Old 04-20-2012, 03:40 PM   #1
Jersthecool
Jersthecool is an unknown quantity at this point
SR My timing should be fine like this?
I was taking a look at everything and after spinning the crank pulley noticed that the chain is just one spot off. This is when the pulley in on tdc 2 the second one from the left where it's supposed to be and both the cam gears are exacty where they should be the only difference is the chain is slightly off. This shouldn't affect my timing at all like this correct?
Here's a picture what it looks like at tdc 2.
Jersthecool is offline   Reply With Quote
Old 04-20-2012, 04:41 PM   #2
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Uh, did you just put this together? Or just popped off the valve cover and took a look?
di-devol is offline   Reply With Quote
Old 04-20-2012, 05:29 PM   #3
Jersthecool
That's how it was before didn't change anything but looking at what I said it shouldn't make a difference it just sounds like the whole chain is off by one link correct?
Old 04-20-2012, 05:32 PM   #4
di-devol
No, dosen't mean that at all. If you never touched anything and this motor was running fine, if you keep spinning the motor over, it will eventually line up.
Old 04-21-2012, 02:20 AM   #5
Walperstyle
Walperstyle's Avatar
Walperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really nice
Send a message via MSN to Walperstyle
be careful wording that.
You don't want to spin the motor over if valves are going to hit against pistons, or if the timing chain is disconnected. When giving tech advice assume some dork might read it and start bending stuff.
KA-T ORG-Function over Flush
Walperstyle is offline   Reply With Quote
Old 04-20-2012, 06:25 PM   #6
Jersthecool
Thanks. I was 99% sure it wouldn't make a difference just making sure before I get it back in the car.
Old 04-20-2012, 06:39 PM   #7
JDMRIDDAZ
JDMRIDDAZ's Avatar
JDMRIDDAZ is an unknown quantity at this point
as long as the dots are 11 links apart besides timming set
ur good
シチサn w/ka20det:in progress
シチサnw/sr20det:stolen
JDMRIDDAZ is offline   Reply With Quote
Old 04-21-2012, 12:10 AM   #8
UNITEDMASTER
UNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to all
ur good
10 full links dot to dot
PS...Put the tensioner in,if your going to continue to rotate motor...
MR JACKSON.
UNITEDMASTER is offline   Reply With Quote
Old 04-21-2012, 01:58 AM   #9
rb25_s13*CHUKI
rb25_s13*CHUKI's Avatar
10 links is suppose to be oem but sometimes its 11 which is fine,just add some timing via cas =)
Obliterate
rb25_s13*CHUKI is offline   Reply With Quote
Old 04-20-2012, 07:48 PM   #10
rb25_s13*CHUKI
Timing is good! how does the cas look?
Obliterate
Old 04-20-2012, 07:57 PM   #11
Jersthecool
Good to hear! Cas is good as well. I actually did change out the headgasket but made sure the chain was in the exact same positions it had before. Didn't go by the dark part because it was off just made a mark with permanent marker. Found out how to adjust the cas and set it dead on so I'm hoping it fires up and runs perfectly.
