Old 12-26-2011, 10:19 AM   #1
240sx23
240sx23 is an unknown quantity at this point
What is a good compression reading for an sr20
Just curious lmk thanks
240sx23 is offline   Reply With Quote
Old 12-26-2011, 10:50 AM   #2
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Not sure but mines 170, 170, 155, 170 after a rebuild and 9:1 compression.
I can't imagine anything under 140 being too good even if its consistent numbers with all the cylinders.
Edit-pretty positive this has been covered before.
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 12-26-2011, 11:35 AM   #3
clutch187
clutch187 is an unknown quantity at this point
i know all cylinders should be +or- 14 psi of each other. most will probably say time for another rebuild
i accidently responded to EsChassisLove thinking he was the OP, sorry
clutch187 is offline   Reply With Quote
Old 12-26-2011, 12:10 PM   #4
jr_ss
This varies, lower compression motors aren't going to yield high comp numbers. Changes in head gasket thickness, piston compression ratio's and ring gaps will all play a role in different comp readings. Just because it "reads low" doesn't mean it's in bad shape.
Old 12-27-2011, 05:10 PM   #5
Kingtal0n
Kingtal0n's Avatar
most important thing is that they are all very similar to each other. if one cylinder is notably lower than the others that is an indication that something is wrong. could be anything- from a piece of carbon stuck in a valve, to a broken piston ring.
Old 12-26-2011, 12:07 PM   #6
jr_ss
Factory spec is 156psi, with 128psi being the minimum. 14psi difference between cylinders is the max allowable per the FSM. The important part is that they are consistent between cylinders. There are many variables that can create comp differences, rings, valves, and head gaskets are the most common. A leak down test will give you a better idea of how healthy your engine is.
