Old 02-08-2010, 07:30 PM   #1
tig_tech
tig_tech's Avatar
Trader Rating: (25)
tig_tech is on a distinguished road
Feedback Score: 25 reviews
Huge Ballers Only Aftermarket Part Out!!!
Well i've thought long about this for a while and certain things have come up that forces me to move on. I just bought a new house and I want to focus on school and get out of turning wrenches/welding. Most of my parts have seen 500-2000miles because of me not driving the car much. Most parts are in immaculate condition due to me cleaning and polishing every time I step foot in the garage. Those of you that know me well know how I am with my car. So rest assure you will be getting parts that are in excellent shape. My setup has never been dynoed but has been estimated to push anywhere from 380-450hp w/0.8-1.3bar of boost. I have a wide backround in mechanics,engine building and welding/fabrication. The engine was assembled by me after taking the engine parts to Precision Machine for machine work and blueprinting. I have receipts from all the machining they did along with build pictures of the engine. The engine only ran Motul 300V and will come with 3 liters of unused motor oil. Everything is still running and together just in case someone interested in the engine wants to see it run. Here it goes:
Super Clean Rebuilt SR20DET Redtop Long Block w/ VG30DETT New Oem 87mm pistons, ARP Hardware w/oem reconditioned rods, Apexi 1.1mm Metal Headgasket, New Oem Cylinder Head Bolts, New Oem Main and Rod Bearings, Nismo Main Bolts, Nismo Thermostat, Tomei 256 Poncams, Tomei Rocker Arm Stoppers, New Oem Rocker Arms (800 miles), Updated Timing Chain Kit, Blacktop Oil Strainer, New Oem Oil Pump/Front Cover, New Oem Bolts on front side of engine, Greddy Iridium #8 Spark Plugs, 3 Angle valve job on head, New oem intake/exhaust valve guides, New valve guide seals, New gaskets up and down the engine, New Core Plugs installed, Power enterprise magnetic oil filter,and Sard Magnetic Oil Drain Plug. Heater lines block/capped off.-$2300obo
Link to engine build: http://nissan.240sx.net/viewtopic.ph...hilit=welddrft
Machine Work on Engine
Checked line bore, Bored and Honed, installed ARP bolts to Rods and reconditioned rods, cleaned and degreased engine, installed core plugs, balanced, polished and grinded crankshaft. (Receipts to prove)
Greddy TD06-20g 8cm2 Turbo Kit modified for LHD 240sx (S13) Roughly 1300 miles-$2800obo
Greddy Profec B Boost Controller-$140obo PENDING SALE
Greddy Intake Manifold-$450obo
SR20DET Wire Harness for S13 Chassis-$180obo
(2) 5 Speed SR20DET Transmissions in good shape-$250 each
Nismo Slave Cylinder (S13-S14) New-$100obo
Nismo Braided Clutch Line (S13-S14) New-$60obo
ATS Carbonetic Twin Plate Clutch (S13-S14) babied 1874miles-$1900obo
JIC J-Force 07 Chrome 5x114.3 17x10 +20mm 17x9 +15mm (Mint Condition) wrapped in good federal 595s. Seen the road under 1500 miles-$1200obo
Yashio Factory Water Temperature Meter-$150obo
Weld DIV Flame Voltage Stabilizer w/earthing kit-$180obo
Custom CAS Cover Polished-$50obo
Custom Air Diversion Plate brushed aluminum-$40obo
Defi Gauge Set 60mm(Link Control Unit V2, Oil Pressure, Oil Temp, Fuel Pressure, Boost complete w/sensors and harnesses) KPA readings-$500obo
Oddyssey PC680 Slimline Drycell Battery w/custom tied down-$100obo
G-Force 3inch 5 point Harness-$60obo
tig_tech is offline   Reply With Quote
Old 02-08-2010, 08:03 PM   #2
speedfiend
Trader Rating: (68)
speedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to all
Feedback Score: 68 reviews
Send a message via AIM to speedfiend
Sent you a pm. Interested in FAL fans and Dif fan controller.
