009, 10:07 AM   #16
redline racer510
checked the resistance of the ect yesterday and it came out to around 2.4 ohms it say it should be around 2.1-2.9 at 68F yesterday was in the mid to high 50's so do you thing the ect is still good?
Old 11-29-2009, 01:13 PM   #17
redline racer510
i just installed the new distributor and i started it up to find that the car is running really wierd the idle goes up and down really fast and it shut off like 2-3 mins later and like a puff of smoke or something came out from under the intake manifold area. this car is really pissiong me off and i really need this to be runing reliably becuase i am starting a new job in a few days. any help guys?? I tried everything i have no clue what it is the last thing i have in id is to clean the iacvbut this thing looks like it would be a PITA to mess with.
