Old 02-12-2011, 07:49 PM   #1
PS13 DRFT
PS13 DRFT's Avatar
Trader Rating: (18)
PS13 DRFT is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to PS13 DRFT
RB won't turn over
I just recently got one of the Wiring Specialties wiring harnesses and before that I had not ever started my RB. I connected everything, and when I turn the key the fuel pump primes, but when I turn the key to "start" nothing happens. I hear the relay click, and that's it.
Then I found out the spade connector wasn't giving any signal, so I tried to bypass it and wire power straight to the spade on the starter... while the engine turned over, it would still not start.
Any ideas? I'm stumped at this point.
PS13 DRFT is offline   Reply With Quote
Old 02-12-2011, 08:09 PM   #2
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
Are you sure the fuel lines are on right? I had mine backwards at first. If it will turn over but not start make sure to check for fuel and spark.
smoked240 is offline   Reply With Quote
Old 02-12-2011, 08:37 PM   #3
Sileighty_85
Sileighty_85's Avatar
while jumping the starter you need someone to Turn the key as if you were to start it normally
If its an S14 chassis check the Fuses under the hood
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 02-13-2011, 08:50 AM   #4
PS13 DRFT
PS13 DRFT's Avatar
Trader Rating: (18)
I was the one turning the key while I had my friend using another car battery to jump the starter.
it's an s13 chassis with a S2 rb25det
Old 02-13-2011, 11:39 PM   #5
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
can you hear a click coming from the starter . your starter might be pooched
1992 240sx (RB20. 362whp@16psi)
eklips3 is offline   Reply With Quote
Old 02-14-2011, 07:23 AM   #6
PS13 DRFT
PS13 DRFT's Avatar
Trader Rating: (18)
Starter is good, I actually swapped it with another when that was my first guess.
Old 02-14-2011, 08:14 AM   #7
wowitsaboy
wowitsaboy's Avatar
wowitsaboy is making a name for him/her selfwowitsaboy is making a name for him/her selfwowitsaboy is making a name for him/her self
Send a message via AIM to wowitsaboy
so now it turns over but does not start?
compression check, check plugs, check injectors?
exhaust system free of obstruction <(this one has happened to me, hollowed out my CAT, started right up).
here the formula: +10 (-5) .. EX: 205/55 becomes 215/50
wowitsaboy is offline   Reply With Quote
Old 02-20-2011, 04:53 PM   #8
PS13 DRFT
PS13 DRFT's Avatar
Trader Rating: (18)
Update on info... I got the engine to turn over with the key now. Also, I checked my plugs and such and there was water near the coilpacks. I decided to swap out the plugs and clean up the coilpacks. A friend of mine suggested to spray some starter fluid in the cylinders while the plugs were out... So I did.
The car still turned over very slowly, but it started, revved to maybe 2500rpm or so, then died back out, and wouldn't start again. So now I'm beginning to think it IS a fuel issue. I'm going to look into that next. Any other suggestions?
Old 02-28-2011, 06:48 PM   #9
PS13 DRFT
PS13 DRFT's Avatar
Trader Rating: (18)
YouTube - RB25DET first start
Some issues resolved...
See how slow it cranks? Has anyone ever had to shim a starter on a Nissan or RB? I'm thinking it could be that...
Old 02-28-2011, 06:54 PM   #10
Sileighty_85
Add more grounds
後輪駆動車1番
1986 SR86 - 200ish
Old 02-28-2011, 07:22 PM   #11
PS13 DRFT
PS13 DRFT's Avatar
Trader Rating: (18)
My block has 2 grounds now, do you really think it needs more?
The starter gets hot when I try to turn it over. Same with my battery though... hmm...
Old 02-28-2011, 07:37 PM   #12
Sileighty_85
Sounds like it.
Make sure whatever ur grounded to is not painted over. If need add a ground to the starter.
後輪駆動車1番
1986 SR86 - 200ish
Old 02-28-2011, 08:15 PM   #13
PS13 DRFT
PS13 DRFT's Avatar
Trader Rating: (18)
Originally Posted by Sileighty_85 View Post
Sounds like it.
Sounds like a plan, if you think of anything else, please do let me know! (=
Thanks!
Old 03-05-2011, 06:38 PM   #14
PS13 DRFT
PS13 DRFT's Avatar
Trader Rating: (18)
All grounds checked, starter ground added and the same issue exists.
I guess I'm just gonna wait on another starter and a redtop and see if that helps any..
Old 03-05-2011, 09:19 PM   #15
Sileighty_85
is the battery to the chassis an adequate ground?
後輪駆動車1番
1986 SR86 - 200ish
Old 03-06-2011, 08:36 AM   #16
ESone3
ESone3's Avatar
ESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of light
Again I say, theres a short. Check wiring. Make you don't have any exposed wiring. Starter is wired directly to the battery so make sure there are no shorts on there. Get a volt meter and check voltage at the starter. If its not 12+ volts, you are not getting enough power.
www.illgarage.com
ESone3 is offline   Reply With Quote
Old 03-06-2011, 03:07 PM   #17
PS13 DRFT
PS13 DRFT's Avatar
Trader Rating: (18)
Tommy! I DID. I'm getting enough voltage to the starter. I even re-did my power with 0gauge instead of 4gauge. I used sand paper and took the paint off of everything that was grounded. New battery ground is 0gauge also.
Old 03-06-2011, 05:51 PM   #18
Sileighty_85
The starter grounds it self though the casing, maybe there is corrosion in between the block and the stater housing?
後輪駆動車1番
1986 SR86 - 200ish
Old 03-06-2011, 06:09 PM   #19
PS13 DRFT
PS13 DRFT's Avatar
Trader Rating: (18)
Hmm a possibly scenario... I suppose I'll see next weekend when I put my new starter on.
Old 03-06-2011, 06:38 PM   #20
slickback420
slickback420 is an unknown quantity at this point
From your video it seems like you have a weak battery. RB's take alot of juice to start up.
Change the battery to one with high cranking power. And if that still doesn't fix it, Try using a jumper wire straight from the starter solenoid and jump it to the battery to see if it cranks better.
And if it still is weak then change the starter.
And whats up with your idle? you must have a bunch of vacume leaks or something??
slickback420 is offline   Reply With Quote
Old 03-06-2011, 07:35 PM   #21
PS13 DRFT
PS13 DRFT's Avatar
Trader Rating: (18)
I have a battery with 950 cold cranking amps right now... can't get much more boss than that. The idle was like that due to not having a coupler on, and possibly having a bad TPS.
Starter is already on the way... fingers crossed.
Thanks though!
Old 03-07-2011, 05:32 PM   #22
rbpwr
rbpwr is an unknown quantity at this point
u mentioned the battery gets hot? i had a optima yellow top that did the same thing in my car and wouldnt start, same as u dumb ? but have u tried another battery, mine dropprd a cell and got so hot i thought it was gonna burst. also batteries should never get to were u say there hot without it being the culprit
rbpwr is offline   Reply With Quote
Old 03-07-2011, 06:22 PM   #23
PS13 DRFT
PS13 DRFT's Avatar
Trader Rating: (18)
That's what I thought, I had one batter, dropped it for another, and tried a brand new red top today too... all having the same issue.
