Old 05-01-2012, 12:30 PM   #1
GreenMNTDDc5
GreenMNTDDc5's Avatar
GreenMNTDDc5 is an unknown quantity at this point
Installing new Nismo long hub bolts
Hey there Zilvians,
I just purchased a 240sx recently with some broken hub bolts. I have some Nismo long bolts but I am worried that just replacing these wont fix my problem.
If the bolts are loose/broken doesn't that mean I will have to replace the hub that they are pressed into? Seems like if they broke loose than the spot they press into must be stripped or must be unusable.
Ill post a picture later to be more detailed, I'm just wondering if anyone has had this issue and had to replace them and what the process was.
Thanks in advance...
GreenMNTDDc5 is offline   Reply With Quote
Old 05-01-2012, 04:06 PM   #2
GreenMNTDC5
GreenMNTDC5's Avatar
GreenMNTDC5 is an unknown quantity at this point
So I got the spindle off using a 36mm socket and an impact gun cranked up to 140psi...
now I need to know if I should replace the hubs with new ones of if I can just install the new Nismo bolts into the stock hubs.
GreenMNTDC5 is offline   Reply With Quote
Old 05-01-2012, 05:06 PM   #3
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
It's all a matter of how hard you're driving the car. If the hub bearings were good before, you can always reuse them, however if you've already got the assembly apart, it wouldn't be a bad idea to just replace the entire deal while it's apart.
Truthfully speaking, even if the hub is goofed up you could always weld the new studs into place to keep them from spinning.
Old 05-01-2012, 10:37 PM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I think he's asking about the wheel studs Cody...
The old studs probably broke off because somebody used impact guns on the wheel lugs. Shit happens all the time when the studs get over torqued.
CLICK HERE!!!
Old 05-02-2012, 12:30 PM   #5
GreenMNTDDc5
Yes I am talking about the wheel studs.
I've seen people install them on here before by just putting a few washers on the bolt and then putting the stock lug nut on and tightening them to hell to "press" the bolt into the back of the hub, but I just feel like this might not be enough. Wish I knew a good/cheap welder I might just go that route to be sure. I don't like the idea of loose hub bolts.
Let me know what you guys think.
Old 05-02-2012, 12:49 PM   #6
az_240
az_240's Avatar
Trader Rating: (41)
az_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really nice
Feedback Score: 41 reviews
Send a message via AIM to az_240
Broken (I assume you mean broken off completely) oem wheel studs are pretty common.
Stack of washers and open ended lug nut works fine. Torque until you know it's pressed all the way.... you can usually tell when they are. Take a look at them from the back to be sure. You don't want them to have any gap between the hub and the wheel stud head or you could loose lug nuts or crack the studs off later.
az_240 is offline   Reply With Quote
Old 05-02-2012, 05:32 PM   #7
GreenMNTDC5
Xxxxxxxxxxxxxx
Old 05-02-2012, 05:33 PM   #8
GreenMNTDC5
No I don't think broken off so much as just came unpressed to the hub and now is spinning when I try to tighten the lug nuts down.
Old 05-02-2012, 12:49 PM   #9
SomeoneWhoIsntMe
SomeoneWhoIsntMe is an unknown quantity at this point
jesus christ, don't weld your wheel studs on
SomeoneWhoIsntMe is offline   Reply With Quote
Old 05-02-2012, 01:12 PM   #10
codyace
codyace's Avatar
Trader Rating: (58)
I'm not saying to weld them permamently, but 2-3 solid beads/tacks can make a world of difference. I'd sooner do that than buy a new hub.
FWIW: THere are PLENTY of real deal race cars that press and weld studs in as well...
Old 05-02-2012, 12:59 PM   #11
az_240
az_240's Avatar
Trader Rating: (41)
^if they are spinning putting a tack weld to keep them in place is not a big deal. If you ever need to replace just grind the tack off.
Old 05-02-2012, 01:22 PM   #12
SomeoneWhoIsntMe
if the studs spun in the hub, they trashed the knurl and are no longer a press fit, right? I don't know how I'd feel about a few tack welds holding the studs in place.
seems like a far less haggard solution would be to drill all of the holes one size up and press studs of a larger knurl diameter in. just saying.
Old 05-02-2012, 09:13 PM   #13
codyace
codyace's Avatar
Trader Rating: (58)
You do realize that the wheel studs secure the wheel to the hub through clamping force, not the knurl/press....that only functions to keep the stud form spinning upon removal/installation.
You can say it's haggard, I'll point out to the same example of there being some real deal track cars that even do such a thing.
Old 05-02-2012, 05:12 PM   #14
GreenMNTDC5
Thanks for the input, anyone else please chime in...
