![]() Join Date: Sep 2005
![]() ![]() ![]() Feedback Score: 7 reviews
SR20DET 3071r Dyno
Hi Guys,
I just wanted to post this up. I finally dyno'ed my S13 SR that I put together a couple months back. I was pretty impressed with the results and just wanted opinions. It did 408.5 whp @ 16.9psi. Setup: CP pistons 8.5 cr 86.5mm Stock Rods ACL bearings Cosworth 1.1 head gasket ARP studs BC 264's BC springs and retainers Greddy adjustable cam gears Enthalpy rom tune Sard 850cc Greddy intake mani Peakboost turbo mani Garrett GT3071 w/ ATP turbo .63 a/r & 3" vband exit Tial MV-S It was dyno'ed on a DYNOCOM dyno. ![]() Coming from a 2871r setup, I expected this turbo to be a little laggier. But it honestly out spools my 2871r. On the street, it hits 17psi around 3.8k. I was told that boost plot on the dyno wasnt very accurate.
It's a huge improvement over my 2871r. My 2871r setup was identical other than the exhaust mani and intake mani and it made 337whp at 19psi. The 2871r made more power up to 5.5k but after 5.5k it tapered off. Where as the 3071r pulls pretty good before 5.5k and but really starts to shine after that. I know the intake mani has a little to do with that as well.
Ive only ran it a few times at a the local 1/8th mile track and the best i could get on some 245 feddies was a 8.0 @ 94.3 mph with a 2.0 60'. Had major traction issues.
![]() Join Date: Dec 2004
Trader Rating: (58)
Seems like torque comes on very late/lazy? What tune, intake manifold, cams are you runnign?
Some changes in the above mentioned things and you could easily have a 425+ whp car, and torque coming on much sooner.
![]() Join Date: May 2006
he should push up to 450 with a better tune using a standalone
#7 | ||
What do you mean by the torque? Mine seems to be similar to the other dyno sheets I have seen with the same setup. Quote:
You really think a standalone would net me that much more power?
If you did make more, probably not more then 420whp at the same psi (17psi), I think standalone is just a good investment in terms of flexibility and safety.
Thanks for the compliments. I've been out of town for a while and couldn't get back on zilvia.
Could you elaborate a little more on this cody? I have my setup posted in the first post.
My motor was rebuilt with oem parts about 20k miles ago. I'm currently running a GT2871r .64 and just had it dyno'd tuned with an Apex'i PFC about 6 months ago. You think it'd be safe to just change out the injectors, exhaust manifold, turbo, and retune without upgrading to stronger internals.
the full GT30 trim 3071 is much more responsive then the 2871
im talking about the 60mm turbine trim T3 version of the 3071 it is much more responsive compared to the 2871 |
Trader Rating: (58)
Got any dyno run files? I'd love to see those claims over time, as I've yet to be in any 30r varient car to get near a 2871 or 28RS in terms of off boost response and or torque ramp up.
#15 |
![]() Join Date: Jun 2010
nice build and numbers! personally,i would think a 3076 would be a better choice for an all out t3 setup...if you wanted a 71mm compressor you could have stayed bottom mount. and i doubt a 3071 will spool faster than a 2871. this is because the gt30 .63 turbine is slightly larger than a GT28 .86 and would therefore spool slower. that dyno sheet shows the 3071 coming up on 15psi at 5500 RPM
#16 |
#17 | |
#18 |
![]() Join Date: Mar 2011
A bit late but was the GT2871R on an external gate like the T3 GT3071R?
www.motoredge.wordpress.com |
