Old 05-10-2011, 04:43 PM   #1
donandal
donandal's Avatar
donandal is an unknown quantity at this point
PlusONETEN build
This is the build thread for a project dreamed up by my oldest son, Allen
I had spent the previous four years building from scratch, a custom two seat aluminum body roadster with a Subaru 2.5 five speed all wheel drive. He got the build bug. He wanted to do an engine swap into a 240SX. We decided to try to find one. After about a year, he located this rust-free original paint coupe in Miami, Fla. We made a road trip all-nighter from Miami about two years ago in February, 2009. While he was searching for the car, he decided on the vq35 engine swap. We went to work locating a donor car for the swap. I found this 2008 350Z on an insurance auction website about 3 months later, in Salem, Mass. My wife and I made the round trip in a day, hauling it back on a rented car hauler trailer, to my shop in Lakewood, N.Y.
After we got it home and looked at it, we decided it had so many things that would work in the 240SX coupe, that we would do a lot more swapping. It has been about two years now and the swapping is done. We ended up using the 350Z engine, tranny (six speed), clutch master cylinder, steering column, entire dash, rear diff and entire wiring harness and emissions system.
We started by stripping the S13 down to the sheet metal, cataloging all the parts as they came off. Then we started rough fitting components just by eye, to see how things lined up. First was the engine fitting; it was pretty tight, but it fit, we decide early on to remove the top cross-member above the radiator and fabricate bolt flanges to make it easy to get it in and out. The engine mount cross-member needed to be modified by cutting, lowering and re-welding to use the original Z engine mounts. We also fabricated a new tranny mount, and reworked the rear diff sub frame to use the Z limited slip with 95-98 five bolt hubs and custom axles from the Drive Shaft shop. They also supplied a custom driveshaft. We looked at the dash and gauges and, thought about the options, and decided to use the entire dash and wiring harness. We used the 240 gas tank and modified it with a second riser and flange to accept the two sending unit harness. We also used all emissions systems. The dash was just a little too wide to fit but we just cut it short and fabricated. The exhaust didn’t fit but with a little chopping and welding it just clears the firewall. We also kept all of the heat/air controls and slipped them into the dash.
Allen wanted to get 265’s under all four corners, and we soon determined we would need to fab our own strut cartridges and coilovers, and rear coilovers as well. Some research on the web, and my son had the info on what struts, springs, shocks, and wheels and tires would work. We made our own camber plates and strut braces as well. There have been a lot of other little things along the way. One thing that we did come to realize was just how many things were compatible from these two cars built 16 years apart. The wiring harness chassis ground points lined up, the bolt pattern and screws on the sending unit were exactly the same, the steering column splines, the axle splines, just a lot of things worked out nice.
We are finishing up the interior now and will probably drive it for a year or so then get it painted. We already painted the engine compartment Millennium Jade, the color he chose. He has plans for a body kit and some other mods later, but we’ll see.
Now I’ll try and post some pics with explanations
this is the day we brought it home
we worked over the winter and pulled everything off
not much left of the Z
the donor car , a 2008 350Z
the cross mount was modified, slots are where engine mounts go, here it is primed with brush on enamel
we also fabricated a new tranny mount using original chassis points
the headers were shortened to clear the firewall
I fabricated this coupler so we could use stock cat converters
here it is installed on engine, I added extra heat shields on firewall because it's pretty tight
this shows the stock shifter support, and our shortened steel one
the shifter sits a little farther back
this is the rework of rear subframe to house Z limited slip diff
we reused the z rubber mount and added a brace that will also carry exhaust hanger, as shown above. These two
show the bottom side as we worked on it
since we are using all of the Z wiring we decided to keep both sending units in the tank
one is also the fuel pump unit, here fitting it to spare tire area, it will be soldered and then sealed
closing off the spare tire area, this top will be bolted together in case of service access, no room for spare,
but we can use it for tools and storage
we bought a radiator from Griffen, and built our own shroud from .060 aluminum, used 350Z fans
we also built a radiator overflow tank
making our cold air intakes
this will be capped off on top, air draws from front, we used dry type cone filters, the box is sealed around
the tube with foam rubber to allow engine shake, air can only enter tube thru filter end,even if foam wears out
Allen wanted to get 265/40/17s on all four corners, to get enough clearance we fabricated our own strut
housings with about 1 inch more offset at the lower ears
we also made our own threaded coilover converions
we ended up with about 3/8 " tire clearance
we used koni shocks and struts, the rears are an eclipse model,with adjustment at the top, same as the front
our camber plates, stainless steel with 5/8 spherical bearing and a 1 and 15/16" thrust bearing. with our custom
spring top hat , we tucked the spring in above the tire
no room for the battery
here you can see the strut tower braces.....
