Old 11-21-2011, 08:25 AM   #1
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
Enkei-Greddy-Cusco-Stoptech-Seibon-ETS-Precision-Tial-Comp clutch-Mazworx-TONS MORE!
THIS IS THE OLD THREAD, CHECK FOR THE NEW THREAD!!!!!!!!!
1. NO BASHING PRICES OR PARTS! if you dont like it, please leave!
2. If you PM, please also bump the thread.
3. Im always adding more parts and pictures to the thread, so check back every so often.
4. More parts have been added as of...11-29-11
Mazworx SR20DET Engine- I WILL NOT PART OUT THIS SR!
HEAD-
New SR20DET Head- $500
Stage 2 Port and Polish- $800
Polished Combustion Chamber- $210
Full Radius Valve job- $200
Tomei Intake Cam Gear- $200
HKS Exhaust Cam Gear- $200
Tomei Solid Lifters- $280
Tomei 270 Cams- $600
Brian Crower Springs and Titanium Retainers- $220
Supertech Valves- $300
HKS Rocker Arm Stoppers- $100
SR20DET Powder Coated Valve Cover- $150
Greddy Oil Cap- $80
New Muli-layer Exhaust Gasket- $80
New Cam Angle Sensor- $330
New Rocker Arms- $150
BLOCK-
SR20DET Redtop- Cost of a core block- $100
CP Pistons 86.5mm 9.0 CR- $525
Golden Eagle Sleeves- $375
Manley Turbo Tuff Rods- $725
Calico Coated ACL Race Bearings- $210
ARP Main Studs- $185
Balanced & Polished Crankshaft- $200
ATI Crank Pulley- $425
Greddy Oil Pan- $300
New Water Pump- $65
New Oil Pump- $375
Upper Oil Pan- $50
Sleeving- $280
Bore/Hone- $320
Whatever I Forgot- $X
TOTAL= $8,535.00+
ASKING= $5,000 OBO
PHOTOS:
R33 Rb25 series II~15k miles since rebuilt- $1,800 obo SOLD!
Arp head studs
Arp main studs
Tomei triple metal head gasket
PHOTOS:
Q45 90mm Throttle Body SOLD!
- Perfect Shape
- $80
RB25 Exhaust mani ceramic coated- $550 SOLD!
Tial 38mm waste gate- $175 SOLD!
Precision 5557 t3 t4 turbo- $650 SOLD!
Mcckinny mounts- $300 SOLD!
Rb20 trans- $200 SOLD!
Competition stage 4 6 puck clutch- $300 SOLD!
Has 4/6 spitfires that come with it- make offer SOLD!
Waisted spark assembly- make offer SOLD!
rb25 to s13 Engine Harness w/ ecu- make offer SOLD!
rb25 Alternator SOLD!
- Perfect Shape
- $125
6 370cc injectors in rb25 fuel rail SOLD!
- Used
- $150
sr to vg adapter plate SOLD!
- NEW!
- $400 shipped
Enkei RPF1
17 X 9.5 +18
17 X 10 +15
- ~2k miles
- $900
Cusco SR motor mounts
- ~1k miles
- $200
350z Stock arms
- ~20k miles
- Make offers
350z Master 1 1/16th
- Perfect Shape
- $60
350z Brake Booster
- Perfect Shape
- $125
350z 03' tinted tail lights
- Great shape
- $150
350z Seibon Carbon Hatch
- ~5k miles
- $550
350z Stoptech floating 355x32mm AeroRotors
- ~3k miles
- $500
350z Seats
- ~20k miles
- $500
350z oem Radiator
- ~20k miles
- $100
TurboSmart Megasonic Blow Off Valve
- ~1-2k miles
- $150 + shipping
Kisuu Custom Made Fuel Rail
- NEVER USED
- $150 + shipping
S15 Hood
- NEVER USED
- $250
ETS Custom Made Intercooler 24X8X3
- NEVER USED
- PERFECT SHAPE
- $175
Greddy Intake Manifold Modifide and Comes w/ Q45 (90mm) Throttle body- SOLD!
- Roughly 500 miles
- PEFRECT SHAPE
- $600
KU Engineering Intake Manifold
- Never Used
- $300
N62 Maf (no pigtail)
- Perfect Shape
- $125
Origin Canards w/ custom aluminum skid plates
- never used
- $175
Q45 Throttle Body
- Used
- $75
Unknown Brand BOV
- Slightly Used
- PERFECT SHAPE
- $50
ROSS TUFFBOND Water Pump Pulley
-ONLY MOUNTED
-PERFECT!
-$100
S14 SR20 88.5mm Cometic Metal Head Gasket multilayer
- NEVER USED
- PERFECT SHAPE
- $70
OEM SR20VE Valvetrain (IN+EX Valves, Springs, Cams, Gears)
- 15,000 Miles
- PERFECT!
