![]() Join Date: Apr 2008
![]() sup guys..lookion to see what stock cam combo are guys runnin..right now im rockin 248x232 on my s14,which has a nice lil pull to redline.i tried the famous 248x248 set up but it drags ass,seems like the accel dies off compared to the stock 232x232..both 248x2 and 248x232 set-up has a sexy ass idle lope though..i did try yesterday 232x248 set up which has a stock feel to it but seemed to me the accel was insane compared to the other set ups i tried..so post what u guys think..
98 s14
im running 248 in 248 ex with the intake advanced 5 degrees N/A impression: pulls hard like the 232/232 stock plus keeps going to redline up power wise to redline 6800. dynoed 141 whp/146 wtq with intake , header, 2.5 catback exhaust and high flow cat. turbo impression: s14 t28, 550cc, z32 MAF enthalpy tune. little to no lag . just need to learn to shift precisely and quickly since u redline lightning fast ![]() no lopey idle . idles like stock idle should. |
#7 | |
![]() Join Date: Jul 2004
![]() ![]() ![]() ![]() Feedback Score: 8 reviews
I'm going to he doing the 240/232 Setup this weekend. Currently running the Stock 232/232 in my 95.
Other mods are: N60 on Neo Tuned on the Road for 12.5-12.7 Steady from 2-6.4k. Full 3" From Header Back (Test-Pipe) 2.75" CAI w/ 3" Ext. No Dyno Numbers yet ![]()
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got ![]() |
how many teeth did you move it,i dont get how u can advance the cam on a ka jus by movin the gear by itself with timing chains...now advancing the cam n gear as one i understand but jus t the gear by itself im a lil lost so help me out a lil...lol
#10 | |
Read the JWT Link and you'll understand.
i got it set up like the link suggested an wow..the cams came alive compared to before,the pull is straight to redline which is nice..like to try this set up on a high comp motor ...any one else rockin somethin different that likes the out come??
#12 | |
didn't search did you?
http://zilvia.net/f/engine-tech/91288-na-ka-faq.html |
im talkin somethin higher than 10, like 11. n 12 cr on pump gas,n some real pistons not sohc cast.. dont give me that bull sayin u need race gass for 11 or 12cr,for one my 13 i had i ran 92,93 on je 11,0,1 pistons with no issues or det and 2 hondas run on pump with these cr all the time
#14 | |
![]() Join Date: May 2008
#15 | |
but what's the point, seeing as you didn't even know about the timing change needed to make 248 cams work I doubt this thread will be anything other than just forum clutter compression is compression, what the hell do the piston type has to do with anything if they withstand the use intended? the motor above was put together by a friend SOHC piston compression was actually higher (the head was piruated) and the headgasket thickness chosen to keep the compression under 11. Reason was because the motor was built to use pump gas and to test a few ideas about NA KAs we had. you build something worthwhile to justify your shitty attitude and we can talk but as it stands you just come across as a typical zilvia dumbass good luck with your phantom build |
#18 |
if u read the na section u would see that i had dyno #'s from my last na build makin 183 with a shitty tune n not dailing in the 264's i had bro..nate1 can also comment on that
#19 | |
I'm now running the 240/232 in my 14.
Powerband feels the same but I can feel a slight increase in power/pull. Its a Tad bit more peppy but nothing extravagant. No bottom end loss or top end gain. Just a nice little what's feels like an increase throughout the entire powerband. Sadly no dyno plot to back up these findings. But the butt dyno does approve.
#20 |
niice..right now im on 248x248 set up. tryin to play around with the degree of the cams..i had it where idle was like stock,it felt a lil peppy nothin like stock..now i have it set up where it idle a lil like/sounds like a subie/muscle n it feels like it has waay more pull to it,nothin crazy..but im definitly thinkin of goin back to 232/248 set up i had before,waAy more response than my current n stock setup
#21 |
![]() Join Date: Jun 2007
I have mine set up as 248 (+5) x 248 (+2.5) havent dynoed yet but feels way better than my previous 248 (+5) x 248 (-2.5). On my previous I made 137hp and 140tq with basic bolt-ons. With the exhaust set as 2.5 advance mid range tq is awesome! Pulls from ~3.5k to ~6.5k then starts to die off.
#24 |
Running a S14 KA im going to be messing around with my cams in a few weeks i been searching for some combos and i have read good things about 248/232, now im seeing your doing 232/248 so i might try out both and see what i like
