Old 09-12-2010, 11:29 PM   #1
zingo
zingo's Avatar
zingo is an unknown quantity at this point
Post Z32 unstable RPM flux
Ok so once its all warmed up and i drive for about 5 minutes, I release the gas and let it slowly crawl down to idle RPM, then once it reaches the 1000rpm mark the car drops to 600 and then rises to 900, and just keeps fluxing like that 600/900/600/900/600/900 and then it stops when I come to a complete stop, Ive cleaned the MAF, AAC, IACV and fixing all vacuum leaks, so far doing all that make no difference, although it does make the problem less aggressive, but I still can't drive it normally, cuz the whole car will shake back and forth when the flux happens, what should I do?!?!?
zingo is offline   Reply With Quote
Old 09-12-2010, 11:40 PM   #2
articdragon192
articdragon192's Avatar
Check your TPS
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 09-12-2010, 11:42 PM   #3
zingo
zingo's Avatar
you really think that would do the trick? I'll give it a shot first thing in the morning and I'll update you on my progress thanks
Old 09-12-2010, 11:48 PM   #4
zingo
zingo's Avatar
hey I looked at my TPS the wire that connects to the TPS is missing that clip thing, is that bad? and how would I fix my problem with the TPS? do i move it back and forth or what?
Old 09-13-2010, 12:31 AM   #5
Z32TT-R
Z32TT-R's Avatar
Z32TT-R is an unknown quantity at this point
Volt meter.., at idle it should be between .40-.50v but .42-.44v are usually the best reults for setting.
Z32TT-R is offline   Reply With Quote
Old 09-13-2010, 05:01 PM   #6
zingo
zingo's Avatar
checked the tps its at .43v thats good? and its still doing the flux thing
Old 09-14-2010, 05:42 PM   #7
zingo
zingo's Avatar
ok so I narrowed it down, its not any electrical equipment failures, so that means somethings clogged, alraedy cleaned AAC and IACV what else is there that could be clogged and causing my problem?
Old 09-15-2010, 01:38 AM   #8
articdragon192
Fuel filter?
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 09-15-2010, 04:37 PM   #9
zingo
zingo's Avatar
ok heres a more precise description, once the cars all warmed up and all that, and I've been driving for 5 minutes or so, I let off the gas to let the car return to idle, on the RPM, once the needle hits idle (about 900rpm) the needle will bounce, and the car will go back and forth back and forth, could it really be the fuel filter?
Old 09-16-2010, 01:09 AM   #10
articdragon192
Or a vacuum leak you're missing
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 09-16-2010, 07:32 AM   #11
cotbu
cotbu's Avatar
Sounds like coolant temp sensor. pull codes.