so it went in the trunk in this sealed and vented stainless battery box we made. the vent goes out the cabin vent
panel in the rear wheel well area of the trunk
the other side of the trunk, this protects the stereo amp and radio/phone/antennae components
we needed to protect that low sitting aluminum oil pan
so we built this skid plate, the mesh is painted stainless steel
some work on the interior, I am building the center console
fitting it to the Z dash
after I covered it in black vinyl
here is the headliner, I recovered it with headliner material that had a foam backing, that is the Z mirror
This just about brings it up to date...the carpet is in and I am installing the seat belts...two side panels of the
dash need to be fabricated and covered in vinyl...package tray needs to be covered...I'll post more pics shortly
I have hundreds of photos so if something strikes your interest and you want more details on something,
let me know
Thanks
donandal is offline   Reply With Quote
Old 05-10-2011, 04:56 PM   #2
dued
dued's Avatar
dued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymore
Bravo young chap. Bravo.
dued is offline   Reply With Quote
Old 05-10-2011, 04:57 PM   #3
Wheelchair
Wheelchair's Avatar
Wheelchair is an unknown quantity at this point
this is insane! there have been cool build threads on zilvia... but i really like this one.
Good work!
Wheelchair is offline   Reply With Quote
Old 05-10-2011, 04:58 PM   #4
Coz@Czp
Coz@Czp is an unknown quantity at this point
Good shit!!!!
Coz@Czp is offline   Reply With Quote
Old 05-10-2011, 05:00 PM   #5
bejota180sx
bejota180sx's Avatar
bejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura about
great build! it's good to see more real builds going on zilvia!
Originally Posted by Taniguchi_Is_#1 View Post
...this is zilvia; prepare to get your feelings hurt.
bejota180sx is offline   Reply With Quote
Old 05-10-2011, 05:04 PM   #6
Wake
Wake's Avatar
Um may I be the first to say............
HOLY SHIT BATMAN!!!!
Welcome to zilvia, we need more like this.
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 05-10-2011, 05:07 PM   #7
R33E8
R33E8 is an unknown quantity at this point
My friend who bought some stuff from you (I think a ka and some other stuff) was telling me about this..
wow..
R33E8 is offline   Reply With Quote
Old 05-10-2011, 05:16 PM   #8
donandal
donandal's Avatar
wow..
Hey
how is he doing on that project?
Those three kids who came to get the engine
were great kids....funny to see them stuff it into the back
of that mini van....there wasn't any room left to sit and they had
a long drive home, I think the day before father's day a year ago
Old 05-10-2011, 05:09 PM   #9
slomar91
slomar91 is an unknown quantity at this point
This is amazing.
slomar91 is offline   Reply With Quote
Old 05-10-2011, 05:18 PM   #10
deolio
deolio's Avatar
wow this is an awesome build.
looks like it won't be able to go very low though due to how low the engine/tranny sit
deolio is online now   Reply With Quote
Old 05-10-2011, 05:33 PM   #11
Phate
Phate's Avatar
Phate is an unknown quantity at this point
Wow looks awesome. A lot of good fab going on here.
I wanna slide.
Originally Posted by nate1 View Post
8. they all smell funny
Phate is offline   Reply With Quote
Old 05-10-2011, 05:31 PM   #12
Backintoans13
Backintoans13's Avatar
Backintoans13 is an unknown quantity at this point
Sick build!! Crazy workmanship
Backintoans13 is offline   Reply With Quote
Old 05-10-2011, 05:33 PM   #13
donandal
donandal's Avatar
I've got a few pics here of the car on wheels
we rolled the fenders and lowered it to allow the tires to just miss the inner fenders by about an 1/8 " at full bump coil bind and this is how it looks
there is about 3.5 inches from the skid plate to the ground
the rears aren't rolled yet in this picture
Old 05-10-2011, 05:52 PM   #14
sickstatus
sickstatus's Avatar
sickstatus is an unknown quantity at this point
Send a message via AIM to sickstatus
Very sick build thread.
straights are for fast cars, corners are for fast drivers.
