Old 04-03-2010, 11:20 PM   #1
wiggafly808
wiggafly808's Avatar
wiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to all
Q on the bottom bolt holding rear suspension in
Hi,
The nut holding my coilover in on the bottom in the rear suspension is super messed up/rounded out past the point of vice grips etc.. (pic for reference of which one im talking about)
If i grind this off, can i just pound out the bolt and replace it?
Thanks in advance.
wiggafly808 is offline   Reply With Quote
Old 04-03-2010, 11:24 PM   #2
repda916
repda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymore
looks like you can still take that off no problem...man up with the vise grips
repda916 is offline   Reply With Quote
Old 04-03-2010, 11:27 PM   #3
wiggafly808
Thats not the actual bolt, im just showing which bolt it is
Started off as a 17, rounded out
Vice grips kept stripping it more
Pounded a 16 on there, it just rounded out again.
Used a dremel to try and flatten two sides of the bolt, stuck a vice grip on there, but the vice grip just stripped the metal.
Old 04-03-2010, 11:52 PM   #4
holybushoffire
holybushoffire's Avatar
holybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant future
Send a message via AIM to holybushoffire
Spray some PB on there and jack up the car a little to even the pressure out. Then man up and caveman it off. lol
"I am not good English, I like the drift"
CHINA DRIFT
"some guys have a better relationship with their car than their wife haha. sad but true."
SECRET SOCIETY
holybushoffire is offline   Reply With Quote
Old 04-04-2010, 12:02 AM   #5
wiggafly808
Pretty much soaked it in PB, i can pull the vice grip, but no matter how tight i get it, it just makes grooves in the metal..
Ill probably just end up grinding it off and replacing the knuckle
Old 04-04-2010, 12:04 AM   #6
Tantwoforty
Tantwoforty's Avatar
Tantwoforty is an unknown quantity at this point
thats probably what your gunna have to do..
and then invest in a good impact gun..
Tantwoforty is offline   Reply With Quote
Old 04-04-2010, 12:13 AM   #7
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
Here's how you use vice grips...its a mental game.
The first time you lock on a bolt has to be the last time! lock them on SOOO FUCKING tight!!! that god himself can't remove them. get another person to help you close them if u hafta.
then loosen, "mini sledge" assist if needed, that sucker will pop right off.
Final resort.. weld on 1/2 socket then breaker bar.
Chrischeezer is offline   Reply With Quote
Old 04-04-2010, 12:28 AM   #8
^fraktal^
^fraktal^'s Avatar
^fraktal^ will become famous soon enough^fraktal^ will become famous soon enough^fraktal^ will become famous soon enough^fraktal^ will become famous soon enough^fraktal^ will become famous soon enough
just get a nut splitter (yes that is an actual tool). or learn how to use vise-grips correctly.
^fraktal^ is offline   Reply With Quote
Old 04-04-2010, 06:55 AM   #9
cotbu
cotbu's Avatar
Yeah! my fiancé is free Wednesday!
Old 04-04-2010, 03:25 PM   #10
aznpoopy
aznpoopy's Avatar
spiral fluted extractors. they cut into the bolt as you turn it out.
http://ldsdates.com/blog2/wp-content...tremovers2.jpg
Old 04-04-2010, 03:28 PM   #11
repda916
never knew they existed
