Old 01-19-2002, 01:24 AM   #1
student
student is an unknown quantity at this point
I want to get as much horsepower from my ka24de and I want toknow if 11.5:1 is ok to run on a ka24de. Will my pistons be hitting anything is there anything i have to worry about. Please enlighten me with your knowledge thanks.
student is offline   Reply With Quote
Old 01-19-2002, 10:12 AM   #2
Tuck&Poke
Tuck&Poke is an unknown quantity at this point
Send a message via AIM to Tuck&Poke Send a message via Yahoo to Tuck&Poke
make sure you use premium feul.  93+ octane cause if not youll be hearing the heart breaking sound of knock which is early combustion.
Tuck&Poke is offline   Reply With Quote
Old 01-19-2002, 10:16 AM   #3
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
True, that is pretty high... but you'll be naturally aspirated. Do make sure you use great fuel, good wires, and make sure your ignition is timed to stock specs. You should be OK.
(Edited by S13Grl at 11:18 am on Jan. 19, 2002)
S13Grl is offline   Reply With Quote
Old 01-19-2002, 05:12 PM   #4
wherezmytofu
wherezmytofu is an unknown quantity at this point
11.5 on 91
12.5 on 93
wherezmytofu is offline   Reply With Quote
Old 01-20-2002, 05:50 PM   #5
Ni5mo180SX
Ni5mo180SX is an unknown quantity at this point
Send a message via AIM to Ni5mo180SX
Just installing a set of high compression pistons isnt gonna give you a huge bump of HP. Your head should be rebuilt to take advantage of this too. And do you even know if your valves are gonna be hitting the top of these pistons or what type of pistons to use? What kind of head gasket are you gonna have on there? What kinda plugs? Im just saying I dont think its as easy as "great fuel, good wires, and make sure your ignition is timed to stock specs. You should be OK". Theres a little more to it then that.
Ni5mo180SX is offline   Reply With Quote
Old 01-20-2002, 06:11 PM   #6
duderiffic
duderiffic's Avatar
duderiffic is an unknown quantity at this point
Send a message via Yahoo to duderiffic
Shouldn't you always use Premium for a 240SX?  That's what my car said... do all 240s say that?
Jeff
98 SE.
duderiffic is offline   Reply With Quote
Old 01-20-2002, 08:07 PM   #7
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
yes, they all say "for best performance use preminum gasoline" or somthing like that... wha's the stock compresion ratio on a ka24? and wouldn't go 11.5:1 be killnig your gas?  u'll feel like u're in a ferarrie or somthing
240meowth is offline   Reply With Quote
Old 01-20-2002, 09:24 PM   #8
misnomer
misnomer's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">u'll feel like u're in a ferarrie or somthing</td></tr></table><span id='postcolor'>
Yerp, that's the idea <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=':p'>
240s will run fine on 87 and 89 octane, I usually feed mine 89
Stock compression is 8.5:1 on most 240s
(Edited by misnomer at 10:25 pm on Jan. 20, 2002)
Old 01-20-2002, 09:32 PM   #9
240meowth
that's more then 30% jump, dosn't that mean 30% more fuel comsumption? and you know ferries get like 8mpg... and stuff...
Old 01-20-2002, 09:54 PM   #10
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from misnomer on 9:24 pm on Jan. 20, 2002
I thought stock compression is 9.6:1 on most 240's.... 9.1:1 on the 90. &nbsp;
AceInHole is offline   Reply With Quote
Old 01-20-2002, 10:12 PM   #11
Guest
Posts: n/a
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from 240meowth on 10:32 pm on Jan. 20, 2002
actually i was reading SCC and they said a 1999 got around 30 mpg.......i think it's vipers that get the shitty mpg
Old 01-20-2002, 10:23 PM   #12
tnord
tnord's Avatar
tnord is an unknown quantity at this point
doesn't the RSX and ITR run like 11.1? i'm sure it gets good gas mileage relatively speaking
tnord is offline   Reply With Quote
Old 01-21-2002, 12:42 AM   #13
misnomer
misnomer's Avatar
Gah, who gets a sports car to worry about gas mileage? <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=':p'>
Old 01-21-2002, 12:49 AM   #14
tnord
tnord's Avatar
poor college kids like me
Old 01-21-2002, 02:25 AM   #15
Ni5mo180SX
umm, last time I checked, raising your compression wont lower your gas mileage. In fact it might raise it. The stock compression on the KA24E is 8.9.1 from what ive heard.
&quot;ka24? and wouldn't go 11.5:1 be killnig your gas? &nbsp;u'll feel like u're in a ferarrie or somthing that's more then 30% jump, dosn't that mean 30% more fuel comsumption? and you know ferries get like 8mpg... and stuff... &quot;
Increase in compression means an increase in efficiency which should raise your gas mileage.
Old 01-21-2002, 07:37 AM   #16
240 2NR
240 2NR's Avatar
240 2NR is an unknown quantity at this point
A diesel motor runs somewhere in the neighborhood of 20:1 compression. &nbsp;Last I checked a TDI gets somewhere in the neighborhood of 45mpg (that has a turbo too). &nbsp;Higher compression ratios are good, and will usually indicate higher efficiency. &nbsp;The reason fuel milage may suck is that to be safe, its better to add fuel then take away or stay the same (general rule, please don't reply back with &quot;I know this one car...&quot;). &nbsp;Same with turbos. &nbsp;You can either run really good engine management and get good milage or throw lots of fuel at it and be safe, but run kind of shitty.
Lots of people have been talking about getting better milage on a KA-T with stock internals over a standard KA on the highway. &nbsp;Maybe my dad would be happy about the upgrade if I told him that.
240 2NR is offline   Reply With Quote
Old 01-21-2002, 07:43 AM   #17
Logo
Logo is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from AceInHole on 11:54 pm on Jan. 20, 2002
You're right dude. &nbsp;It's 9.6:1
Logo is offline   Reply With Quote
Old 01-21-2002, 07:51 AM   #18
thewholefnshow
thewholefnshow is an unknown quantity at this point
Send a message via ICQ to thewholefnshow
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from 240 2NR on 7:37 am on Jan. 21, 2002
A diesel motor runs somewhere in the neighborhood of 20:1 compression. Last I checked a TDI gets somewhere in the neighborhood of 45mpg (that has a turbo too). </td></tr></table><span id='postcolor'>
Yah, but the also don't spin to 6500...
thewholefnshow is offline   Reply With Quote
