Old 02-06-2012, 01:09 PM   #1
gostrider
gostrider is an unknown quantity at this point
Steering Rack loose steering ?
How do I know if my steering rack is bad? I replaced my inner and outer tie rod ends and had the car align and it felt great very responsive. Now 2 months later the steering has a lot of play. Ever thing is tight I even replace the lower ball joints but no improvement. I did notice my power steering pump is leaking but I'm not sure if that will cause the sloppy steering..any idea where to buy a steering rack ? ebay?
gostrider is offline   Reply With Quote
Old 02-06-2012, 01:35 PM   #2
Hiighboost2
Hiighboost2's Avatar
Trader Rating: (32)
Hiighboost2 is an unknown quantity at this point
Feedback Score: 32 reviews
Send a message via AIM to Hiighboost2
Let me google that for you
Instagram @hiighboost @iasperformance
Hiighboost2 is offline   Reply With Quote
Old 02-06-2012, 02:25 PM   #3
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
Originally Posted by Hiighboost2 View Post
what a jerk. haha
does your car vibrates? check the bushing between the steering column and steering rack could be worned out.
Old 02-07-2012, 02:19 PM   #4
Hiighboost2
Trader Rating: (32)
Originally Posted by wangan_cruiser View Post
what a jerk. haha
Its all in good fun lol
Old 02-06-2012, 03:10 PM   #5
slider2828
slider2828's Avatar
Your rack AND/OR your sub frame could be loose. Your rack bolts require 75 ft/lb of torque.
Also check the 4 subframe bolts in the front that bolt to the chassis....
Is there wheel bearing play or tension rod?
What I would also do is put the front on jack stands and have a friend get in the car and turn the steer wheel.... All the while you get under it and see what is loose.
Turn and Burn!
