Old 12-13-2010, 12:02 PM   #1
Zenk1_love
Zenk1_love's Avatar
Zenk1_love is an unknown quantity at this point
RB20 "click" but no start
Quick background:
95 240sx
RB20det
Wiring conversion done by Yuri at Wiring Specialties
Using Their pre-made lower harness. Both pieces excellent work
Anyway, I have everything hooked up. I've gone over the whole harness several times. Everything is grounded. Put the key in, lights come on, fuel pump comes on, when I go to start it, I get a loud "Click" from the starter, then nothing. It doesn't continue to make the noise. Just one and done. Could my starter just be bad? I'm really at a loss here. Any help is much appreciated.
Edit: The 75 amp fuse in the fuse box was blown, replaced it today, still does the same thing.
UPDATE:
Turns out I was grounding the starter from the solenoid post so it wasn't maintaining voltage. Now it cranks no problem, but doesn't ever start. It's getting fuel. But no spark. I checked the voltage in and out of the ignitor and everything is good there. Could by coil packs be shot? How can I test them? Thanks for the help.
Zenk1_love is offline   Reply With Quote
Old 12-14-2010, 10:01 AM   #2
nissanguy11
nissanguy11's Avatar
nissanguy11 is an unknown quantity at this point
check the starter wire. the one that connects to the starter itself.
wiggle it and have someone try and start it, it might just have a shitty connection.
nissanguy11 is offline   Reply With Quote
Old 12-14-2010, 10:31 AM   #3
Sileighty_85
Sileighty_85's Avatar
might be insufficient grounds from the Engine to the chassis
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-20-2010, 07:23 PM   #4
Zenk1_love
Zenk1_love's Avatar
Updateded.
Old 12-21-2010, 06:29 PM   #5
nissanguy11
it could be coilpacks, but its very unlikely that they would all blow at once.
check your cam angle sensor (CAS)
and check your relays i think its the eccs relay and the ignitor relay.
i had the same problem with my car, it was one of the relays.
it was a simple fix swap out the relay and bam it fired right up.
Old 12-21-2010, 07:29 PM   #6
Zenk1_love
Zenk1_love's Avatar
Are those the two green ones by the ecu? I did the ecu diagnostic and it was throwing any codes, so I assume that rules out the CAS.
Old 12-21-2010, 08:28 PM   #7
nissanguy11
yeah the two by the ecu.
theres an easy way to check your CAS...
You should be able to spin the CAS by hand and hear the injectors click and see the coilpacks fire. if that happens...your good.
Old 12-22-2010, 08:41 AM   #8
qu0vad1s
qu0vad1s is an unknown quantity at this point
I had a similar issue, had a relay failure...
Dunno on your harness but mine has 2 brown relays near the ECU... check them out.
qu0vad1s is offline   Reply With Quote
Old 12-22-2010, 09:33 PM   #9
copermn
copermn is an unknown quantity at this point
Hmmm sounds like a starter problem to me, go get it check out or do it yourself.. other than that I'm not sure. That's just my .02
no
copermn is offline   Reply With Quote