sickstatus is offline   Reply With Quote
Old 05-10-2011, 05:52 PM   #15
str84dapokie
str84dapokie's Avatar
str84dapokie is an unknown quantity at this point
only on zilvia would someone be sad a car cant go low when it was built like this smh....
i saw this car in person and this swap is scary clean...
it just looks great... cant wait to hear what it sounds like...
but that f**king garage is... AMAZING!!!! if only it wasnt a 6 hour drive
Heh Don we had to lay that KA to rest but the trans lives on. lol
www.iDigsThat.com
....Check it out....
str84dapokie is offline   Reply With Quote
Old 05-10-2011, 06:02 PM   #16
donandal
donandal's Avatar
I hope it wasn't a bad engine we sold you... I'd be happy to send your money back... let me know
Old 05-10-2011, 06:19 PM   #17
str84dapokie
s14
def wasnt a bad engine my lil cus who came with me out there had some fun with it before he sold his s13 shell... car sold engine gone...
the trans is what i wanted but the price was to good to not get both from you...
his build is going good i'll send you the pics of that..
my build is just a pile of parts now but soon to come together
www.iDigsThat.com
Old 05-10-2011, 06:27 PM   #18
donandal
donandal's Avatar
good to here it wasn't a bad engine...
hope all is well with you and your cousin and friends
you are allways welcome to stop in if you are up this way
I'll be looking for the pics
Old 05-10-2011, 05:58 PM   #19
str84dapokie
..... and that roadster of yours is sick!!!!!
www.iDigsThat.com
Old 05-10-2011, 06:01 PM   #20
drftwerks
pics of roadster.
please.
giantroboteyes.wordpress.com/
Old 05-10-2011, 06:06 PM   #21
donandal
donandal's Avatar
Originally Posted by drftwerks View Post
pics of roadster.
please.
ok I'll post the build here
Old 05-10-2011, 06:04 PM   #22
herbieS13
herbieS13's Avatar
herbieS13 is an unknown quantity at this point
Send a message via AIM to herbieS13
this build looks like such an epic win it disgusts me...subscribed
herbieS13 is offline   Reply With Quote
Old 05-10-2011, 06:11 PM   #23
Drft_S14
Drft_S14's Avatar
Drft_S14 is making his/her stupidity well-knownDrft_S14 is making his/her stupidity well-knownDrft_S14 is making his/her stupidity well-known
Wow .. the Fabrications are awesome!!!! the Fan shroud and the suspension are my fave ! good job sir!
I never narc'd on nobody
Drft_S14 is offline   Reply With Quote
Old 05-10-2011, 06:19 PM   #24
donandal
donandal's Avatar
the subie is posted in chat now
Old 05-10-2011, 06:23 PM   #25
Phlip
Yes, I look like that
Phlip's Avatar
I had to move it to off-topic.
Also, you could make a killing selling those consoles
Weirdo
And I write too!
Old 05-10-2011, 06:37 PM   #26
donandal
donandal's Avatar
sorry ...and thanks for moving it
that console has probably a weeks work in it
I couldn't build it and sell it for a profit...oh well
Old 05-10-2011, 06:40 PM   #27
Phlip
Phlip's Avatar
No problem, I would have sent a lesser thread to the graveyard, so thank YOU.
If you don't mind me asking, what do you do professionally, like for a living?
Weirdo
And I write too!
Old 05-10-2011, 06:29 PM   #28
treken2t87
treken2t87's Avatar
treken2t87 is a glorious beacon of lighttreken2t87 is a glorious beacon of lighttreken2t87 is a glorious beacon of lighttreken2t87 is a glorious beacon of lighttreken2t87 is a glorious beacon of lighttreken2t87 is a glorious beacon of lighttreken2t87 is a glorious beacon of lighttreken2t87 is a glorious beacon of lighttreken2t87 is a glorious beacon of lighttreken2t87 is a glorious beacon of lighttreken2t87 is a glorious beacon of light
Top notch build. Very great attention to detail here.
Also kudos for offering a refund on a transaction over a year ago
treken2t87 is offline   Reply With Quote
Old 05-10-2011, 06:56 PM   #29
tricky_ab
tricky_ab's Avatar
This is great work so far!
Old 05-10-2011, 07:04 PM   #30
Okinawandrifter87
Okinawandrifter87's Avatar
Trader Rating: (22)
Okinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfection
Feedback Score: 22 reviews
I am thoroughly impressed which I dont say too often here on Zilvia with alot of build threads.
Driftphreak87
Okinawandrifter87 is offline   Reply With Quote