But ya, I'll probably take the hubs off and see if the knurl is re-usable. If not I think I'll spend the money and get new rear hubs.
Old 05-03-2012, 07:31 AM   #15
GreenMNTDDc5
So I pulled all the hub bolts out of the hub and inspected the "threads" of the hub. (It's not really threading but inner the ridges that the bolt presses into). They seem a little worn down/stripped, but so were my bolts that I pulled out. Previous owner probably used a impact gun on the lug nuts too many times.
I'm thinking that my new bolts that have deep, sharp edges will hold in these holes once pressed in (using the washer method) correctly. So I'm going to try that and if that doesn't work and they still spin, it looks like I can find a new set of rear hubs with bolts for a little over $110
Thoughts?
Old 05-03-2012, 08:13 AM   #16
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
once they are worn down you might as well just invest in new hub, welding them in place is to micky mouse to me
S-Nation S13 is offline   Reply With Quote
Old 05-03-2012, 08:40 AM   #17
0wn3r
0wn3r's Avatar
0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of
Sounds like you should really try and get these pressed in. I'd probably try to avoid the washer trick if you're having spinning issues. The washer trick is 'spinning' it into the hub vs a press which would go straight in. If you have the hub off, pressing wheel studs into a hub takes no time at all.
As long as you don't think your hub is messed up already, I wouldn't bother replacing it. Also, I would not recommend trying to drill larger holes and save that option for dead last.
97 240sx se
0wn3r is offline   Reply With Quote
Old 05-03-2012, 09:32 AM   #18
GreenMNTDDc5
How would I go about pressing the wheel studs into the hub?
Old 05-03-2012, 09:39 AM   #19
0wn3r
0wn3r's Avatar
With a press. You can buy one or find someone that has one and it'll take about 2 minutes.
97 240sx se
Old 05-03-2012, 10:33 AM   #20
GreenMNTDDc5
Awesome thank you
Old 05-03-2012, 02:25 PM   #21
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
tapdeznutz is an unknown quantity at this point
Feedback Score: 50 reviews
how would one get the old studs out? with a big ass hammer?
tapdeznutz is offline   Reply With Quote
Old 05-03-2012, 02:38 PM   #22
0wn3r
0wn3r's Avatar
Yes, they come out easily with a hammer. Some people hit them with a 2lb hammer while on the car, but you can do it just as easily while the hubs are off.
It might surprise you how easy they come out. Like cody said, the knurl doesn't hold the stud in very tightly, it's mainly there for clamping force when you put the lug nut on the other end.
97 240sx se
Old 05-03-2012, 08:16 PM   #23
GreenMNTDC5
Ya I got the old studs out no problem a few light hits with a hammer should do the trick
Old 05-03-2012, 08:17 PM   #24
GreenMNTDC5
I dont think that the bolt will spin with the washer method.
if I hold the bolt and tighten the lug nut down onto the washers wont the lug nut be the only thing spinning as the bolt would press into the groves????
Old 05-03-2012, 08:52 PM   #25
0wn3r
0wn3r's Avatar
Hold the bolt how? Up to you, I know people that have used the washer method and been ok. If you take a poll between the press and the washers with the hub already off, I think I would know what would win.
97 240sx se
Old 05-03-2012, 09:15 PM   #26
chumchum
chumchum is an unknown quantity at this point
you use the washer method to pull the studs through until they bottom out in the hub. there is also a recessed tool that you slide on the stud and tighten down a lug so that it pulls the stud through. both are the methods used by mechanics to seat the studs. there is nothing mickey mouse about doing this and is just as efficient and easy as a press except you dont have to remove the hubs from the car.
chumchum is offline   Reply With Quote
Old 05-03-2012, 11:25 PM   #27
0wn3r
0wn3r's Avatar
Efficient doesn't always mean effective. Why put stress on lug nuts and the new stud threads when you can just use a press and fully seat them in a minute without dealing with an impact gun? Maybe if you really really don't want to take the hubs off, sure. Meh, not my car.
97 240sx se
Old 05-04-2012, 07:13 AM   #28
GreenMNTDDc5
Thank you guys for your input, Ill try the washer method and if the bolt starts spinning I'm just gonna stop and try to find someone with a press.
Is this a common tool that would be used by mechanics at most garages???
Old 05-09-2012, 09:03 AM   #29
GreenMNTDDc5
So the washer method definitley doesn't spin the bolts as you put them in. It pulls them into the grooves and now they seem to be secure. I took pictures of the whole process and am going to post a DIY on here shortly.
Thanks everyone on your help, I'll keep you posted to let you know how they hold up.
Old 05-09-2012, 11:30 AM   #30
0wn3r
0wn3r's Avatar
It's great you want to make a DIY, but it's not the optimal way to go about putting studs in...
97 240sx se
