Old 04-22-2011, 03:12 PM   #1
Mi BEAN
Mi BEAN is an unknown quantity at this point
RB25DET speed sensor
Ok i just found out that im running a ka speed sensor in my rb25 tranny. well after research i found out that the rb needs the sensor to go deeper (thats what she said) to get the right reading. here is my question does anyone know of an interchangeable sensor off another car or where to get an rb25 speed sensor?
Mi BEAN is offline   Reply With Quote
Old 04-22-2011, 05:53 PM   #2
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
I heard you need the na z32 speed sensor
WARNING: User has a low tolerance for stupidity. Post at your own risk.
redline racer510 is offline   Reply With Quote
Old 04-22-2011, 07:44 PM   #3
Sileighty_85
Sileighty_85's Avatar
if its in an S14 I might work just fine with the speedo.
Mine did
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-22-2011, 07:49 PM   #4
Mi BEAN
Mine did
you used the ka sensor in an rb tranny? they are different lenghts
Old 04-22-2011, 08:52 PM   #5
Sileighty_85
it was the RB with stock S14 cluster
後輪駆動車1番
1986 SR86 - 200ish
Old 04-22-2011, 08:30 PM   #6
kevin_s13.5
kevin_s13.5's Avatar
kevin_s13.5 is an unknown quantity at this point
Mine did
My s14 worked fine also. No real calibration was needed. Rb25 sensor btw.
kevin_s13.5 is offline   Reply With Quote
Old 04-22-2011, 07:47 PM   #7
Mi BEAN
could be true. i just wonder about the right gearing and the right length. i found this link about it and the first two pictures about speed sensors look like the diagram i seen before but then the picture after that they look short.
Photo Guide to the Z32: Sensors
Old 04-23-2011, 08:58 AM   #8
Mi BEAN
I pulled this from a search. notice how the gears are different on each one? maybe the actual sensor is the same but the gearing is different??
http://zilvia.net/f/tech-talk/240385...trans-s13.html
Old 04-23-2011, 11:12 AM   #9
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
When i'm going 50mph my speedo reads 15mph haha. I have the rb sensor, what if i put the KMPH guage on? Would that work?
singlecamslam is offline   Reply With Quote