- MAKE OFFERS ON WHAT YOU NEED!
S14 Non-ABS Driveshaft
- Used
- $120
S13 Non-ABS Driveshaft
- Used
- $120
S13 SR Transmision -
- Roughly 30k miles
- PERFECT SHAPE
- $150
These are all the make an offer items...i dont want or need them all so just make an offer...pictures of these upon request...its to many pictures for the thread.
S13 SR OEM Coil Pack Cover
BNIB SR Multi Layer Exhaust Gasket
BNIB OEM SR Exhaust Gasket
SR OEM Exhaust Manifold w/ Heat Shield
(1) V1 Godspeed S13 Toe Arm
(1) V1 Godspeed S13 Traction Rod
Valve Cover Coil Plug Gasket
Water Outlet
Water Inlet
(4) Cam Oil Tubes (2 Sets)
(16) OEM Spring, Retainer, and Keeper (1 set)
(8) SR OEM Intake Valves (1 set)
(8) SR OEM Exhaust Valves (1 set)
(8) SR OEM Rocker Arm (1 Set)
(8) SR OEM Lifter (1 Set)
SR Block (bare) w/ 87mm bore (needs align bore...roughly 200 at any machine shop)
SR20 Front Cover w/ Oil Pump
(2) Oil sandwich plate Galley w/ sensor
(2) Upper Oil Pan
(2) Water Pump
Water Pump Pulley
(3) Rear Crank Case Cover
Crank Pulley
(4) SR Oil Squirters (1 Set)
(3) SR OEM Rod
(4) Upper Oil Pan Screen (2 Sets)
(3) Different SR20 Timing Chain Guides
(3) SR Timing Chain Tensioner
(2) SR Main Cap Girdle
(2) Alternator Bracket
AAC Valve
(3) Knock Sensor
(3) Coolant Tubes
(2) Thermostat Housing
(2) Coolant Temperature Sensor Housing
3” S14 Exhaust that was very hacked up but it has a Very good condition HKS muffler
Turbo Blanket (was on a T67)
SR Transmission Plate
SR OEM Turbo Lines
S13 Rear OEM Chamber Arm
S13 Rear OEM Traction Arm
S13 Rear OEM Toe Arm
stock KA24de fuel pump (in working order)
stock KA24de header + stock heatsheild
stock KA24de airbox intake system and Filter is still clean
Summit Liquid Fuel Pressure Gauge
Thank You For Looking!
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 11-21-2011, 10:42 AM   #2
JonathanPrem
JonathanPrem's Avatar
JonathanPrem is an unknown quantity at this point
Can you give me the best price shipped for s13 sr spark cover, s13 sr valve cover gasket and spark plug gasket to canada ontario m1r5s1
JonathanPrem is offline   Reply With Quote
Old 11-21-2011, 11:05 AM   #3
d-man478
d-man478 is an unknown quantity at this point
Good stuff here. Bump for you
d-man478 is offline   Reply With Quote
Old 11-21-2011, 12:13 PM   #4
Drftr915
Drftr915's Avatar
Trader Rating: (22)
Drftr915 is an unknown quantity at this point
Feedback Score: 22 reviews
bump for a great guy to work with.
Drftr915 is offline   Reply With Quote
Old 11-21-2011, 05:11 PM   #5
Highlo630
Highlo630 is an unknown quantity at this point
Rb mounts work for both s13 and 14?
Highlo630 is offline   Reply With Quote
Old 11-21-2011, 07:53 PM   #6
Briou
Briou's Avatar
Briou is an unknown quantity at this point
Is the greddy intake with the q45 tb an s13 or s14/s15 intake...couldn't tell from pics...I will PM you aswell....great sale thread...Bump!!
Briou is offline   Reply With Quote
Old 11-21-2011, 11:21 PM   #7
TheRealSy90
TheRealSy90's Avatar
How much for an upper oil pan with screen and a good water pump to 85364? Thanks.
Such a good signature.
Old 11-22-2011, 07:06 PM   #8
Imarvin240
Trader Rating: (18)
LIST UPDATED WITH MORE PARTS!
more pics will be up this weekend!
Old 11-24-2011, 08:36 AM   #9
Trinidrift3
Trinidrift3's Avatar
Trinidrift3 is an unknown quantity at this point
Pm me pics of the canards?
Trinidrift3 is offline   Reply With Quote
Old 11-24-2011, 11:06 AM   #10
S14 James
S14 James is an unknown quantity at this point
Send me a E-mail on the RB Manifold (I'm assuming that is a T3)
[email protected]
-James
S14 James is offline   Reply With Quote
Old 11-25-2011, 04:19 PM   #11
Imarvin240
Trader Rating: (18)
Bump number 1!
