Old 02-05-2004, 11:37 PM   #1
santanavanna
santanavanna is an unknown quantity at this point
just got sportlines and kyb agx's
i just got this set up for my car and i am gonna install them on sat...i took a look at my stock shocks and i noticed that the dust boots are pretty messed up....i called up the dealership and they sell the fronts for $26 each and the rear for $52 each....thats kinda pricey....i called kragen and they only carry the front and those go for $16 each...i was wondering if i really needed them on my car or can i go without....also if i really do need them does anyone know where they carry the whole set for a decent price...or i can somehow bring the ones i have back to life....if anyone can help please tell me~!!
santanavanna is offline   Reply With Quote
Old 02-06-2004, 01:13 AM   #2
240Driver39
240Driver39 is making a name for him/her self240Driver39 is making a name for him/her self
Send a message via AIM to 240Driver39
pretty sure www.tirerack.com sells the boots for a reasonable price. I believe thats where i got mine when i did my suspension.
1990 240sx 5spd fastback
240Driver39 is offline   Reply With Quote
Old 02-06-2004, 07:00 AM   #3
Replicant_S14
Replicant_S14's Avatar
Replicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of light
Yah. IIRC they're about 10 bux.
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink.
Replicant_S14 is offline   Reply With Quote
Old 02-06-2004, 05:02 AM   #4
kandyflip445
kandyflip445's Avatar
Yes, you should use the boots. Just call up all the auto part stores in your area and shop around. As for the internet I'd look at tirerack like 240Driver39 suggested.
My 240 vBgarage
Old 02-06-2004, 07:57 AM   #5
Dream240
Dream240's Avatar
Definitely get new boots. The boots protect the strut/shock rod from dust getting in there and eating away at the seals. And once the seals go....bye bye suspension!! I did the exact same set up you have, and I picked up my boots through the dealer(front) and KYB website(rear). Check them out. You should also get new pillow mounts both front and back!! Get these through KYB too. They're basically stock replacements as far as performance but it's much better to get the whole thing new right off the bat. Also look into getting new washers for all 4 wheels. I mean the big pink washer that fits on right between your frame and the shock/strut assembly. You can see it in the fronts when you pop the hood and look at the mounting bolts. Nissan has em for a fair price (10.00 a piece I think).
All in all a little more money but well worth it. That way you won't have to go back in there later and pull all the struts out again to replace worn pillow mounts, washers, etc.
p.s. One other thing make sure you at least get front camber correction bolts BEFORE you do the install. Basically it's one bolt per side replacing the top of the two bolts. I got mine from enjukuracing.com for 25.00 bucks. Money well spent considering I don't want to go through tires every year. The backs should end up at a 2 degrees negative on stock adjusting parts. Not bad but you will notice a little inner tire wear. Oddly enough 2 degrees neg. is the Nissan factory camber spec!! Wierd.
Good luck!!
Old 02-06-2004, 09:21 AM   #6
Var
Var's Avatar
Send a message via AIM to Var
Good luck!!
i highly doubt that bro. plus the worst part of the 2 degrees negative camber(IMO) is not tire wear, it's understeer.
Hi
Old 02-06-2004, 10:31 AM   #7
epoxy_nc
epoxy_nc is an unknown quantity at this point
let me know how they are man
epoxy_nc is offline   Reply With Quote
Old 02-06-2004, 06:34 PM   #8
santanavanna
sweet....i appreciate the help guys...imma try tire rack
Old 02-06-2004, 06:52 PM   #9
santanavanna
is the kyb boots the same for the front and back?? or do i need the strut mounts for the front and the other boots for the back?? im sorry i am new to all this so please dont be too harsh on me
Old 02-09-2004, 11:12 AM   #10
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
I didnt need the front camber bolts when I installed mine. They were able to get it back to factory spec when I did an alignment.
rancid240 is offline   Reply With Quote
Old 02-09-2004, 12:01 PM   #11
Dream240
Dream240's Avatar
Here's the interesting thing. If your car is lowered, the factory specs don't necessarily mean your car will get exactly within the tolerance for a good alignment. Haveing a 2" drop on your car dramatically changes your "standard" specs. So factory specs probably wouldn't apply. The other thing to remember is that if your car's been in an accident in it's life the front or back end probably aren't perfectly straight, so that throws you off a little too.
Old 02-09-2004, 06:49 PM   #12
Var
Var's Avatar
Here's the interesting thing. If your car is lowered, the factory specs don't necessarily mean your car will get exactly within the tolerance for a good alignment. Haveing a 2" drop on your car dramatically changes your "standard" specs. So factory specs probably wouldn't apply. .
what are you talking about? please explain yourself in detail cause it doesnt make any sense to me. 1 degree of camber is the same whether your car is stock or lowered. Same with toe and caster. So if you they are put back to factory specs, what would be wrong with your alignment..aside from bump steer.
Hi
Old 02-09-2004, 06:28 PM   #13
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
so if a car is lowered, and suspension geometry is changed so much as to deviate from the factory specs, how are you supposed to figure out what your new alignment should be?
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 02-09-2004, 06:58 PM   #14
EchoOfSilence
suspension geometry would be different, so the car would handle differently because of the different loads to the susp. components. toe and camber is only a part of what suspension is about.
