Old 09-17-2012, 10:04 PM   #1
Juantwo3
Juantwo3's Avatar
Juantwo3 is an unknown quantity at this point
Engine Hump??
OK, so my s13 coupe has been making this forward and backward shifting movment while between 2,000 and 3,000 rpm while i holding at a set speed. it does this in every gear EXCEPT when i have it in nuetrual. I changed the transmission mount it was obviously broken, but it continued to make the backward and forward motion i converted my auto to a 5speed about 3 months ago and i bought a used flywheel, so thinking to myself that maybe it was warped i replaced it with a brand new one along with a new excedy clutch kit (stock one). it still does it just not as bad as it used to. i googled it nothing came up.
any help would be greatly appreciated
Juantwo3 is offline   Reply With Quote
Old 09-17-2012, 10:28 PM   #2
AutechKouki
AutechKouki's Avatar
Trader Rating: (43)
AutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura about
Feedback Score: 43 reviews
I knew my brother doing this back when he was learning to drive stick shift. It only happened in first into second, then went away. Learned to drive and now it doesn't happen anymore.
Maybe your clutch pedal is out of adjustment causing improper engagement? Hard to say.
AutechKouki is offline   Reply With Quote
Old 09-18-2012, 08:12 AM   #3
Juantwo3
Juantwo3's Avatar
i was thinking the same thing ima have to check it out thanks for you input
Old 09-18-2012, 09:15 AM   #4
itsjustdaphne
itsjustdaphne's Avatar
itsjustdaphne is a well-known jackass
The only issues relating to this I've heard of were the results of bad sensors.. speed, throttle and crank position or simply the tranny sensor.
Good luck though.
@ddaapphh | @spectuned
itsjustdaphne is offline   Reply With Quote
Old 09-19-2012, 09:44 PM   #5
Juantwo3
Juantwo3's Avatar
anyone have any other issue related to this??? its driving me mad
