Old 11-27-2009, 12:55 AM   #1
youarenottricky
youarenottricky's Avatar
youarenottricky is an unknown quantity at this point
Send a message via AIM to youarenottricky
temp gauge drops when revving
so, i blew my radiator or water pump or something, and i replaced pretty much everything (radiator, all hoses, thermostat, water pump). after priming the block post-installation to get the air out of the system, my temp gauge is normal while idling, driving low speeds, or when in neutral, but when i rev the engine or am going above 35 in drive (yes i have an auto lol ), the gauge slams down to C like it wants to jump past the pin.
could this mean that there's still air in the system? or do i just need to clean/replace my temp sensor? or what?
"I may have been born yesterday, but I stayed up all night" - El-P
youarenottricky is offline   Reply With Quote
Old 11-27-2009, 01:01 AM   #2
Slammed Assassin
Slammed Assassin's Avatar
Trader Rating: (34)
Slammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud of
Feedback Score: 34 reviews
Send a message via AIM to Slammed Assassin
your temp sensor may be going bad, cheap replacement.
if anything try getting a aftermarket temp gauge as well, the oem ones suck.
Slammed Assassin is offline   Reply With Quote
Old 11-27-2009, 01:02 AM   #3
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
make sure the sensor is connected properly. as the actual temp of the water goes up resistance in the sensor increases. check resistance of the sensor or that it's connected properly and make sure that it's getting 5 volts reference. also if you can, jump the wires in the connector to make sure that it's reading properly. it could just be the gauge that is bad.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 11-27-2009, 01:52 AM   #4
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
This happened to me in my SR. I forgot what I did to fix it...I think I just replaced the coolant temp sensor...
They are like 20 bucks or so..
DataXUnknown is offline   Reply With Quote
Old 11-27-2009, 02:17 AM   #5
youarenottricky
thanks for the info! ill look into getting a new temp sensor... i have a new gauge cluster waiting to be put in as well, since my speedo is buggy
Old 11-27-2009, 12:34 PM   #6
johngriff
johngriff's Avatar
The sensor that drives that gauge is not the two wire temp sensor (thermistor) it is the 1 wire thermo-switch. Make sure you replace the right one.
[email protected]
Old 11-27-2009, 09:07 PM   #7
youarenottricky
where is this sensor? and do you know where can i buy a replacement?
Old 11-27-2009, 12:40 PM   #8
DataXUnknown
Trader Rating: (30)
Nissan OEM ECU Temperature Sensor S13 SR20DET KA24DE
Thats the one I remember buying. It was on the top of my intake manifold. Not sure if "johngriff" is talking about that one?
Old 11-27-2009, 01:32 PM   #9
johngriff
johngriff's Avatar
Yeah, that is the wrong one to fix the gauge cluster
[email protected]
Old 11-27-2009, 09:09 PM   #10
youarenottricky
i should probably also note that my car has a KA24E, don't know if that makes a difference
Old 11-27-2009, 10:10 PM   #11
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
John is right, the red one is for the ecu. the one next to it is the gauge.
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 11-28-2009, 12:54 PM   #12
johngriff
johngriff's Avatar
Originally Posted by BoostedCoupe View Post
its the red sensor on the intake that the upper rad hose connects to the intake manifold.
No
NO
NO!
NO!!
It is not the colored two wire sensor! Its right next to it! It has one wire push on black square plastic connector, on a thick gauge black wire. Does not matter what engine type, all eccs nissans use this setup.
[email protected]
Old 11-28-2009, 02:05 PM   #13
NISMO_tuner
NISMO_tuner's Avatar
Trader Rating: (64)
NISMO_tuner is an unknown quantity at this point
Feedback Score: 64 reviews
Send a message via Yahoo to NISMO_tuner
FAE KA/SR Dash Gauge Temperature Sensor S13 Chassis
this is for the dash guage temp sensor
Check my for sale thread for S13 parts
NISMO_tuner is offline   Reply With Quote
