Old 03-06-2012, 03:49 PM   #1
warauto
warauto is on the path to ruinwarauto is on the path to ruin
Manual boost controller setup
Hello everyone,
Before everyone starts to tell me to search let me explain my problem. I have had an Sr20det for close to 5 years 4 years of which I have run a manual boost controller without problems. Recently I have decided to clean my engine bay up and get rid of my 2 piece hotpipe and replace it with a cxracing single piece unit.
Problem: old pipes had boost pressure line to connect to my manual boost controller to, cxracing line does not.
From what I have read the bottom of the throttle body vaccum lines are boost lines, could I just tap into these or do I need to weld a vacuum fitting on the hotpipe?
I really would like another option rather than welding a boost nipple on that single piece beauty
warauto is offline   Reply With Quote
Old 03-06-2012, 03:52 PM   #2
ryandriftingfat
ryandriftingfat is an unknown quantity at this point
That thing of beauty is going to get dirty in a hurry. So don't worry about it, boost pressure source should be near the compressor with short lines to your BC.
Get out your drill.
ryandriftingfat is offline   Reply With Quote
Old 03-07-2012, 04:46 AM   #3
warauto
Has anyone used the boost source from under the throttle body, with good results?
