Old 07-18-2012, 03:52 AM   #1
2slow2go
2slow2go's Avatar
2slow2go will become famous soon enough2slow2go will become famous soon enough2slow2go will become famous soon enough2slow2go will become famous soon enough
S14 sr20det bad clutch?
So i'm thinking about buying a s14 with a s14 sr20det. I drove the car around and I tried to rev it up and dropped the clutch at a dead stop but no burn out.
While driving let say 20 mph and i rev it up and change to next gear it usually just revs and doesn't really go anywhere faster. It does go into the next gear though but it still remains at a high rpm to where i revved it about.
The transmission and stuff doesn't grind and it shifts smoothly. I forgot to check if the rpm slipped after changing gears.. it mostly just keeps revving and goes nowhere.
I'm guessing that it a bad clutch? is this the problem?
I read other places it might just be a adjustment to the pedal and the slave(bleeding)?
Also, if anyone knows a write up on changing a clutch on a sr20det that would be great. Or any tips that you can give on replacing one
2slow2go is offline   Reply With Quote
