Old 10-14-2010, 05:03 PM   #1
Drifting-pedobear
Drifting-pedobear's Avatar
Drifting-pedobear is an unknown quantity at this point
s14 before the SR goes in, a few things to do.
okay, I've been compromising a list of things that should be done before the SR is plopped into its respective location. please add or comment on the list I've gather this far. tips, info, etc is very appreciated.
Coolant Temp Sensor
Front Main Seal
Rear Main Seal
Water Pump
Intake Plenum To Collector Gasket
Nismo Thermostat
Manifold To Head Gasket
Manifold To Turbo Gasket
Valve Cover Gasket
Spark Plug Cover Gaskets
Intake Plenum To Head Gasket
z32 Fuel filter
All hoses under intake manifold
4 bolt and 5 bolt turbo gaskets
Heater hose
new injector o-rings
PCV Valve
Clutch (pilot/throw out bearing)
resurface fly wheel
Nismo Clutch fork pivot
All belts
i think thats a pretty good list for a well done maintenance job. LMK what else or if you have any comments. thanks
RIGHTWHEELDRIVE.com
Drifting-pedobear is offline   Reply With Quote
Old 10-14-2010, 06:44 PM   #2
Stratokat
Stratokat's Avatar
Stratokat is an unknown quantity at this point
Send a message via AIM to Stratokat
i wouldn't change the clutch fork, but it's your money.
F/S Moroso SR20 Oil Pan & Solid Mounts
Stratokat is offline   Reply With Quote
Old 10-14-2010, 06:59 PM   #3
inyowindow
inyowindow's Avatar
inyowindow is an unknown quantity at this point
i dont think he's changing the clutch fork, just the pivot bolt.
inyowindow is offline   Reply With Quote
Old 10-14-2010, 07:54 PM   #4
Drifting-pedobear
thats correct.
its like 50 bucks, i ive heard that its worth it.
RIGHTWHEELDRIVE.com
Old 10-14-2010, 11:37 PM   #5
slow40sx
slow40sx's Avatar
slow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud of
Send a message via AIM to slow40sx
Originally Posted by Drifting-pedobear View Post
thats correct.
i got mine at cost, 30 bucks haha but its diesel as fuck u'll never buy another one haha
slow40sx is offline   Reply With Quote
Old 10-14-2010, 11:48 PM   #6
Drifting-pedobear
ill cut you.
RIGHTWHEELDRIVE.com
Old 10-14-2010, 08:34 PM   #7
97240TB
97240TB's Avatar
97240TB is an unknown quantity at this point
You forgot to add the souls of 1000 children.
97' 240SX, VQHR swap Combplete.
97240TB is offline   Reply With Quote
Old 10-14-2010, 08:44 PM   #8
helladudebro
helladudebro is an unknown quantity at this point
re-seal oil pan, piston rings, rod/main bearings. <- it'll be worth it to have a fresh engine. those parts are cheap.
helladudebro is offline   Reply With Quote
Old 10-14-2010, 09:45 PM   #9
Drifting-pedobear
resealing the oilpan is easy to do after the swap. same wuth bearings. but i dont feel like replacing thoes things. i thought about it tho.
RIGHTWHEELDRIVE.com
Old 10-14-2010, 11:39 PM   #10
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
the parts are cheap .. but to put them in can get way out of his price range.
and its not a good idea to cheap out on machine work
1992 240sx (RB20. 362whp@16psi)
eklips3 is offline   Reply With Quote
Old 10-14-2010, 11:52 PM   #11
Red Dragon3
Red Dragon3's Avatar
Red Dragon3 is an unknown quantity at this point
Change the oil pump and timing chain. Those are the two things i regret not changing when i had my motor out. Do i while you have everything apart.
08 Mitsubishi Evo X MR
89 Nissan 240SX
Red Dragon3 is offline   Reply With Quote
Old 10-15-2010, 12:17 AM   #12
Drifting-pedobear
thoes are kinda expensive. id rather not untill i have to, even if it will be a pain.
RIGHTWHEELDRIVE.com
Old 10-17-2010, 09:18 PM   #13
Fries
Fries's Avatar
Its a good thing that the damage caused by not replacing either of these are cheap yeah?
Cost vs Risk. Is the risk of replacing your motor worth the cost of not replacing these items?
Old 10-16-2010, 03:39 PM   #14
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
do you already have your swap?
S14 SR and RB25 is the same price on zetrolift
REVIEW
killer240 is offline   Reply With Quote
Old 10-17-2010, 07:05 PM   #15
Drifting-pedobear
s14sr > RB25 nuff said
RIGHTWHEELDRIVE.com
Old 10-18-2010, 12:59 AM   #16
penco
penco is an unknown quantity at this point
Im going through the same process right now. It ends up being expensive but a lot of stuff you might as well do it while the engine is out and apart, such as the timing chain and oil pump. I was just going to replace the pistons. Ended up replacing the rods, all gaskets, bearings, oil pump timing chain, etc.. I say just save up for the extra parts before you put it all back in. Also nissanparts.cc is the cheapest site for most of the parts listed.
penco is offline   Reply With Quote
Old 10-18-2010, 09:52 AM   #17
JonGu
JonGu's Avatar
JonGu is an unknown quantity at this point
thenismoshop.com (west covina nissan) also has great pricing for the timing chain and oil pump. it's alot of money but I plan on purchasing those later this week for my swap too.
JonGu is offline   Reply With Quote
Old 10-19-2010, 08:04 AM   #18
SR20Driftking4lyf
SR20Driftking4lyf's Avatar
SR20Driftking4lyf is an unknown quantity at this point
I did just about all the above listed with my SR before swapping, BUT wish I would have spent some more time and thought when it came to cleaning up the engine bay along with wiring while everything was easily accessable. Just my
SR20Driftking4lyf is offline   Reply With Quote
Old 10-19-2010, 08:09 AM   #19
xiaphin
Trader Rating: (32)
xiaphin is an unknown quantity at this point
Feedback Score: 32 reviews
Send a message via AIM to xiaphin
SPL has a clutch fork pivot cheaper than the nismo. I'm sure its just as good if not better, considering all their other quality parts.
2018 Audi RS 3 | Unitronic Stage 1 ECU and Stage 2 TCU tune
xiaphin is offline   Reply With Quote
