![]() I have an S14 with an S14 SR and was wondering if the KA fan and clutch will fit an SR shroud.
![]() ![]() Last edited by djfiniki; 09-25-2012 at 06:28 PM.. Reason: Text error |
![]() Join Date: Nov 2007
Trader Rating: (36)
![]() ![]() ![]() Feedback Score: 36 reviews
A ka fan will hit the front part of the head of an SR you have to notch the backside of the blades a little. As far as it fitting under a shroud, that would be a test fit type scenario. It should fit though as the sr fan is offset further forward than a ka fan.
[QUOTE=mewantkouki;4920064]A ka fan will hit the front part of the head of an SR you have to notch the backside of the blades a little. As far as it fitting under a shroud, that would be a test fit type scenario. It should fit though as the sr fan is offset further forward than a ka
THANKS. |
kouki man
![]() Join Date: Apr 2006
Trader Rating: (36)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 36 reviews
Ka fan clutch and fan will work. Fan clutch will fit but the fan itself will hit the sr crank. Just need to shave each blade until u get the clearance to make it work. Its not hard. I currently run it on on my sr. No problems
![]() Join Date: Jan 2011
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
KA clutch fan will not work on SR. The blades will be too close to your belts and accessories. You must get an SR fan clutch. You can use the KA blade on the SR clutch, but you must use an SR clutch.
