Old 06-14-2010, 11:53 AM   #1
thenooblet
thenooblet's Avatar
thenooblet is an unknown quantity at this point
Question Q45 lsd swap q's
im wanting to swap my diff in my '95 s14 for a Q45 diff. i want the lower gear ratio tht is in the Q45's. i was trying to find out if the Q45 diff. is a straight swap with my non-abs s14 diff. is there any modifications at all when swapping for the q45?
thenooblet is offline   Reply With Quote
Old 06-14-2010, 10:57 PM   #2
240Zfunahollic
240Zfunahollic is an unknown quantity at this point
This is from a for sale thread i came across a while back. I wouldn't run that with a ka/sr/ca/rb though. The ratio would SLOW you down, but increase gas mileage and top speed.
1992 Q45 Differential 3.54:1 Ratio
1992 Q45 LH Axle
1994 Z32TT LH Axle
1992 Q45 5-lug Hubs
All Axle nuts/bolts/washers/etc.
This is everything you need to bolt in this R200 with the larger, stonger TT style axles in your 5-lug 240SX.
http://zilvia.net/f/image.php?type=sigpic&userid=15347&dateline=123195  6786
Visit My Trader rating page
http://zilvia.net/f/traderratings.html?u=15347
240Zfunahollic is offline   Reply With Quote
Old 06-16-2010, 12:35 PM   #3
shade
shade's Avatar
shade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond repute
'97-'01 Q45 VLSDs are what your looking for. You just need J30 axles to make it work.
Won't even bother with the earlier Q45s unless you want to change out your hubs as well.
shade is offline   Reply With Quote
Old 07-16-2010, 08:23 AM   #4
s15lover
s15lover's Avatar
s15lover is an unknown quantity at this point
Send a message via Yahoo to s15lover
got a full swap btw with the driver's side axle and hubs...you can source the tt axle on car-part.com they run 125...txt me 865-604-9443 if you're interested.
s15lover is offline   Reply With Quote
Old 11-07-2013, 07:21 PM   #5
crewchief05
crewchief05 is an unknown quantity at this point
sorry to open this back up. I just need some clarification.
I plan on using the z32tt/q45 axles and q45 diff.
My question is will that fit into the stock s14 knuckles(uprights)? or do i have to use the TT or q45 knuckles. I know without using the axles they are to short or long regardless. But again if I am using the axles and hubs will they fit into the stock s14 knuckles?
No one ever mentioned this or asked this question. i searched.
crewchief05 is offline   Reply With Quote
Old 11-07-2013, 07:23 PM   #6
crewchief05
i think the answer is use q45 hubs? or can i use TT hubs?
Will these fit in the stock s14 knuckles/uprights?
Old 11-07-2013, 08:12 PM   #7
JD504
JD504's Avatar
JD504 is an unknown quantity at this point
What do I need to do to have the 97 q45 diff on my s13 hatch looking at one for sale rite now just need to know requirements before I purchase it
JD504 is offline   Reply With Quote
Old 11-08-2013, 06:50 PM   #8
The Dude
The Dude's Avatar
The Dude is an unknown quantity at this point
KA24DEvelopment.com :: VLSD Swap Information
/thread
The Dude is offline   Reply With Quote
Old 11-08-2013, 06:43 PM   #9
turbob16ef
turbob16ef's Avatar
turbob16ef is an unknown quantity at this point
If I recall right, the older (pre-97), you must use the tt/q45 axles along with z32/q45 hubs.
The 97+ you can use j30 axles, which can fit the stock s-chasis hubs.
My set up consist of 97 diff
95 axles flanges
Z32 tt driver axle
Q45 driver axle
Q45 hubs.
You must also redrill your driveshaft flange.
turbob16ef is offline   Reply With Quote
Old 11-08-2013, 06:45 PM   #10
turbob16ef
turbob16ef's Avatar
But I could be wrong. There might be other combos that work.
Old 11-22-2013, 09:58 PM   #11
crewchief05
just did the q45 swap. all bolted up. pretty simple.
lsd, q45, s14
