Dousan or anyone with Tein HEs
not sure if this goes in the technical forum or not...but o well.
just wondering if anyone has a Tein HE manuel in english, or were they all writen in Japanese? I got mine in Japan 2 years ago so Im not sure how the US ones came. I need to know some things about that little green plastic thing that came with them. Thanks! ![]()
If your refering to the long L shaped plastic peice that says Tein on it, that's just to make sure that you have enough legal ground clearance. Remember In Japan they have to go thru Shaken which is somewhat like smog test but more elaborate, some pretty tuff standards. I think no less than 9 inches will pass
hum... the manu dosnt go over it.. weird..
stupid green thing, ive had it forever and had no idea what it was for. Then my friend said it was for the sugested ride hight or somthing... weird..
![]() Join Date: May 2002
yeah i dont know what that thing is for haha
i just threw it away. obviously nothing to do for performance... maybe ride, doesnt it have some ruler on it? i guess its good if you dont have a tape measure? |
Endless Knights
Yeah i also wondered about that green thing. Like kurio said it is for measuring ground clearance(i think). In the japanese manual it has an illustration of someone measuring the clearance with it.
![]() Join Date: Aug 2002
> I recommend to set up your TypeHE. Please check below.
> > *Ride height (Hub center to femder) > Front : around 320mm > Rear : around 315mm > > *Damping force set up (Click No.) > Front : Depending your feeling. > Rear : Depending your feeling. > But...you should start up at No. 8 front & 8rear. > and then ,You got a some feeling and something you want, > Please turning click knob & change click setup. > > Click setup is... > > Full colockwise is No.0, It's hardest setup. > Turn back to Unclockwise setup are going softer. |
Endless Knights
apparently there's some kind of height regulation in japan, it's a measurer for that height, like from your cat to the ground... i believe it's the standard size of a speed bump in japan, like 80mm, right?
K.A.H. -so then i tell'er "yeah, honey, you're on the list, but i moved you way to the bottom!" |
#10 | |
Endless Knights
my car was so low my frame rail hit the speed bump. NOT COOL
hahaha.. fixed that. ill measure where its at now, everything seems to clear except steep driveways..but that's always gonig to be an issue unless you are stock height...and sometimes need to be higher then that too. ![]() |
#12 | |
Endless Knights
#13 | |
on strike three.
![]() Join Date: Mar 2003
![]() i'm most worried about that damn front lip..the thing is like millimeters off the ground... |
#14 |
mine is low too
but not horrible its mean to scrape. its a warnign it is more for comedy scraping lip, clunking and skipping rear tires (from LSD) makes people give me dirty and WTF looks in parking lots best is when the tire sqeels i get lots of dirty looks for parents with kids walking thru the lot good times ![]() ![]() now imagine sideskirts on that soon hahaha edit: from center of wheel well (fender) to ground front is 61.5 cm rear is 60.5 cm yes i know front is slightly higher up. but 1cm is not much. weight shift to rear ![]() this is with 205/55/15 tires Last edited by Dousan_PG; 07-15-2003 at 02:31 PM.. |
#15 |
on strike three.
yeah i might have to raise mine up a little bit..just to be safe..we'll see..i'll measure when i get home..
![]() also what do you set your Teins at damper wise for normal driving?..uhh we'll say 0 being softest and 16 being stiffest (arbitrary values).. hey when you comin back up north?..there is a pretty fun small time event on August 3rd in Monterey, well Marina to be exact (it's like 25 min from Santa Cruz), if you wanna get a tiny bit of warm up in before Buttonwillow.. |
#16 |
aug 3...hmm i'll chck my schedule. for now im maybe but that might be yes if i find out im free that weekend!! thanks! (can i drift there?) hehe...
my Teins were at 8 clicks in from hardest daily drive..sometimes 10. i dont like it too soft. i like to haul around corners so low damper=sot springs is just annoying. |
#17 | |
on strike three.
alright well hopefully you are free that weekend.. yeah you can most definately drift..that is the only reason we go there..it's technically an AutoX but they allow us to drift because we know the person who puts it on personally through Full Speed..plus there are only about 4 of us out of 100 or so participants who drift..but he hooks us up...we don't even have to show up at 8am like everyone else..we can cruise in at like 12:30 and run in the afternoon groups.. ![]() |
#19 | |
![]() Join Date: Nov 2002
#22 |
on strike three.
hahah...swim..i like that..
![]() there should be another one in September though... so maybe you can come to that one if your car will be here by then..it is definately the more the merrier..within reason of course..and assuming the people are cool..lol..but any friend of Dousan's............ ok, yes i'm a nooob...but i have to ask..Touge = Grip ![]() |
#23 | |
#24 | |
on strike three.
![]() yeah my friends and i just purchased some walkie talkie type radios with headsets that are voice activated..and i think they have like a 3-mile range or somethin..very cool though..can't wait to try them out..getting tried of using cell phones and/or light flashing to denote what we are trying to say to eachother.. |
#26 | |
on strike three.
#28 |
Endless Knights
I had a question about adjusting the camber on the HE. I adjusted the front camber today and im not certain how much i did it. There are ruler lines on the top of the camber plate and i put it to the fourth mark. Does each marking measure in 0.5 degree increments or is it measured in 1 degree increments? If its .5 then i have it a -2 camber.
#29 |
i dont think its meant to be degrees. i think its for accuracy on each side.
also remember, HEs have a eccentric bolt so make sure you are alerady aligned properly w/ that bolt before playing w/ the camber plates also more camber=toe in. |