Cameron
speedfiend is offline   Reply With Quote
Old 02-08-2010, 08:18 PM   #3
drb930
drb930 is an unknown quantity at this point
Walbro 255 Fuel Pump-$50obo
Can you do $50. shipped to 91406?
Thanks,
Dave
drb930 is offline   Reply With Quote
Old 02-08-2010, 09:16 PM   #4
Couped_up'd
Couped_up'd's Avatar
Trader Rating: (47)
Couped_up'd is an unknown quantity at this point
Feedback Score: 47 reviews
Pm'd you mang.
Couped_up'd is offline   Reply With Quote
Old 02-08-2010, 09:44 PM   #5
240sxman
240sxman is an unknown quantity at this point
I will take the SR Harness for the S13
240sxman is offline   Reply With Quote
Old 02-08-2010, 10:03 PM   #6
sidedrifts13
sidedrifts13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
fpr and greddy boost controller shipped to 90250 thanks
sidedrifts13 is offline   Reply With Quote
Old 02-08-2010, 10:05 PM   #7
MeowMR2
MeowMR2 is making a name for him/her selfMeowMR2 is making a name for him/her self
Also intrested in the DIF fan controller. Any pictures on the Sparco fighter, and the date of the seat.
MeowMR2 is offline   Reply With Quote
Old 02-09-2010, 04:39 AM   #8
ross.cottrill
ross.cottrill's Avatar
ross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant future
hey man,would you sell me the coil pack cover??
" NEO VVL BABY FTMFW!"
Originally Posted by shagspeed
Dude if I made 500WHP on a 54C SR20DET back in 1999-2000 with old school technology .. This VET will T-BAG your RB engines
ross.cottrill is offline   Reply With Quote
Old 02-09-2010, 08:11 AM   #9
volcomprodigy02
volcomprodigy02's Avatar
volcomprodigy02 is an unknown quantity at this point
ill give you 650 shipped for the seat, the harness with the Nismo slavecylinder and the steel braided clutch line if you can get me some pics shipped to 55313
volcomprodigy02 is offline   Reply With Quote
Old 02-09-2010, 09:13 AM   #10
jeremy385
jeremy385 is an unknown quantity at this point
Yo man can you do 55 shipped for the fuel pump to 80127???
jeremy385 is offline   Reply With Quote
Old 02-10-2010, 01:25 AM   #11
180sxs13
180sxs13 is an unknown quantity at this point
pm you for the DIF 11413 NY
180sxs13 is offline   Reply With Quote
Old 02-10-2010, 07:03 AM   #12
tacoboy
tacoboy is an unknown quantity at this point
I'll give you 85$ shipped to n0m2a0 canada land, pm me if interested.
tacoboy is offline   Reply With Quote
Old 02-10-2010, 07:34 AM   #13
dookiedang
dookiedang is on a distinguished road
Send a message via AIM to dookiedang
how stiff is that clutch?
dookiedang is offline   Reply With Quote
Old 02-10-2010, 09:42 AM   #14
fufanu180
fufanu180's Avatar
fufanu180 is an unknown quantity at this point
how much for the coil pack ornament?
fufanu180 is offline   Reply With Quote
Old 02-10-2010, 11:40 AM   #15
Campos
Campos's Avatar
Campos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura about
Send a message via AIM to Campos
The clutch is tempting...pm me best you can do shipped to tx 77651
Parting out SR build....
Campos is offline   Reply With Quote
Old 02-10-2010, 01:48 PM   #16
iwannaslyde
iwannaslyde's Avatar
iwannaslyde is an unknown quantity at this point
yo. RE-FUCKING-SPECT on that engine build.
iwannaslyde is offline   Reply With Quote
Old 02-10-2010, 02:00 PM   #17
sr20drifter1
sr20drifter1's Avatar
Trader Rating: (66)
sr20drifter1 is just really nicesr20drifter1 is just really nicesr20drifter1 is just really nicesr20drifter1 is just really nicesr20drifter1 is just really nicesr20drifter1 is just really nicesr20drifter1 is just really nicesr20drifter1 is just really nicesr20drifter1 is just really nice
Feedback Score: 66 reviews
parts
Has anybody received a reply from this guy? I pmed him twice,but no response.
