s13 and s14 timing chain oil covers interchangeable?
Im sorry if this has already been covered, i tried to search but when i do the screen stays white and does nothing. From what i have read the s13 and s14 ka24de blocks are the same, so are the s13 and s14 lower timing chain oil covers interchangeable?
Im have a rebuilt motor but i need a new oil pump and was going to buy one for an s14 but i have any s13 motor. Here is a link for the cover, Any help is greatly appreciated. Thanks in Advance. ![]() Imported from frsports.com Genuine OEM Nissan Front Timing Cover Oil Pump S14 240SX KA24DE
![]() Join Date: Jul 2008
Trader Rating: (32)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 32 reviews
Not sure how much help I am BUT on the s14 I currently own, there was a small oil leak. Previous owner rebuilt the motor and when I finally found the leak it was at the upper timing cover right by the exhaust manifold. I noticed that the cover had a different shape (very very slight, just enough to cause the leak) so all I did was wipe it clean and put silicone on it and no leaks since then. So I guess you can use it but it might be a little off
#3 | |
So i have done some more research via google.com, I found a forum from another site that says "l you have to do is remove a dowel pin from the s13 block (right side) if your using a s14 lower cover as the cover has one built into it." Post By smbonn2005 ka-t.org
So i think i figured it out i hope it helps someone else out in the future, If it does not work i will repost have i get the block back together.
