why my AFR's are high? sr20det
well i got hooked up to a wideband and did a few pulls...setup is weird but ok..vacuum hooked up to bov and wastegate the afrs where shit like 13 down to 11.9 running 4-5psi running lean which leads to detonation and that i dont want...2nd set of pulls where with the wastegate vacuum disconnected running 12psi at 11.7 down to 10.8 running good....so why is this?...i was just told that the DP has a hole in it and coverd by exhaust wrap and my guess is that would through it all off correct. and what is the correct timing for this motor?
![]() Join Date: Feb 2006
That doesn't seem high enough for detonation.
Which timing are you talking about? Mechanical timing? I think its 15* BTC. That could be completely wrong though. I'd have to look. Edit: I also dont understand why your AFR's were more lean at a lower psi. You sure that gauge is right? |
I guess I was right. Mech timing is 15* BTC. Check the FSM on how to stab the CAS. Set it to TDC and line the dot up with the first mark on the CAS and push in till it lines up with the second mark.
1. What modifications do you have to your motor? What engine management are you using? 2. You need to fix that exhaust leak. If it is anywhere before the last bend in the dp it can change the AFR reading not to mention sap power. 3. Also where do you have your bung reading your AFR's from? |
#6 | |
the motor is stock just a turbo mani,screamer pipe and dp with a hole in it the bung is down below in the dp right after the bend i have no engine management |
![]() Join Date: Aug 2010
hi,
my wideband show me 20 when it is in lean cruise and 16 when i have boost pressure why??? i have a sr20det with following: gt28r (stock boost pressure) big intercooler 3" exhaust (complete, turbo elbow, downpipe ...) stock ecu stock injectors big apexi air filter |