DAOUD AKA KONGO DAVE
sr20drifter1 is offline   Reply With Quote
Old 02-10-2010, 02:53 PM   #18
tig_tech
tig_tech's Avatar
Trader Rating: (25)
Thanks for the comments. All PMs replied to. Sorry, ive been getting pm's left and right every hour on the hour so its been hard for me to reply. I have alot of people that are interested locally but if they do flake I will get back with everyone who needed parts.
Old 02-10-2010, 03:08 PM   #19
nissansrbetter16
nissansrbetter16's Avatar
nissansrbetter16 is making a name for him/her selfnissansrbetter16 is making a name for him/her self
how much for the slave cylinder and braided clutch lines shipped to 26330
nissansrbetter16 is offline   Reply With Quote
Old 02-11-2010, 12:44 AM   #20
FerretsCanDrift
FerretsCanDrift's Avatar
FerretsCanDrift will become famous soon enoughFerretsCanDrift will become famous soon enoughFerretsCanDrift will become famous soon enoughFerretsCanDrift will become famous soon enough
whats the best u can do for the lugnuts shipped to 08724?
FerretsCanDrift is offline   Reply With Quote
Old 02-14-2010, 05:59 AM   #21
mattsil80wis
mattsil80wis is making a name for him/her selfmattsil80wis is making a name for him/her self
how much for the slave and underbody panel shipped to 18360
I PMed you and never heard back lmk
mattsil80wis is offline   Reply With Quote
Old 02-14-2010, 07:56 AM   #22
Nismoslider
Nismoslider's Avatar
Nismoslider is an unknown quantity at this point
hey can i pick those radiator hoses up for $35, i live like 45 min from jax... send me a pm
Nismoslider is offline   Reply With Quote
Old 02-14-2010, 10:52 AM   #23
MeowMR2
Hey your pm box is Super full, Still have the DIF fan controller?
Old 02-14-2010, 11:00 AM   #24
uperformance
uperformance is an unknown quantity at this point
still want that fpr setup dude.
thats all.
please pm me.
uperformance is offline   Reply With Quote
Old 02-14-2010, 11:44 AM   #25
tig_tech
tig_tech's Avatar
Trader Rating: (25)
The DIF fan controller is sold as well as the flex a lite fans. FPR setup is still available. I will pm you for details.
Old 02-14-2010, 11:57 AM   #26
speedfreak90
speedfreak90's Avatar
speedfreak90 is an unknown quantity at this point
you def. have alot of baller parts... glws
speedfreak90 is offline   Reply With Quote
Old 02-14-2010, 03:57 PM   #27
white1996zenki
white1996zenki is an unknown quantity at this point
if sale for boost controller falls thru..lmk
white1996zenki is offline   Reply With Quote
Old 02-14-2010, 06:42 PM   #28
1SicS13
1SicS13 is an unknown quantity at this point
take 225 shipped for the sway bars and mounting hardware
1SicS13 is offline   Reply With Quote
Old 02-16-2010, 07:12 AM   #29
bananamonkey
bananamonkey's Avatar
bananamonkey is making his/her stupidity well-knownbananamonkey is making his/her stupidity well-knownbananamonkey is making his/her stupidity well-knownbananamonkey is making his/her stupidity well-known
Thumbs up
pm sent. . . . .
bananamonkey is offline   Reply With Quote
Old 02-16-2010, 11:21 AM   #30
S13RB25DETDRIFTER
S13RB25DETDRIFTER's Avatar
S13RB25DETDRIFTER is an unknown quantity at this point
stuff
msg sent pm sent and stuff sent
S13RB25DETDRIFTER is offline   Reply With Quote