Make offers people!
More pics up this weekend!
Old 11-29-2011, 02:53 AM   #12
Imarvin240
Trader Rating: (18)
BUMP NUMBER 2!
more photos/parts added. Also, more photos and parts will be added this week once i go through more of my storage unit.
please make offers to help fund the current car build. thanks guys.
Old 11-29-2011, 04:52 PM   #13
BryanR00
BryanR00's Avatar
BryanR00 is an unknown quantity at this point
Wow $5000 for a fully built SR by MazWorx is crack prices! Man if I had the money you'd best believe I'd be all over this. GLWS!
BryanR00 is offline   Reply With Quote
Old 11-29-2011, 08:29 PM   #14
pinkarrowsnow
pinkarrowsnow's Avatar
pinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura about
ugh i need these wheels! let me see if i can get some money together im local too.
pinkarrowsnow is offline   Reply With Quote
Old 12-03-2011, 05:35 AM   #15
Imarvin240
Trader Rating: (18)
10% off everything till December 10th.
get your Christmas shopping done now!
Old 12-03-2011, 07:38 AM   #16
venom2034
venom2034 is an unknown quantity at this point
cant get the pm window to open up. Im interested in the wheels. would you ship to new york?
venom2034 is offline   Reply With Quote
Old 12-03-2011, 08:03 AM   #17
Detroit.Tee.Tee
Detroit.Tee.Tee's Avatar
Detroit.Tee.Tee is an unknown quantity at this point
Hey Marvin,
I am interested in the McKinney Mounts. Those will fit on an RB25, I assume. Also, the trans mount is included?
Detroit.Tee.Tee is offline   Reply With Quote
Old 12-03-2011, 04:24 PM   #18
Q.Smooth127
Q.Smooth127 is an unknown quantity at this point
Damn...i wanted that sr greddy intake mani wit the q45 tb but it sold already ya?
Q.Smooth127 is offline   Reply With Quote
Old 12-03-2011, 06:02 PM   #19
TurboStrong
TurboStrong's Avatar
TurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really nice
do you have an rb25 power steering pump and brackets?
TurboStrong is offline   Reply With Quote
Old 12-05-2011, 03:13 AM   #20
Imarvin240
Trader Rating: (18)
yes, i will ship the wheels, engine, and everything except the hood and hatch.
Old 12-05-2011, 04:46 AM   #21
JohnJunYi
JohnJunYi's Avatar
JohnJunYi has made poor choicesJohnJunYi has made poor choicesJohnJunYi has made poor choicesJohnJunYi has made poor choicesJohnJunYi has made poor choicesJohnJunYi has made poor choices
Send a message via AIM to JohnJunYi
bump pm is about to be sent
JohnJunYi is offline   Reply With Quote
Old 12-05-2011, 08:04 PM   #22
240sxwanted
240sxwanted's Avatar
240sxwanted is an unknown quantity at this point
willing to part the rb25 head?
240sxwanted is offline   Reply With Quote
Old 12-06-2011, 12:22 PM   #23
Imarvin240
Trader Rating: (18)
Sorry guys, not willing to part out the engines. Only way that will happen is if you pay for the head gasket that would then be worthless and for my labor of taking everything apart...thats the only way.
Old 12-06-2011, 12:45 PM   #24
je_decoy
Trader Rating: (33)
je_decoy is an unknown quantity at this point
Feedback Score: 33 reviews
Would you post up some pics of the oil sandwich plates also what kind are they thanks glws
je_decoy is offline   Reply With Quote
Old 12-06-2011, 08:57 PM   #25
slow92
slow92's Avatar
slow92 is an unknown quantity at this point
Will the KU Engineering manifold accept a q45 throttle body or do I have to get an adapter?
Sr22 in the works
slow92 is offline   Reply With Quote
Old 12-08-2011, 05:47 PM   #26
Imarvin240
Trader Rating: (18)
you would need to get an adapter.
more parts/pics added
Old 12-09-2011, 09:56 PM   #27
AS240
AS240's Avatar
Trader Rating: (18)
AS240 is an unknown quantity at this point
pm sent
*bump it up*
AS240 is offline   Reply With Quote
Old 01-22-2012, 05:27 PM   #28
zneubauer
zneubauer's Avatar
zneubauer is an unknown quantity at this point
bump for yuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu.
zneubauer is offline   Reply With Quote
Old 01-22-2012, 09:47 PM   #29
dtfdanyo
dtfdanyo's Avatar
dtfdanyo is an unknown quantity at this point
would you split and sell the 17x9.5 separately?
tEAM tUCK
dtfdanyo is offline   Reply With Quote
Old 03-28-2012, 09:36 PM   #30
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Your oil pump was $375??
They are $240 brand new OEM O.o
Is it aftermarket?
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
